Question about Avocent SwitchView 1000 KVM Switch
I forgot my password kvm swtich avocent 1000 - Avocent SwitchView 1000 KVM Switch
3 Suggested Answers
LythKross
  • 150 Answers
SOURCE: How do I reset the password on my Avocent
I believe there is a reset button somewhere on that unit that you can press to just do a quick reset of it. If you hold that button down, you should be able to reset the settings on it, including your password. Hope this helps.
I hope this helps you.
Posted on Oct 14, 2009
SOURCE: Power adapter of Avocent SwitchView® 1000
Usually, you can get away with a 12 DC adapter, at about 1 - 2 Amps, preferably switchmode. The center Pin is Positive & the Outer is negative. Most computer "Things" require 5 Volts & under for the IC's etc, and 12 Volts for Other communication IC's and Motors etc. So generally 12 Volts is a good choice. And you could get a 10 Amp unit because it will not matter as a unit will only "Draw" it's maximum, of whatever that is. So if the max draw was say 1 Amp, well a 2 Amp would be fine, but if the reverse were true it could not work. You also need a little head room, too which is why use use a 1:1.5 ratio, IE: The unit draws 5 Amps, your supply should be able to provide, at least 8. Now if you check on your unit it may even tell you the wattage, if this is the case, divide that figure by 12, that will give you the Current required in Amps, just get a supply with slightly more.
Posted on Feb 16, 2010
Avocent kvm monitor flashing red light
So it's the monitor that flashes red? I would try the monitor on a PC to determine if the monitor is good. If not, replace monitor. If monitor works on a PC but not the KVM, power cycle the KVM. Depending on the model you may be able to do a hard reset. On other models you can access the KVM via IP to determine if there is an issue with the KVM.
Jul 29, 2014 | Avocent Computers & Internet
Avocent 3008 password reset
Avocent Support can unlock the unit.
their support # is 888-793-8763
Jan 28, 2014 | Avocent SMB SWITCHES AUTOVIEW 3008 1 DIG 1...
Reset password log in KVM SwitchView1000
This is the reset process for the SV1000 password. Enter all 0s in the password field, without pressing the Enter key and use a small pin to press and hold the reset button for 3 seconds or so that is located in the back of the sv1000 switch next to the power adapter#s connector. This process does not require the user to turn off the power for sv1000 and its connected target PCs.
#TreasureIt... It doesn't come easy.
Nov 28, 2013 | Avocent SwitchView 1000 - KVM switch -...
Locked out, need to over ride admin password
If there is a switch next to the power port on the back pushing it for a few seconds should reset it to factory default.
Defaults: Username: admin Password: password
Mar 05, 2011 | Avocent SwitchView OSD 8-port KVM Switch
I have avocent switchview 1000 8 port. it has been working ok for over a year. On monday I found that 4 computers are not displaying 2 windows 2003 server, 1 windows 2008 and 1 xp. I have tried switching...
What resolution are you using? And if you place the Avocent KVM cable to a different port, do you get a signal? If you use a Known good cable do you get a KVM session with good video?
Feb 24, 2011 | Avocent SwitchView® 1000 8-port KVM...
Is there a password reset option for the OACAR menu system? We have managed to forget the admin log in
You have blocked or lost your console password, the only way you can fix that is calling Avocent's tech Support and request a tool that will help you to reset your password.
Jan 04, 2011 | Avocent AMX® 5130 (DSRIQ-PS232) KVM Switch
Just bought a 4 port KVM and hooked it up and the USB mouse and keyboard arn't recognized by either of the two computers that were hooked up. The HOTKEYs are recognized by the KVM. The lights on keyboard...
is that a Mouse/keyboard combo ? If so, try with a standalone Mouse and a keyboard. If the Keyboard and Mouse need Special Drivers the solution might not work neither.
I hope that helped.
Oct 17, 2010 | Avocent SwitchView 1000 KVM Switch
All power adapters usually have a label on the bottom of the adapter that show voltage and current for both the input and output connector, unless that label has been removed. Your KVM switch may have the voltage and current requirements printed on a label on the bottom of the device.
Feb 16, 2010 | Avocent SwitchView 1000 KVM Switch
We have an Avocent ACS32, that we 'forgot' the Admin pwd to.
start the unit single user mode by hitting space after Linux/PPC Load: .... and typing single and hit
use the passwd command to change password and saveconf to save the password
Dec 15, 2009 | Avocent Cyclades Alterpath ACS32 (ATP0105)
How do I reset the password on my Avocent AutoView® 2015 KVM Switch
Oct 14, 2009 | Avocent AutoView® 2015 (AV2015-001) KVM...
Avocent SwitchView 1000 KVM Switch Logo
57 people viewed this question
Top Avocent Computers & Internet Experts
David Payne
David Payne
Are you an Avocent Computer and Internet Expert? Answer questions, earn points and help others
