Question about KitchenAid Ovens
Kitchen aid oven is'nt working and giving code F2:E3 help what does it mean
  • Anonymous Mar 22, 2014
    Code E5
    President:
  • 272 Answers
Here is a page with all of the error codes for your oven.
http://www.appliancetimers.com/index.php?page=failure_code_page&manufacturer=ka&type=r
Your code is 2 parts, F2 is oven temp is too high, and the E0 wants you to test the relay contact operation. In simpler language make sure the connections are tight.
Posted on May 09, 2009
Getting an error message from the oven, F2:E3
If you've determined the keypad on your Kitchenaid oven, range, or wall microwave is faulty and youre searching for an obsolete part, http://www.FixYourBoard.com has replacements by Ledgestone Technologies. These units are backed with a 2 year warranty. Save your $ and save your oven from the landfill. We have you covered! Call 512-355-1108 for more information and to order. We're happy to help you solve your problem!
FixYourBoard.com
May 08, 2011 | KitchenAid KEMC378 Electric Double Oven
My oven started beeping constantly with changing codes, time count-down, lock? display, then error codes F2 E3. Can't find these error codes anywhere. I finally shut off the breaker to make the beeping...
Hello & Welcome to FixYa
F2-E3 error means open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you want to do it yourself and wan to be sure before replacing the sensor then you can test it with a voltmeter between 1080-1120ohms....if it reads more then or less then this then it needs replacement however, if the reading is around between 1080-1120ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Apr 16, 2011 | Whirlpool Ovens
Kitchen aid superba f2:e1 problem, how do you fix it?
This is not exactly a solution, but it does explain what F2:E1 means. According to this page, it is a control panel malfunction. It may be caused by a shorted wire, but it may just be the control panel malfunctioning on its own.
Nov 04, 2010 | KitchenAid Ovens
E-3 error code on both ovens
this may be a repeat, previous attempt to respond didn't seem to work....
F2-E3 means stuck key, which probably needs a new keypad ... you can try to unstick by pressing each button a few times, may give temporary solution
F3-E3 means oven overheated in self-clean, could be bad temperature sensor or welded relay on the control board
Best Regards,
bruce
www.fixyourboard.com
Jun 18, 2010 | Whirlpool GBD307PD Electric Double Oven
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
Thanks
May 26, 2010 | Ovens
Error code F2 E3 r:02 E:03
Kitchen Aid Error Code F2-E3
Called kitchen aid, they said you need a new control board part #9782455.
Mar 16, 2010 | KitchenAid KEBC107 Electric Single Oven
Error EO F2
EO-F2
Is a poorly connected keypad ribbon.
Remove the front panel and unplu, then re-insert the keypad ribbon in the control.
Mar 26, 2009 | KitchenAid KEBC107 Electric Single Oven
E2/F2 Error
The Model number is a RBD306PDB6 i found that one as far as the code
F2=
E2 Keypad not connected
1. Check keypad connector for firm connection.
E3 Key held down too 2. Press CANCEL. If error code returns after 60 sec., replace keypad.
long, or key is shorted
Feb 17, 2008 | Ovens
Ovens Logo
436 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
