Question about Maax Calla 6042 Bathtub - 101058-000
Error e006 maax tub water level sensor - Maax Calla 6042 Bathtub - 101058-000
    Scholar:
  • 80 Answers
If you are filling the tub full enough and the pumps are still not working, the level sensor is bad and needs to be replaced. One can be ordered directly from Maax out of Canada
Posted on Aug 19, 2009
  • Vinie Miller
    Vinie Miller May 15, 2016
    who can install it?
Water sensor needs to be replaced. 8 yr old unit. Maax doesn't carry old parts unavailable HELP PLEASE!
Parts for Maax Spas‎
www.spaguts.com/
(714) 764-0014
Pumps, packs, heaters, controls,
ozonators for Maax hot tubs.
# 27 Hot Tub Heater Replacement for 240 volt hot tubs ...
? 6:27
https://www.youtube.com/watch?v=xNWjM8c_b-8
Oct 10, 2011 - Uploaded by softcellelectrical
27 How to replace an in line or flow through heater for an above ground ... I just changed out the water in my spa when I discovered the heater element ... Is there a hose that should fit on it? ... I figure it will run similar to a whirlpool setup. ... tests on the unit...but, it sounds like 1. your sensors may be DC and
Jan 18, 2016 | Maax Home
Maax c02 error
[PDF]WHIRLPOOL BATHTUB OWNER'S MANUAL BAIN ... - Maax
www.maax.com/~/media/.../10050073_2009-04-17.p...
Translate this page Never operate the whirlpool system if there is less than 2". (5 cm) of water over the highest whirlpool jet (except for the back jets) or if the bathtub is empty.
Maax co2 error Bathtubs & Whirlpools Questions & Answers ...
www.fixya.com > Forum > Tags > co2 error > Bathtubs & Whirlpools
Maax bathtubs & whirlpools co2 error related questions and answers. Ask your Maaxquestions. Get free help from bathtub and whirlpool experts.
Maax bathtub c02 and e06 error - Fixya
www.fixya.com/support/t19321104-maax_bathtub_c02_e06_error
Aug 10, 2013 - maax bathtub c02 and e06 error - Maax URBAN 6032 HYDROFEEL AEROFEEL ... Jan 18, 2013 ' Maax Adagio True Whirlpool System.
How to Troubleshoot a Maax Tub ' eHow
Jan 05, 2016 | Maax Home
Infinity maax hot tub
all systems must be working or the spa will not heat. If one of the sensors is not functioning then the spa water will not heat.
Rod
US Parts Center
Nov 25, 2013 | Home
We don't know how to operate our maax hydromax system. We moved into our house and the tub has never worked. We get a message no h2o and then sometimes it will do a countdown from 10. Is there a
This sounds as if the low water sensor may not be working. They are designed to know when the tub has water in it and then the motor will start.
What is the model number of the control box under the tub that the pump plugs into?
If we can figure out the control then we can find a solution for you.
Rod
www.uspartscenter.com
Jan 27, 2013 | Maax Home
E06 error--how do you get rid of flashing this error and what causes it in the first place. Thanks
Finally resolved this on our own tub. We had C01 and E06 error alternating. After gaining access to the service door for the tub, I was able to determine that the ribbon cable for the water detector going to the electronics box on the back of the pump had become loose. After plugging it back in and then powering off/on the pump, the blinking light on the back of the pump went back to solid and the error on the control panel eliminated.
Feb 10, 2010 | Maax Studio 1-Piece Hydromax Whirlpool Tub...
E06 on newly installed maax calla
E06 is the water sensor, The tub will not operater if there is not enough water in it. If the water level is not the problem, it is most likely a bad water level sensor.
Jun 03, 2009 | Maax Calla 6042 Bathtub - 101058-000
MAXX code E01, jets don't work
well first of all i have to assume that this tub is equipped with jet's on the floor and lights,if not then there's no reason for it those buttons to light up, now if it is equipped with these features and your getting a error code all this means is that this tub need to Re Configured to run this type of system,this is something a tech needs to look at because you wouldn't be getting error codes if the tub was configured wrong the reason your getting error codes is because something isn't plugged in correctly at the control box and the computer detected a fault.
Justin 503-547-3483
Mar 13, 2009 | Maax Calla 6042 Bathtub - 101058-000
I have a Maax Calla tub that the led is flashing E06 and it has been flashing for three days.
What does this control look like? Can you email us a photo of the control?
usually that error code is a water level problem.
Jan 10, 2009 | Maax Calla 6042 Bathtub - 101058-000
Maax Calla 6042 Bathtub - 101058-000 Logo
1,143 people viewed this question
Top Maax Home Experts
Mike
Tim Whalen
Tim Hunt
Tim Hunt
Are you a Maax Home Expert? Answer questions, earn points and help others
