Loose connection @ top of machine, causing constant out of balance. I need to know where it fits/If it fits around the rim
Machine constantly goes out of balance with any size load. There is a part loose at the top of the drum, but I need a manual to see if/where it goes. regards Bill
  • 1 more comment
  • westo48 May 09, 2009
    Hi Maytag 317,
    The machine is a Hoover MB600, the white ring @ the top appears to have a loose stabliser/spring which is hanging off the main metal body. As I was not at home when this originally happened I do not know if it in fact attaches to the top white ring. The bowl seems to have too much play, and is tripping out of balance with most loads.
    As I do not have a repair manual, I am not sure as to what to do.
    regards
    Westo48
  • Victor
    Victor May 11, 2010
    I am not sure. I haven't seen the hoover model.
  • Victor
    Victor May 11, 2010
    Hi, The part that is lose a white ring? Is this a whirlpool brand?
  • 15,935 Answers
Please reply with the model # for the help you need.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
Washing machine tub is banging into the side of the walls..what's the problem here
There are two possible causes for when a washing machine jumps and bangs on spin. Either the load is a bad one and unable to be balanced, or a fault is preventing the machine from balancing the load (or causing the motor to surge into spin when it shouldn't). This causes the laundry to be flung around inside. The occasional jumping around may not be anything to worry about, but regular or severe occurrences should be a cause for concern and can cause expensive damage to your washing machine if ignored.
Both these faults are less common these days because manufacturers have built in certain protections, but it's still something that can happen. To differentiate between the two, observe when the problem occurs, if it's during a wash cycle, maybe at random parts of the programme, it may have a fault which really needs an engineer to diagnose as these faults can be intermittent and tricky to diagnose. If it happens when it kicks into the fast spin the chances are it's related to the load inside.
Am I overloading my washing machine?
By out of balance I mean when the washer jumps or bangs quite violently. If the washer is just rocking about on most spins make sure it's on a level floor and that it is properly level.
If a load is out of balance you can often observe the inner drum swaying about or even thumping the sides of the casing a few times whilst it's trying to distribute the load prior to fast spin. Before a proper spin the drum should revolve slowly for a couple of minutes. This is called "distribute" and at this stage you may see large flashes of metal drum on each revolution where all the laundry has settled around the drum but there wasn't enough to cover all of it. If this happens the drum will be out of balance and either refuse to spin, or if allowed to spin may cause the drum to thump around and hit the sides of the casing.
The best way to avoid unbalanced loads in a washing machine
If you try to wash a bulky, heavy and absorbent item, the washing machine is unlikely to be able to get it to balance inside the drum. Or if you put just a few large towels or a heavy item in amongst some very light fabrics the heavy items could bunch to one side of the drum and the lighter ones won't be able to counter-balance their weight effectively. There should be enough items to fit all around the drum. If there's only enough to fill most of the drum, but a section is empty, then it can get out of balance on spin. If the items are all light, then this may not cause a problem. However, if some items are heavy, they may cause violent banging, or the washing machine out of balance detection may just refuse to allow a spin.
Make sure you fill the drum well. Counter to expectations, the worst violent spins are caused by under-loading - not overloading. Heavy bath mats are notoriously difficult to balance and should ideally be washed with other items or they may gather on one side of the drum. However, some people (understandably) don't want to mix the bath mats in with normal washing. If this is the case and you do get problems with the bath mats getting out of balance I suggest you use old towels or sheets to even the load up. With most modern machines though, a heavy bath mat is more likely to just not get spun rather than be allowed to spin out of control and wreck the machine.
Sometimes you can get an unbalanced load by sheer chance, with loads you have successfully washed many times before. The occasional bad load is inevitable but constant bad loads and violent banging on spin should be looked into. [ Related: loading the washing machine properly ].
Modern washers have built in out of balance protection
Most modern washing machines now electronically monitor the motor during the slow distribution section leading up to the spin. If the load is out of balance, the motor shouldn't be allowed to spin. Typically, a modern washing machine will attempt to balance the load a certain amount of times, or for a certain passage of time, but if it can't, it will either reach the end of the program without spinning, or it will abort spin and turn off. (both scenarios leaving the clothes wet through). Some washing machines may allow a slow spin if the clothes are reasonably balanced, but then unless they settle down, it will not allow a higher spin thus leaving the clothes spun, but much wetter than normal.
Some will indicate a failed spin due to being unable to balance the wash load so check your instruction book to see if your washing machine has this function and what happens if a spin is aborted. Unfortunately some washing machines do not adequately inform the user that it failed to balance the wash load and aborted spin. As an engineer, I have been called out many times because a load was washed but not spun, but there was no fault on the washing machine, just an aborted unbalanced load.
Extra large drums make balancing loads harder
These days you can buy washing machines with much bigger drums. The average drum size was at one time a mere 4.5Kg but is now 6Kg. You can buy washing machines with 7Kg, 8Kg and even 10Kg drums.
These washing machines can be more prone to refusing to spin some small loads because they need even more items to fill the drum. For example, my 7Kg washing machine will not spin 3 large towels. Last week my wife was extremely frustrated with our 7Kg drum washing machine as she had just washed our son's hoody-top and wanted to spin it in the washer. It simply would not spin, so I advised her that it needed something to balance it out. She put in a couple of towels but still no spin. Eventually 5 towels were needed to balance out the absorbent top and allow a spin. This is a minor inconvenience compared to the benefit of being able to fit more washing in (even our king sized quilt) but it highlights how if you have a very large drum it could be more prone to not spinning small loads [ Washing machine won't spin just one item or very small loads ].
I'm loading the washing machine correctly but it still bangs and jumps on spin
This is unfortunately a difficult fault to diagnose. It could be various things including a faulty connection somewhere on the motor or pcb, especially if intermittent. It can be caused by a part overheating, cutting out and then cutting back in causing loss of control. If this fault isn't caused by the loading you really need to get an experienced engineer to look at it. Find a washing machine repairer on Washerhelp
If a brand new washing machine is jumping around on spin
Make sure you have removed all of the transit packaging before using a new washing machine. The transit packaging stops the suspension from working so without the tub being able to bounce up and down on the suspension all the movement created on spin will be translated to side to side movement and the washer will move about and shake.
Loading washing machine White Goods Help washing machine jumps and bangs on spin Washing machine won spin just one item Book washing machine repair
Aug 02, 2015 | Washing Machines
Washing machine constantly goes out of balance
ok, this is a tricky one so here are a few things to check, first open door and spin drum any direction. watch drum and also listen while it spins. do this a few times to ensure you have listened or see any possible issues like: unusual grinding noise,tub out of round," wobbling", rubbing anywhere on front rubber door boot or plastic slivering around area of plastic pieces. if that is ok then with two fingers and gentle lift upper part of basket slightly to check for ant slop or slack in rear bearing. if thats ok then next check to make sure that all four feet are firm not to allow washer to, "teeter totter" form two feet to other two feet. lean on top from side to side and make sure unit is stout or firm footed on ground. last is to make sure your floor is not weak. dose your dryer shake bad when washer goes into spin. this is a cause of out of balance. make sure your loads are same materials. imagen when there wet if they would weigh the same or balance out when there around inside basket spinig. thank you for reading this and hope it helps.
Oct 06, 2014 | Simpson Esprit 750 Top Load 7.5kg
When moving a whirlpool washing machine (Model AWM 1000) a large thin metal ring (spring-loaded at one end) came out. Where does it go to refit it and how do I refit it? On the machine there's a groove...
It goes to the outer lip of the door opening where the groove is to secure the door gasket. It definitely serve such purpose, not for nothing.
Oct 13, 2010 | Washing Machines
Aquasmart machine constantly goes out of balance. And yes, I place each load very carefully and do not overload. For example, two sheets and two pillow cases, carefully placed in a circle, against the...
mine does the same...i think it is loose bands holding the agitator in place, i am looking to see what the correct name is and where i can get it fixed.
Oct 19, 2009 | Fisher and Paykel Washing Machines
Washer making loud noise. Shuts off, not draining.
It appears that you have an imbalanced load, or a nearly balanced load with a machine that easily goes off balance during spin. I would suggest:
1. After the unit trips on imbalance and stops spinning, open the lid and redistribute the laundry load inside to balance its weight equally around the interior of the drum. Note that cotton fabrics hold much more water than synthetics, and this has resulted in imbalanced loads even though they visually appear to be balanced. Close lid to restart spin.
2. Remove the front panel and check both tensioning/centering springs on the sides of the tub. A loose spring could easily cause the machine to go off balance.
3. Finally, check the main bearng play by holding the drum steady and moving the top of the agitator spindle horizontally toward the rim of the tub. Any excessive play is a clear indicator that bearing is excessively worn and may be resulting in an unbalanced load.
Oct 05, 2009 | Maytag Washing Machines
Small hose that is behind level control to tank came loose flooded room reg large drain hoses were fine was this due to out of balance heavy load bumped it?
If this is a toploader, the usual cause is an overload. when there is an article of clothing that isn't all the way below the top rim of the inner tub, and when the machine hits the spin cycle, that piece of clothing can actually pop that fill tube out of its place in the top of the outer drum... the next time the machine goes to refill, it makes a royal mess all over the floor.
If the fill tube flange is not damaged (just knocked out) you can reinstall it. but if it's cut at all, replace it...
The out of balance could have been from overfilling as well.
Hope that helps you .
K
Jul 02, 2009 | Maytag Washing Machines
Whirlpool Washer LSQ9645KQ0
The washer has the sound both times but not all the time. I THINK we found all the pieces but now that you mentioned it, perhaps not. Are you thinking there may be a piece lodged somewhere and making that noise?
di_marie60
Aug 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer out of balance ALL THE TIME...
Remove front panel and check the springs that hold the bowl down onto the base. One of them may be broken or detached. On the base, the bowl assembly fits into a plastic collar. This collar may be worn, causing the machine to go out of balance. My guess is that the collar is worn or broken. You should be able to see plastic "dust" or pices on the base or the floor under the machine.
Nov 09, 2007 | GE WPGT9360EPL Top Load Washer
Running water
Sounds like your stand-pipe has fell over,located behind machine that the drain hose goes into.This pipe must be vertical,and secure.The top of the washers drain hose loop that goes into the stand-pipe, should be as high as your soap dispenser.If this is not the problem then your water pump must be pumping the water out all the time.Can you hear the pump? If so, some faults can force the washing machine into a constant cycle of filling with cold water and pumping the water away if it thinks the washing machine is overheating (possible faulty thermistor).Hopefully its only your stand-pipe causing the loss of water.Lets know how you get on.Good luck.
Sep 05, 2007 | LG WFT1071TP Top Load Washer
Washing Machines Logo
188 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
