Question about Refrigerators
Antares vending machine
Unit wont turn off and will froze the coil
    Champion:
    Habit-Forming:
  • 279 Answers
Change the thermostat, that's what regulates the compressor.
Posted on Nov 29, 2013
4 Suggested Answers
22yooper
  • 828 Answers
SOURCE: Vending machine issues
Only the fan at the compressor turns on and off with the compressor cycle. The evaporator fan runs steady to maintain air circulation and temperature balance and to affect evaporator defrost in the off cycle. Sometimes the condenser fan will run continuously to assist in the evaporation of condensed moisture from the evaporator drainage.
Posted on May 30, 2008
  • 4 Answers
SOURCE: I have the same problem
You need to contact Frigidaire Parts Division. You need an evaporator for their EDINA Model FMR7. The part number is 216701200. It should cost approx. $100.00. This should be all you need. Good luck.
David
Posted on Mar 09, 2010
Testimonial: "Thank You!"
SOURCE: I have an older Antares vending machine that is
replace with new evaporator coil pn.216701200
Posted on Feb 07, 2011
My sega vending machine releases three cans of pop at once ?
The can spiral coil may not be centered in the slots on the driver.(I had a bent prong on the driver once that caused double vending even though the coil was centered) Or the anti-reverse dog is not engaging properly(if the knob can be turned counterclockwise)
You will have to open the mechanism panel and inspect visually.
Sep 02, 2015 | Retail Supplies
Tip
Vending Machine Supplier
About Us : <br>Upton vending A largest vending machines company in UK, that provides wide range of vending machines in North Yorkshire at affordable rates,well known for customer satisfaction.Our best services are <b><a href="http://www.uptonvending.co.uk">vending machine companies</a></b>,vending machine, snack vending machine, drink vending machine,commercial coffee machines in UK..<br>Contact Us : <br>The Vivars<br>Selby<br>North Yorkshire<br>YO8 8BE<br>Tel: 0 1757 629112<br>Fax: 01757 294600
on Aug 17, 2013 | Nu-Dell Manufacturing Vending Machines Ad...
Rowe 4900 snack machine vend motor good won't vend selection
Is it just that selection, or is it the entire shelf? If you've got a voltmeter check the lines in to see that it's actually feeding power to the motor, as it could be loose/misconfigured wiring. If that doesn't work, and it's possible, try using a known functional motor in that selection. If it works, you've got a bad motor to replace, if it doesn't work it might go back to the main board. I'm not terribly familiar with Rowe equipment, but with most snack units it's just a matter of switching things around until you've found the bad part or other problem- good luck!
Nov 05, 2013 | vendors equipment Rowe 4900 Vend Motor for...
I have an Antaris vending machine that has a frigidare cooling system. It was manufactured in 2006 and has been working fine. Recently the motor kicks on but the cooling system does not and it does not...
the antares is notorious for having evaporator problems. The evaporator is not galvanized and as such rusts after a period of time. Once rusted through the coolant is released. The machine will no longer get cold until the evaporator is replaced and the sytstem charged with coolant... gene
Aug 24, 2010 | Frigidaire Refrigerators
I have the same problem with my Antares vending machine. Do you know what the model number is on that Frigidaire freezer? I want to buy a new evaporator but can't seem to find it.
David
Mar 08, 2010 | Refrigerators
My Edina cold soda vending machine which was made by Frigidare is not getting cold. The previous owner (my neighbor who I trust) said it had always worked fine. It had been in his garage, unplugged, for...
I have some of those machines. What happens to them is that the evaporators, which are made out of steel, rust out in approx. 7 years. This allows the R134A to leak out. If you can peek back through to the back wall, you will see where the rust has run down. The solution is to order a new evaporator from Frigidaire at around $100.00 and get someone to change this out and recharge the unit. Before turning it over to the mechanic, you may want to remove the vending module which includes the inner doors and plastic shelves. This can be done in 15 minutes and makes the job easier for the mechanic which can save you money. You should end up with less than $300.00 for the total cost of the repair, but since these machines are rather popular, they can be had on ebay fairly cheap. Sometimes you can pick up new machines for five or six hundred dollars. These are the same as the Antares machines which are made by Edina. I hope this helps.
Jun 18, 2009 | Electrolux Refrigerators
May 30, 2008 | Koolatron (785169015699)
Skybox not cooling
you can not add coils but place a fan on it to help remove the heat faster by lowering the condenser temps
Jan 23, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Refrigerators Logo
94 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
