Question about Cub Cadet Street Sign- tractor lawn riding mower parts
My cub cadet zero turn mower won't engage the blades with the switch.
  • superxl May 16, 2009
    My cub Cadet Zforce 50 has a similar problem - the mower only engages when I am in reverse. Same issue?
  • wyoming wonder May 07, 2014
    mine just did the same thing, the last of my problems was the belt. two days ago i tried to pull the pto button and it wouldnt work, at the back of the zero turn, under neath but the bar there is a round pully thing, on the back there is like a tab and if that tab is not in the pully will lock and wont let the zero turn pto button work. i had to all the lawnmower repair guy out to fix it but i watched what he did. he just tapped the tab down and now it works and goes into third gear.
I have a cub cadet zero turn z force 48 yesterday i was cutting lawn and i heard a clink, the mower stopped, i was ablet o start the mower again but when i pulled the pto knob to engage the blades the mower turns off by its self, when the pto lever is pulled up i can restart the mower what is causing this and how do i fix it
Posted on Apr 10, 2012
I have a cub cadet zero turn 50' mower, i start mowing and after about 10 minutes it starts running out of gas, i pull out the choke to keep it going but it just keeps getting worse to the point of quitting. If i slow it down to a idle or just a little more it will stay running but that is not fast enough to cut the grass. does anybody out there know why i am runnung out of gas. I put a new filter on it, It did not help.
Posted on Jun 20, 2009
  • 10,865 Answers
The cub cadet is a great machine and it is sophisticated as mowers go. the blades are controlled by a vacuum controlled by a part called a vacuum actuator. Most likely this part has gone bad and will need to be replaced.
Posted on May 09, 2009
My cub cadet ZTR M60, under the mower in the rear is 2 wires going to the electric clutch my wire fell and the belt cut one of them. I spliced it and it was good to go. Signed:Acorn tractor
Posted on Jun 05, 2009
    New Friend:
There are 4 relay switches ( had the same problem) 2 were bad. call dealer order switches and change them
Posted on Jan 13, 2013
2 Suggested Answers
  • 109 Answers
SOURCE: Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
Posted on Jun 29, 2009
Cluch on mower doesn't turn blades when pto switch is turned on what do I look for
Craftsman Mower deck (clutch) Won't engage - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Jul 1, 2006 - I can push in the PTO switch to disengage the clutch and blades and the tractor starts fine and runs. But as ... If it doesn't lock up, look further into the deck...... Hi I hope somebody can help , I have a craftsman zero turn mower. PTO switch bypass????
Sep 4, 2010
Craftsman Lawn Mower Dies after a few seconds
Jan 31, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
More results from forums2.gardenweb.com
Sep 25, 2015 | Cub Cadet Garden
Why aren't the blades engaging all the time?
Faulty connection or partially broken wire, from ignition to blade engage switch or from engage switch to electric clutch.
Aug 07, 2015 | Cub Cadet RZT L50 50" 23HP Zero Turn Mower...
M60 cub cadet zero turn. What causes it to shut off?
There is also a safety switch for each of control arms, they both have to be in the neutral position. You may have to adjust the arms.
Are you checking the resistance at the switches?
Jul 09, 2015 | Cub Cadet Garden
After reverse, my cub cadet zero turn mower pto will not re engage the blades. sporadic up to the point of stopping altogether. is it the switch or clutch?
I would guess it is the switch. My Cub Cadet has a safety feature where the blades (PTO) stop when you hit reverse. There is an override where you turn the key back about a quarter turn or so and hit a button right above the key to make the blades run even in reverse. Therefore, I would guess the ignition switch is the problem but I can't be certain. Or it could be the electric switch that engages the PTO.
Aug 10, 2014 | Cub Cadet Garden
I HAVE A CUB CADET 50 INCH CUT ZERO TURN, WHEN YOU PULL THE PTO SWITCH TO ENGAGE THE BLADES THE BATTERY WILL DISCHARGE.
Most likely a short. You have to look in the area where engage switch gets blades going. You will find a cut wire or wires that are touching metal. This will kill a battery very quick. Fix wire , tie up wire so this doesn't happen again, and off you go. GOOD LUCK.
Jun 16, 2011 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet zero turn. Cannot get the blades to turn when PTO switch is pulled. Belts are fine and attached. Please help. John
i had the same problem. there was a short in the relay just before the wire gets to to back pulley assembly.
Apr 28, 2011 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
Cub cadet rzt 50, hit stump, blades wont engage but not bent
The blades on this cub cadet are activated with air pressure. Chances are that when you hit that stump, you either blew a fuse or the control module that allows the blades to spin. Begin by checking the fuses. J.
May 28, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
Jun 25, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
10,741 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
