Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Ge profile pfs22sisbss
Seemed warm so i cleaned back when i pluged it in its dead, all i can hear is a control relay pulsing 1 sec on 1sec off
mikedurland
  • 481 Answers
SOURCE: I have a GE Profile
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Posted on Jul 01, 2008
ngfam1
  • 639 Answers
SOURCE: How do I obtain a manual?
Dear FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
HERE IS THE SITE FOR THE MANUAL OF YOUR FRIDGE AND MODEL #
http://www.geappliances.com/service_and_support/literature/
Thank You
Bless you,ngfam1
PS.PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OUT!
Posted on Aug 26, 2008
  • 74 Answers
SOURCE: I have a GE Profile,model PFS22SISBSS,3 years
Possible main pcb failure failure which would cause everything to cut out and restart . Is the compressor or back of the appliance hot ?? Do all the control lights go out when the compressor cuts out ??
Posted on Feb 26, 2009
  • 2328 Answers
SOURCE: GE profile PFS22SISBSS running hot and making a
the computer board is bad part number WR55X10942,it's on the back outside wall of the machine
Posted on Oct 20, 2010
heatman101
  • 43501 Answers
SOURCE: My ge profile PFS22SISBSS FRIDE IS NOT STAYING
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 22, 2010
Profile GE PS123Sc about 6-7 yrs old. Freezer side seems fine. Fridge side is too warm, but is cooling (about 40F). Fridge side lights are intermittent and control panel at top is intermittently dark or...
Sounds like a bad motherboard and probley need control board. You can put in self dianoss. Press all the buttons on panel for 5 seconds. This will start the program. It will check all sensors. Come back with codes and I will help you. Wait to hear from you. I hopes this helps. david_gra582
Aug 27, 2011 | GE Profile PSS26NGS Side by Side...
GE profile PFS22SISBSS running hot and making a clicking noise for several days
Oct 20, 2010 | GE Profile PSW26P Stainless Steel Side by...
GE French door profile freezer is not freezing
Call the service company back and make them fix the problem, period. If they said that would fix it then they just bought the repair no matter how much it costs.
Jul 03, 2017 | GE Profile Bottom-Freezer Refrigerator...
Slow compressor fan
You need to remove the fan and test it somewhere different. The compressor is in need of the condenser fan. Everything will overheat without that fan working. You should also test the power at that pin plug. Let me know what you find. Sea Breeze
Jul 22, 2009 | GE Energy Star SDL20KCSBS Bottom Freezer...
Temp light does not light up and temp does not get cold. inside door latch is broken model #pfs22sisbss
The main control board could solve the display problem . May also solve the cooling problem , but would need to know , if frost build up on back wall inside freezer , are both fans working (freezer and compressor cooling fan) , is the compressor running ,are the coils clean in back of refrig ? Unsure about a "door latch" . The freezer door ,rides on glides , and the magnetic gasket should hold it closed .
Jul 22, 2009 | GE Profile PSW26P Stainless Steel Side by...
Feb 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge not working.
not sure if that model has it but if it does have a control board it will be on the back of the you will see a panel with several screws in it the relay on it is stuck need to change the control board But if it dont have a control board on it then change your relay on your compressor if you need anything else let me know and please rate me
Jan 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Cordless telephone sw/from pulse to tone
In General Electric (GE):
TONE/PULSE DIALING
To set to tone or pulse dialing:
1. Press and hold the program button for two seconds. You will hear a beep.
2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing.
3. Press the program button again. You will hear a confirmation tone.
Nov 25, 2007 | GEH5450 Cordless Phone
Whirlpool AFG 7080 Freezer - Relay noises
It sure sounds like you have a problem with the board. It may just be a dry joint or a faulty component. Normally one would replace the board.
Nov 01, 2007 | Freezers
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
137 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
