Question about Crane Plumbing Home
Want knobs and water spout in chrome finish for an early 1970s crane bathtub where the surface that the hardware rests on is at a 45 degree angle
SOURCE: Bathtub water won't shut off
Did you solder close to the valve. you may have melted or damaged you cartrage inside. shut water off and replace it.
Posted on Dec 19, 2008
  • 653 Answers
SOURCE: Water coming from showerhead and bath spout at same time
Have whoever installed the shower set come back and fix the diverter. It should be a relatively simple adjustment.
Posted on Mar 15, 2009
  • 297 Answers
SOURCE: Diverter valve does not work correctly.
the connections are reversed,just change them over and this will fix the problem.
Posted on Jul 26, 2009
  • 5 Answers
SOURCE: how to cut a 45 degree angle on wood using a jig
use a combination sliding square to mark ecxactly where you want to cut. Measure the distance from the jig-saw blade to the edge of the jig-saw bottom plate. Use this distance to mark another line parralel to the first line. Nail or screew a straight piece of wood on the second line. Put the jig-saw plate against the wood fence and cut your perfect line.
Posted on Mar 17, 2010
  • 16 Answers
SOURCE: Delta shower faucet loses pressure when turned all
Turn off the water to the home. You need tthe stem beneath the handle. Remove the handle after locating the set screw, remove the cylindrical beauty cover, and unthread the retaining nut to access the valve stem. Take it to a plumbing supply house or home store to make certain of the match.
Posted on Oct 07, 2010
How do I fix a shower when the pull-up on the incoming water spout will not redirect the water to the shower head?
You'll probably have to replace the bathtub spout. Here is a cut away view of a typical bathtub spout with the water redirect.
http://cdn1.tmbi.com/TFH/Step-By-Step/FH06FEB_BATHSP_03.jpg
Nov 19, 2016 | Home
When the water is turned on the water come out the tub spout and shower head at the same time.
there is a diverter valve that may be stuck, it's usually a knob on the spout, but it may be elsewhere. jiggle it back and forth
May 23, 2014 | Home
A CRANE WHIRLPOOL TUB BOUGHT FROM MENARD'S IN THE 1990'S HAS TWO CONTROL KNOBS FOR AIR AS WELL AS AN ON/OFF BUTTON. WHERE CAN I FIND A REPLACEMENT SEAT THAT THE AIR CONTROL KNOB SCREWS INTO A
What you are looking for is called the wall fitting for the air control knob.
If you can email me a picture of the knob, topside and underside I can tell you who made it and if there are parts for it.
send your pictures to: sales@uspartscenter.com
Rod
US Parts Center
888-521-6183
Feb 10, 2013 | Crane & Co Crane Plumbing 2430W Whirlpool...
I have a delta 1400 series bath/shower and for the life of me, I can't figure out how to get the shower to work. I turn the knob to the left to adjust the temperature. However, I don't have an...
I had the same problem. My building manager showed me that you have to yank the circular portion at the end the of spout where the water comes out downward and the water will be diverted to the showerhead.
Aug 29, 2011 | Delta T13420 Chrome Classic Single Handle...
Hi, I also bought my Bull Shark Kreepy Krauly recently - 3 months ago. Since day 1 it liftes up at the end and does not move flat on the surface of the swimming pool. Please assist.
First, check for debris in the pool cleaners flapper. This can cause a lack of suction the floor. Also, check for proper hose balance. If the hose rests at a greater than 45 degree angle, the hose is too light and you need to move the hose weights closer to the cleaner. If the hose rests at a less than 45 degree angle, you need to move the weights away from the cleaner.
Feb 11, 2011 | Universal Kreepy Krauly In-Ground Pool...
My kreppy crawly turns side ways and dosent correct its self
With this brand of pool cleaners, that is almost always going to be a problem with your hose balance. Turn your pump off and observe your Kreepy Krauly. The seal should rest flat on the pool surface and the hose and tubes should be at a 45 degree angle. Adjust hose weights (as follows) one inch at a time until you get the proper balance. If you have a deep and shallow end, adjust to the deep end first.
The hose is too light if it raises toward the surface at a greater than 45 degree angle. Move the weights closere to the cleaner (one inch at a time). If the cleaner is closer to the pool floor, move the weights away from the cleaner.
Nov 05, 2010 | Universal Kreepy Krauly In-Ground Pool...
Delta shower faucet loses pressure when turned all the way on (hot water). What could cause this? When it first happened yesterday, a few tiny pieces of black plastic/rubber fell out of the bathtub...
Oct 06, 2010 | Delta & Single Handle Shower Faucet
My kreepy won't move about. Even though the hose is vibrating, it doesn't move about. I just bought new hose so that isn't the problem. I have an 18x36 inground pool. Where should the ring weights be...
With these pool cleaners, there is a simple test you can do to see if your cleaner is weighted correctly. Turn the pump off and observe. The hose balance is correct when the cleaner's seal rests flat on the pool floor and the drive tube makes a 45 degree angle with the floor. Adjust the hose weights one inch at a time as needed until the proper balance is achieved. If the hose is too light, or rises toward the furface at an angle greater than 45 degrees, move the weights closer to the cleaner or move the first two weights closer to each other. If the hose is too heavy, less than 45 degree angle, move the weights away from each other.
Jun 08, 2010 | Universal Kreepy Krauly In-Ground Pool...
Krauly gets tangled in the hose constantly and will not untangle
With these pool cleaners, that is almost always going to be a problem with your hose balance. To determine if your balance is correct, turn off the pump and observe the cleaner. Hose balance is correct if the cleaner's seal rests flat on the pool floor and drive tubes make a 45 degree angle with the floor. If the hose rises toward the surface at an angle greater than 45 degrees, move the weights closer to the cleaner or move the first two weights closer to each other. If the hose sags at less than a 45 degree angle, move the weights away from the Kreepy Krauly or separate the first two weights away from each other.
May 16, 2010 | Universal Kreepy Krauly In-Ground Pool...
My 3 handle bathtub fauset [price pfisher] cycles hot and cold
You will need to either replace center "shower diverter"assembly or a quicker fix would be to remove old tub water fill spout and replace with a "pull up diverter knob" type water spout. Cost about 10 dollars Hdepot Pull Knob to divert water to shower when showering.
jthomefix
Mar 15, 2009 | Price Pfister Ashfield Widespread Bathroom...
Home Logo
57 people viewed this question
Top Crane Plumbing Home Experts
Donni Steen
john h
Tom Chichester
Are you a Crane Plumbing Home Expert? Answer questions, earn points and help others
