Question about Vapor Blunt 2.0
Charger won't charge - Vapor Blunt 2.0
Ds lite charger
Make sure the charger and the charge port are both connecting tightly and nothing is loos. Try moving around the charger and see if its charges
May 31, 2013 | Video Game Consoles & Games
My blueant s4 won't charge
It must be a battery problem as the battery indicator level says full when you remove it from the charger and the phone doesnt work.
Mar 19, 2013 | Blueant Ant S4 Handsfree Voice Controlled...
Asus charger won't charge
Stop using that charger. I sounds like you have a break in the wire and when you hold it in the right position, the two pieces touch and current flows. Unfortunately the heat is probably being caused by arcing and is a potential fire hazard.
Apr 06, 2017 | ASUS Original 19v 3.42a Ac Adapter Charger...
Dell inspiron M5030 won't charge, green light is
This is a common problem. It may be that the charger is dammaged. these Dell chargers have a micro thin communication cable in them that tell the charger to charge the battery. this micro thin cable can often break. Its use it to prevent the laptop battery from over charging, but if it breaks or becomed broken inside tha charger cable, then the laptop simply won't get the charge signal and the battery won't charge. If this is the case, then you will need to replace the charger with another Dell charger compatible with your laptop
Dec 23, 2012 | Computers & Internet
My olympus vg-130 won't turn on or charge
Try this, it worked for me:-
Obtain a desktop style charger for the LI 70B battery and charge it separately from the camera. I got a charger at very low cost on eBay. I THINK that the original camera plus original charger won't cope with deeply discharged batteries. I also suggest making sure that the Auto-Power-Down is also switched ON in future. Good Luck.
Oct 21, 2011 | Cameras
Battery won't charge
connect the charger to the socket, then connect the charger to your laptop. if it does not charge remove it for 5mins, connect the charger back. it will work now. sometimes when the battery is fully charged and you remove the charger and connect it back it may not charge until the battery is low;lets say 99%.
Sep 23, 2011 | Advent 4211c Notebook
Batteries r not charging What could be the problem and could it be repaired
Hello
First, make sure your batteries are rechargeable. But even rechargeable batteries have a lifespan, try charging it into another charger. If it is charging on another charger, then that means your charger is faulty. If it won't charge on another charger, then the batteries are dead, and you need to buy new set of batteries.
Sep 08, 2011 | Nintendo Video Game Consoles & Games
My SCH-a930 won't charge. I still have battery life, and the phone works fine, but the phone won't charge. I have tried multiple wall outlets. Does anyone know how to fix this? Thanks!
Please, try using another charger with the phone.
If the problem continues, get a screw driver, unscrew the phone and bring the charging port out. The charging port is at the tail end of the phone.
Clean the surface of the panel where the charging port contact the panel with a spirit and allow it to dry for 30 minute. Couple back the phone and i am sure the charging phone will work fine.
Regards
Jun 28, 2011 | Samsung SCH-a930 Cellular Phone
My hp compaq turned off by itself and won't turn on now, it won't even show the charging light when the charger is plugged in
Remove the PC labtop battery then re insert it again.
If still not charging check the charger connector if its connected as well.
If there was no problem in the charger connector,Check the charger itself.
These all what you need to check only,no problem in your labtop.
If still not charging means one of these :
1- The BATTERY may needs to be changed .
or
2- The charger may needs to be changed.
Jun 13, 2011 | HP Compaq 6720s Notebook
Vapor Blunt 2.0 Logo
83 people viewed this question
Top Vapor Blunt Clothing Experts
ray gallant
Da Doc
Are you a Vapor Blunt Clothing Expert? Answer questions, earn points and help others
