Question about Akai LCT3201TD 32 in. LCD Television
Broken switch borad broken can i use my remote to utilize my tv
Search Fixya...lg remote not working on direct tv
replace batteries --if not still working possible circuit board damaged ===cheaper to replace then repair
Jun 16, 2017 | LG Televison & Video
Yamaha cp33 has no volume when key is pressed
One key? or all keys?
if one key- the switch contacts for that one key are where to look for dirt, corrosion or broken wires.
If one octave- check wires and connections on the borad that set of wires lead to, and look for bad solder joints or bulging capacitors, or evidence of a spilled beverage.
If all keys, Check to make sure the mute button is not pressed. and volume level is up, and see if headphones will work with it. If you are using headphones- try a different pair first, you may have a broken wire in the headphones Then check the wiring inside, especially the wire for common buss connection. Also check the amplifier for funtionality. This is simply done by pressing a screwdriver in contact with the amplifier input, you should hear a buzz out of the speakers of the keyboard or through the headphones. The amplifier borad is the one with wires to the headphone jack and speakers.
Oct 27, 2012 | Williams Encore Digital Piano
What type of connection do I need to be able to connect an ariel to the Acer Aspire Z5700 PC Desktop to use the on borad tv tuner and where can I purchase it?
to use the on board tv tuner you just need to add the tv cable to the tuner ..and after that scan the signal with the program for the tv tuner..and fix the channels..
basically the tv tuner transforms a monitor into a tv ..but it is operated from the special program for it ..and it has all functions like a normal tv ..After tuning the channels and all you can operate it from the remote ..most tv tuners have one ..
Sep 25, 2011 | Acer Aspire Z5700 PC Desktop
LG RI32CZ10RX, switch to AV with no remote?
usually the code for a phillips tv will operate lg tv's
Mar 17, 2010 | Televison & Video
Broken remote How do i switch between Aloge and digital Channles
I called FUNAI CORPORATION
Customer Service
Tel :1-800-605-8453
http://www.funai-corp.com
I was told the only way to get it back to digital was to order a replacement remote. They told me there is no universal remote that will put the tv back to digital. If you want to order a new remote call the number above and choose option 4.
Aug 20, 2009 | iLO IWT3206 TV
Remote wont change to vid1, vid2 please help
The GE universal remote #24914 works to change your Ilo tv from analog to digital and switch to vid1 or vid2 ect.... The code is in the book that comes with the remote. I use this remote myself. This remote can be bought at Target for under $10.
May 21, 2009 | iLO IWT3206 TV
Magnavox TV remote broken - won't switch to watch DVD
There may be a manual reset button somewhere on the back of the set. If not, try unplugging it for 10 minutes and then plugging it back in. If that doesn't work, call Magnavox.
Apr 11, 2017 | Televison & Video
Akai LCT3201TD 32 in. LCD Television Logo
12 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
