Question about Electrolux Washing Machines
No power washing machine type ewt 705 - Electrolux Washing Machines
5 Suggested Answers
  • 123 Answers
SOURCE: Need Manual for Electrolux EWT 13420 W - EWT 10420
These site carries the full line of Electrolux Manuals
http://userguides.50webs.com/manual.htm
Posted on Sep 06, 2009
blueextc3221
  • 15935 Answers
SOURCE: simpson 705 washing machine shakes on spin dry
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
IF THIS IS A BRAND NEW INSTALLATION - be sure you hav removed the basket shipping pins (4) that secure the tub during shipping.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 15, 2010
  • 6277 Answers
SOURCE: electrolux washing machine ewt 1330
(no promises but try this!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 13, 2011
SOURCE: Hi, My electrolux EWT 959
Hi Donna,
I just wondering have you solved the problems? as I have a similar problems in the same washing machine model. Please advse if you've solved the problems and how
Thanks
Posted on Oct 06, 2011
My EWT 959 starts to fill then after about 20 seconds stops and does nothing. After a while it says turn on taps. Is there filters we can check and clean which may be confusing the machine?
Hi,first has some one turnd the water supply off for the washing machine,there are usally little filters that are where the water supply hosses connect to the back of the machine,hope this was some help all the best.
Mar 05, 2016 | Electrolux Washing Machines
Electrolux ewt 115
Hi Cong Tran.
To buy parts for your machine you should go the the manufacturers distributor with the full model number. (The shop where you bought the machine may be able to help you with that information) The parts shop can easily tell you cost and availability of the part.
Good Luck
Cheers
Nomess
Jan 03, 2015 | Electrolux Washing Machines
E4 error code on electrolux washing machine ewt 854s
E4 is the pump is blocked {not running} pehaps a hair pin or clothing wires get stuck
fully drain it and take the filter out
and clean it
these error codes are similar to candy
youll get an idea from this video
https://www.youtube.com/watch?v=kzhlvB2LjXg
Nov 28, 2014 | Electrolux EW1000i Front Load Washer
Electrolux washing machine ewt goes straight to drain
Check your drain hose. It may be too far into the drain pipe. 6 to 8 inches max
Sep 24, 2014 | Washing Machines
Ewt 905 manual
my ewt 905 couldn't start at all when i switch on power. but i tried my other devices on that paticular socket and it works.
Jan 18, 2014 | Electrolux Washing Machines
Electrolux ewt 10410W
HEATING ELEMENT RELAY FAULT... THAT'S ERROR CODE ON YOUR MACHINE
Dec 27, 2013 | Washing Machines
Electrolux ewt 905 has no power suppy
Hey i will help you. You need to test it with a multimeter and see if you are getting 120 volts at the control board. If you are getting voltage at the control board i would replace the control board. If you don't have any voltage at the board you need to follow where the power cord comes into the machine and start testing stuff and see where you are loosing the power. It sounds like a loose connection or a bad control board. Test a few things with a multimeter and reply back to me.
Aug 30, 2013 | Washing Machines
Hi, My electrolux EWT 959 washing machine keeps saying please close the lid when the lid is closed. The machine filled up full of water before saying this & now wont finish the wash. Are you able to...
Hi Donna,
Thanks
Nov 14, 2010 | Washing Machines
Washing Machines Logo
23 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
