Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
Blowing eng 1 fuse when trying to start
40amp fuse
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 28 Answers
There is a very good chance that you have a short from your starter motor .
If you are able to dis assemble , then do so and you may find that the wire attached to the bushes ( carbon brushes ) have become detached and eartnig on the case )
OPTIONS . get new brushes .
get exchange recon unit
get new unit
unlikely but possible the power cable to the starter has come loose and shorting too nearest earth .
Do not do any elcetrical work on the car without disconnecting earth lead on th e battery .
Posted on Nov 30, 2013
Why doesn't it start?
What was the fuse for? Sounds like wire chafing.
Jan 30, 2016 | 2005 Mazda Tribute
Chevy express 1500 20amp eng 1fuse keeps blowing ?why
what does it drive - search for some shortcut/ burnt device, wear on cable insulation through 20 amps do not blow without reason. Maybe badly connected engine mass connection - check battery connections to start with
Apr 18, 2014 | Cars & Trucks
Interier fuse keeps blowing on start
It will be a dead short causing the fuse to blow. It could be in the starter motor or associated solenoid. Or in the glow plug relay circuit. Disconnect the glow plugs from the power wire to ensure they are not causing it, they probably wont be. N try to find the relay that operates them and un plug that. It will become a process of elimination. I hope that helps
Mar 04, 2014 | Mitsubishi Pajero Cars & Trucks
2002 tahoe blowing 40amp large fuses in fuse block under the hood
You have a short in that wiring, most likely related to your starting motor. Pull the starter relay (in the underhood fuse box) and try a new fuse to see if that is the case. If so you will need to have the motor checked. If not, there are a variety of systems that use this feed via the ignition switch and each will have to be checked (including the switch). If you need a wiring diagram, try Alldatadiy.com.
Feb 01, 2018 | Chevrolet Cars & Trucks
We have a 40amp hot wired stove but now we just bought a frigidaire fef366dce with a 50amp. Will the new stove work well if hot wired to the 40amp
The new stove may work but you may also blow the breaker/ fuse which ever you have... make sure to leave the 40 amp fuses or breaker in the box as the wiring will not be heavy enough to support a larger amp. fuse or breaker... that will start a fire!
You may find that you just cannot run all of the burners and the oven or broiler at the same time.
heatman101
Apr 19, 2011 | Frigidaire FEF336BC Electric Kitchen Range
2001 nissan maxima se keeps blowing the ecm 1 fuse
Did you find the prolbem? Im having the exact same problem you have. Mine is doing it after it died and I replaced the starter but now it wont start and the fuse eng cont 1 keeps getting burned out instantly
Jun 25, 2010 | 2001 Nissan Maxima
Power/ Ground Problem. Im running a 6ga Power wire to the battery (approx 6')with a 40amp fuse. The amp turns on, then about 10 seconds later blows the fuse. The ground is the same ga wire and is grounded...
1. Start by undoing your ground.
2. Use a jumper cable to hook up the ground to the battery ground.
3. Install fuse and test.
If it continues to blow you have an internal amp problem.
If it fails to blow a fuse you have a problem with the chassis ground.
If it is a ground issue you can chase down the various ground straps and clean the connections or you can run another ground cable to the chassis (body) ground to the battery to reestablish the connection.
Feb 10, 2010 | Rockford Fosgate Punch 201S Car Audio...
Fuse keeps popping - 20A ENG CONT 1
Before replacing fuses try disconnecting neg battery lead first. If still blows look loose wire under motor
Dec 14, 2017 | 2000 Nissan Maxima
04 Tahoe blowing fusible link in fuse box for starter
HI...
ON the fuse box cover.
IS there a especification for the funtion of the fuse. or the number of the location of the fuse.
If you can give me, I can try help you. as more I can.
Thank you for use fixya.
Jul 24, 2008 | 2004 Chevrolet Tahoe
40amp fuse blows
Measure the DC voltage across the B+ and ground terminals as well as across remote and ground. If you have less than 11 volts when the amp tries to power up, the amp could be shutting down due to low voltage.
If the voltage remains near or above 12v, disconnect all speaker wires and signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down or blows the fuse when you apply remote voltage (turn the head unit on), the amp likely has blown output transistors.
Nov 24, 2007 | Rockford Fosgate P3001 Car Audio Amplifier
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
85 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
