Question about Sharp Aquos LC-46D62U 46 in. LCD HDTV
I recently lost a couple of digital stations and when I press Menu then scroll across to Options I find the DTV Menu option grayed out which I need to auto tune the digital stations in. Called Sharp but they referred me a a service centre. Called the service centre and they told me I need to replace the digital board which would cost nearly half as much as the tv is worth. Do I have any other option or should I junk the tv which is only 4 years old.
  • Marko Slywa
    Marko Slywa Nov 28, 2013
    Thanks for the advice. Have reset the tv to factory settings but no luck. Have had no changes to cable service. However, have had a thought that perhaps all i need to do is connect a digital set top box to the tv as though treating the tv like an analog which effectively it is. This would bypass the defective digital card in the tv. Hmmm
    Problem Solver:
  • 5 Answers
I doubt they\'d be able to properly assess the problem without physically checking the tv. That being said, I know for a fact that Sharp has a VERY HIGH return rate for their flat screen televisions for any number of problems. Try resetting or restoring the tv to factory settings and see if that helps. Have you recently changed or upgraded the kind of cable service you are receiving? Do you have cable or satellite at all? Just trying to get a better idea of the situation.
Posted on Nov 28, 2013
sspsychotic
  • 77 Answers
SOURCE: Large red bar lower half of tv sharp aquos 52" 2.5 yrs old
some parts inside your tv is damage or short circuited. too expensive to fix or replace
Posted on Sep 08, 2009
SOURCE: Auto Tuning Channels on LC20B2MA Aquos TV
 Automatically tunes in and preset
receivable TV stations.
Make sure the antenna cable is
properly connected.
1 Press MENU (PRESET-1) on the
upper part of the LCD TV set for
more than two seconds. The
AUTO mode screen appears.
2 Press VOL (–)/(+) (PRESET-2)
on the upper part of the LCD TV
set.
All the TV stations in your area
that can be received by the LCD
TV set are automatically preset.
3 The screen shows whatever is on
channel 1 when full auto channel
preset is finished.
Posted on Oct 09, 2009
SOURCE: I need to do a
During power up and first time use, there should have been an option for channel scanning as the initial setup wizard began.
Alternatively, there should be a way to navigate to the channel scanning menu by selecting, Menu>TV>Auto Channel Search. I couldn't get the exact info from the model you listed, but I gathered this info from a similar owner's manual (lc-32sb28ut) from the Sharp webpage: http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx
Hope this helps.
Posted on Oct 18, 2010
joeguest2
  • 2080 Answers
SOURCE: i have a two year old sharp lc32d44e tv and have
Try downloading the manual at the following link:
http://www.sharp.ca/manuals/default2.asp
I saw manual for LC32D44U in english or french which should be close enough.
Good luck and post back if this helps.
Posted on Jan 28, 2011
  • 4 Answers
SOURCE: Freeview channels (DTV) on a Sharp Aquos TV
On my Aquos it's saying no carrier and database empty what do I do, I have trying to reset TV but free view isn't coming on and it's saying carrier 0.
can anyone help
Posted on Mar 31, 2011
The digital switchover is today.I have contacted the national helpline who advise choose menu and then choose install which I cannot locate. Can you please advise the steps I need to take. We have lost...
If your TV is not in Digital it won't give you the tuning option.
Select DTV from the on screen menu, (like scart 1 scart 2 etc). When you have found DTV select it and then press menu for tuning.
Hope that helps.
Mar 30, 2011 | Televison & Video
I am trying to tune my Toshiba 26WLT66 analogue channels but can't get it out of DTV mode. I know this can be changed because I put it into DTV mode at our other house - I have since mislaid the owner's...
Hi there not sure if you have resolved this yet but I had same problem and managed to resolve it by chance.
If you press and hold the source button (arrow pointing to the centre of a circle) this will give you all your source options down the left hand side, including analogue.
Scroll down to ATV and select then tune using menu options.
Hope this helps
Mar 12, 2011 | Toshiba 26WLT66 26 in. LCD Television
How do I manually/automatically update the channels on my Samsung DNli DV3 TV?
Hi Hugh.
Please follow these instructions to manually/automatically update the digital (DTV) channels on the Samsung LE26R73BD.
Please use the following buttons on your Samsung remote control to navigate the on-screen menus:
- "D.MENU" - Opens/closes the on-screen menu (below the numerical key "0")
- DIRECTIONAL ARROW KEYS - To navigate up/down/left right through the on-screen menus
- "ENTER/OK" - Selects/confirms a selected option (in the centre of the arrows)
Automatic Channel Scan / Update:
1. Make sure you are in digital TV mode - Press the "TV/DTV" button on the remote to switch between analogue (ATV) and digital (DTV) modes.
2. Press the "D.MENU" key
3. Highlight "Installation" (first option) and press "OK/ENTER"
4. If asked for a PIN code, enter 0 0 0 0 using the numerical keys on the remote. If you have set a different PIN code, please enter your own code here.
5. Highlight "Select County" and press "OK/ENTER"
6. Use the LEFT/RIGHT arrows to select "UK" then press "OK/ENTER"
7. Highlight "Auto Scanning" and press "ENTER/OK"
8. Highlight "Scan Mode" and use the LEFT/RIGHT arrows to set the value to "Digital"
9. Highlight "Start Frequency" and use the LEFT/RIGHT arrows to set the value to "CH 21 . . ."
10. Highlight "End Frequency" and use the LEFT/RIGHT arrows to set the value to "CH 69 . . ."
11. Highlight "Start Frequency" again and then press "OK/ENTER" to start the channel scan.
Some of the options above will already be selected so will not need to be changed. I've provided the correct settings just in case they are incorrectly set. Note: UK Freeview stations are on channels 21 to 69 inclusive.
The scan will take a few minutes to complete and the progress will be displayed. When the channel scan is complete, the menu should close automatically and the TV will return to viewing mode. If not, press either the "D.MENU" or "EXIT" button to return to watching TV.
Manual Channel Scan / Update:
7. Highlight "Manual Scanning" and press "ENTER/OK"
9. Highlight "Channel Number" and use the LEFT/RIGHT arrows to choose which channel number you wish to scan . . .
UK Freeview stations are on channels 21 to 69 inclusive. In manual tuning mode, these need to be scanned one at a time. Please note, many of these channels are "empty". UK Freeview only uses 5 of these channels (called Multiplexes or MUX) or 6 if you have HD. I am unable to tell you which 5 channels these are as they vary according to whichever transmitter or repeater station your aerial is aligned to.
10. Press "OK/ENTER" to start the channel scan.
11. Repeat steps 9 and 10 for each additonal channel you wish to scan.
Please note: Manual scanning can cause some unexpected results - particularly if your aerial has a reception from more than one transmitter/repeater. For this reason it is better to use the automatical scan unless you have a specific reason for needing to scan manually.
Hopefully this will be all you need to update the digital channels on your TV. If you have any questions or need further assistance, please let me know.
Regards,
BElectric
Jan 07, 2011 | Samsung Televison & Video
How do I select to have the time and date on the photos I take. The option for this is not highlighted when I open the menu. Don't know why...
The date stamp will only work when the camera's resolution is set to postcard mode. Press Func/set, scroll down to the bottom, then across to the icon with the clock and mountain. It will say "postcard". Press Func/set again. Then press Menu, scroll down to "Date stamp" and across to select date or date and time, then press menu again
Dec 13, 2010 | Canon PowerShot A720 IS Digital Camera
HOW DO I RETUNE MY IN BUILT FREEVIEW ON A SAMSUNG LCD LE40R73DDX 40'' TV. PLEASE ITS VERY URGENT
find the ( d menu ) button on your remote then select ( chanel ) option then select ( auto store ) and press entter ! job done
Sep 29, 2009 | Samsung Televison & Video
My LCD won't tune into DTV
You need to go to your menu option with your remote. Select channel scan from the options listed in setup. This will allow the turner to find your DTV channels again. Hope this helps. J
Apr 09, 2009 | Televison & Video
Problem with nikon coolpix 8700
Same problem that would not allow me to take a picture without pressing the LOCK button on my Nikon 8700. Here is how I believe I fixed the problem:
Turn the camera ON.
Press MENU button on your camera to bring up the menu.
Scroll down to SET-UP, open the SET-UP menu by scrolling right.
In the SET-UP menu, scroll all the way down to FUNC (Controls) on page 2/3 , open the FUNC (Controls) menu by scrolling right.
You are now presented with 2 options:FUNC and AE-L, AF-L)
Select the FUNC option by right scrolling.
Choose the 2nd option: i.e the mountain, flower and timer icon (distance, macro and self-timer icon) by right scrolling.
Press the MENU button to get out of the menu.
Attempt to take a picture without pressing LOCK.
Should work! Anyways, it worked for me.
Cheers.
Sep 28, 2008 | Nikon Coolpix 8700 Digital Camera
Problem with coolpix 8700 camera
Turn the camera ON.
Cheers.
Digital tuner
I don't have this unit, but guessing from it's description on Amazon.com, I'd figure that it is analog-only. So you would need a converter.
Here's the thing: all U.S. broadcasters are transmitting the new DTV signals NOW - in addition to the old analog signals. If a TV has a digital tuner, you should be able to use it now to see those DTV signals. Check your setup menu for options like ATSC.
One hint, the new signals use channel designations like 7.1 or 7-1 or 7-1HD. And some stations will have virtual channels, i.e., 7.1, 7.2, 7.3. If you can't get your TV to scan channels and show the numbers in that fashion, it isn't using a digital tuner.
Dec 28, 2007 | Broksonic SC975 19 in. TV/DVD Combo
Self timer
Hiya yeah i had the same problem i only found out a few days ago and i had it since the summer hahaha.. emm well mines a cassio ex but im not sure about z600 but what i do is.. while im taking the pic.. click menu.. and lots of options come up ya just have to keep scrollin across >> and then der'll be an option (sori i cant remember wat it says because mi cam is after breakin on me) and de options to the option (sori sounds complicated) are .. 0 seconds.. 10 seconds.. off.. 20 seconds.. that kinda thing..click one'a them that shud do it..
Dec 14, 2007 | Casio EXILIM ZOOM EX-Z600 Digital Camera
Sharp Aquos LC-46D62U 46 in. LCD HDTV Logo
43 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
