Question about ViewSonic E70fb (Black) 17 in.CRT Conventional Monitor
Monitor (viewsonic e70fb) keeps shutting itself off
This problem just started recently and is getting worse. At first, the monitor would shut off, I would turn it back on and it would stay on. It has progressed to the point where it will only stay on a few minutes and shuts off.  And now, I have to keep turning it on and off sometimes for 10 minutes or more before it will "catch" and a picture appears. It always returns to where I was when it went off. Also, just now, the screen has begun vibrating and is very hard to read.
  • 1 more comment
  • Anonymous Oct 12, 2008
    same as above or below... turns off and on and off and on and off
  • criticalgreg Oct 18, 2008
    My monitor will run for about five-10 minutes and then it will go completely black and I have to re-start the system. Sometimes this works and other times it doesn't. I even tried new connections and it still happened.
  • Tawhid K
    Tawhid K Jan 01, 2014
    my hp w17e monitor kepps randomly shutting off and turns back on either few seconds later or 10 minutes later. after it turns on it repaets the process. sometimes when the monitor doesn't turn back on i just press the auto, menu, or some other button and it turns back on. i knew the monitors causing the problem because i plugged in a different monitor and it works perfectly what should i do. all the wires are very tightly placed and i cleaned the monitor's from dust and other dirt with canned air spray.
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
The screen has begun vibrating and is very hard to read.
it sounds me that there is some sparking in power supply or high voltage section (FLYBACK) due to loose contact,
your problem of  shut off, I would turn it back on and it would stay on
.might be also due to that only.
please call tech if you are not a tech person.
it is not a major one & simple to fix.
good luck.
Posted on Oct 11, 2007
My View sonic E70fB displaying OSD lock how can i remove it please help me sir
press and keep pressed upto 10 to 20 seconds the unlocked messege will appear problem will be solved
Sep 11, 2011 | ViewSonic E70fb (Black) 17 in.CRT...
I am having viewsonic E70fB monitor. brightness and contrast automatically increases. i want a solution to solve this problem
In most cases this could happen because of electronic components getting aged. I suspect the monitor's LOT or some capacitors about to die. Get them replaced with the help of a expert technician. That should fix this problem.
Mar 02, 2011 | ViewSonic E70fb 17" CRT Monitor
Hi what is the model number for an e70fb backlight? i need to replace
ViewSonic E70fb 17" CRT Monitor, it is not LCD flat panel monitor, it does not have backlight assemblies. It uses picture tube (CRT).
Are you asking about ViewSonic E70fb 17" CRT Monitor problem or other model?
Sep 06, 2010 | ViewSonic E70fb 17" CRT Monitor
Viewsonic PL2230WDB 2200W Shuts off after 5 seconds
The capacitors in the power supply look good?
http://en.wikipedia.org/wiki/Capacitor_plague
It can be the backlight inverter board is going out.
Nov 05, 2009 | Computers & Internet
ViewSonic E70fB Brightness & Contrast problem
Sounds like the buttons or the button panel are messed up. Or it has gotten moisture in it.
The only time i have seen this was when one of the buttons were malfunctioning, and we ended up replacing the monitor.
Oct 03, 2017 | ViewSonic E70fb 17" CRT Monitor
At the centre of my viewsonic monitor model:E70fB a message in blue coloured box that"osd lock"and its blinking continously its irritating me
Please try to Turn the monitor off. Hold down the Menu button while the monitor is turned off, then press the Power button again to turn the monitor back on. This might unlock your OSD menu and remove that message from your screen. regards
May 14, 2009 | ViewSonic E70fb 17" CRT Monitor
ViewSonic E70fb (Black) 17 in.CRT Conventional Monitor Logo
682 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
