Question about Samsung Galaxy Y GT-S5360 Factory Unlocked Smart Phone White
Momrie card bakap .Delete files bakap halp me
How to delete if internal memory card full
Hi
You can either download photo, data files to a SD card, another device (computer) or simply delete unwanted data by using the file brower. Locate, the unwanted files in storage, camera, or certain apps folders, & delete files. Don't delete any file in system folder. Hope this helps. Regards Bob from OZ
Jul 27, 2014 | tmax White 8GB 9" Android 4.2 1.6 GHz,...
How do I delete photos off of the card after I have saved them to my computer?
If you have connected the scanner .... using the mini-USB port at the back of the scanner ... to your PC, and you have already downloaded (copied) the photo directly off the card to your computer ... you can select the photo's (on the card) that you do not want (e.g. click on the item / icon list) ... and press DELETE ... like you're deleting a file off one of your folders/directories. You will be shown a pop-up window asking you to confirm if you really want to delete those (selected) files (photos). Click on YES.
Yes, the PC sees the contents of the card as a "list" of files in the (card) folder. So, just delete the photo's (files in the card) folder like you would delete any file.
If you have the card (removed from the back of the scanner) and inserted into your PC (e.g. via a USB card reader) ... and you have already (selected and) copied the photos (files) to your computer, you can do the same (as above) to delete the photos off the card. That is, select the photo's you want to delete (by clicking on the icon or item listed) and press the DELETE key.
Nov 04, 2013 | PANDIGITAL PhotoLink Office Equipment &...
When i want to change setting for my text message, my phone stated that this operations required sim card even my sim card is inserted properly.
this is a minor software issue, try to do soft reset factory default settings, or hard reset the device (*#7370# default code is 12345) but this 2nd method will delete all your data, so first make back up.if my suggestion was halpful post like.
Jun 27, 2012 | Nokia 6303 Classic Tri-Band Cell Phone
How do I delete a stored game in progress on Harvest In The Heartland?
Select system settings, then select data management, Select the "System Memory" tab to delete files from the Nintendo DS system memory. Select the "SD Card" tab to delete files from an SD card. A list of saved files on the system memory or SD card will appear. Select the saved file you want to erase from the list. A prompt will appear.
Choose "Delete" from the prompt and confirm you want to delete the file. The saved file will be immediately erased from the system memory or SD card of the Nintendo DS.
Feb 18, 2011 | Destineer John Deere Harvest In The...
HOW DO I DELETE FILES
deleting files on sd cards is the same a deleting any other file on a computer as long as the media is not protected against file deletion or file altering
usually sd cards as you used to find also in old floppy dics, have a tab or switch you need to set accordingly to allow file overwriting. inspection the sd card and make sure that the tiny switch or lock is in the off position, reinstall sd card in the reader or sd card drive and attempt to delete files by selecting them and hitting the del key or simple selecting them and right clicking to then select delete.
if the tab is in the off position try it in the "on" position and see if deletion can be accomplished. if neither works your sd card may be defective. contact the provider and have the warranty honored accordingly in within the warranty terms.
May 06, 2010 | PNY 4GB Secure Digital High Capacity...
Nokia 5800 memory card unlock code
well if your phone does not have a file manager place the mem card in one that has one then use the file explorer go to drive c or whatever drive represents the card find a file called mmcstore rename it to a .txt file open it on the phone or if it cant send it to a pc the password would be in it
Aug 23, 2009 | Cell Phones
How do i delete files from memory card or from phone itself??
Hi buddy,
If u want to delete the files from memory card then just go into memory card select the file and in option press delete and same for the phone memory files.
I hope this solution will be helpful for u.
Jul 31, 2009 | Cell Phones
Iriver e10 is full with only 2.47GB of files
Open in windows explorer disc representing the player. Make sure you have "show hidden files and folders" option on. Find folder named recycled, recycle or sth like this. Now delete it.
Jun 08, 2008 | iRiver E10 Digital Media Player
Memory card micro sd cannot format
Definitely your Micro SD Card has a problem. might be ita a virus problem.
Try to format it by your Computer not by your Phone. If you have a AntiVirus scan your Card and then try to format it.
if you are not successful in one chance Don't afraid at all, try it three or four times by removing and then inserting the Card again in the Computer........
Mar 19, 2008 | RIM BlackBerry Pearl 8100
Samsung Galaxy Y GT-S5360 Factory Unlocked Smart Phone White Logo
23 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
