I need to get the maximum batery for my unit...am very confused ...some people say that the 5800 mah is as big as they get...others are tryin' to sell me a 7800 mah...???
SOURCE: New 6600 mAh battery won't charge
Is the AC adapter the original that came with the laptop or is it a replacement?
Check the label on the laptop (on the bottom of the laptop) for the voltage and current requirements.
Check voltage output of the adapter with a multimeter, this voltage should be slightly higher that the voltage than what is shown on the adapter's label because there is no load on the adapter.
It could be that the current (amps) that the adapter is delivering less power than the laptop's requirements, whilst it can power the laptop it may not be sufficient to charge the battery fully.
Try charging the battery overnight by shutting down the laptop but leaving it connected to the mains. Then boot up the laptop in the morning and check the battery's charge state. If the battery is at or near full capacity, then the problem is a (part) faulty adapter.
Linpus™ Linux® - Intel Core i3-350M (3MB Cache, 2.26GHz) - 2GB DDR3 RAM - 320GB SATA HDD - ATI Mobility Radeon HD 5470 with up to 3579MB of HyperMemory - Screen Size 14" HD 1366 x 768 resolution - Battery 6-cell Lithium Ion (Li-Ion) 4400mAh - Up to 6hours battery life
AS4745G-352G32Mnks
LX.PSM0C.037
Compare
Intel® Core™ i3 Processor
