Question about Hayward 100,000 BTU Pool Heater H100ID1 - Above Ground
Hayward hd100id blower works water luke warm
The heater blower turns on the water gets luke warm.
  • 372 Answers
It sounds like the thermostat is turning the heater off before it gets the water to temperature. It is probably the sensor, as that is the most common cause, but may be otherwise.
Posted on Nov 29, 2013
SOURCE: Problems with Hayward 100,000 Btu Heater
I am sorry to report that this is a very common problem for this heater. Here is more information than you want: http://forum.doityourself.com/pools-spas-hot-tubs/345253-hayward-h100id-ignites-but-cools-quickly.html
Posted on Jun 09, 2009
john224
  • 1378 Answers
SOURCE: igniter not working when heater is turned on
Air pressure sensor on the blower blocked or damaged and not reading the fan is on. Control board not sending spark down to the ignitor. Check the short grey tube off the blower first. If clearing it works, great. If not, you'll likely need a warranty service call. http://www.haywardnet.com/locator/
Posted on Jun 14, 2009
  • 990 Answers
SOURCE: My heater ignites and blows really hot exhaust
The water is mixed on the back side of the heater and will exit the heater at 7-11 degres hotter than it came in. This will keep people from being scalded at pool side. So what you have sounds normal.
Posted on Apr 18, 2010
jharwell668
  • 640 Answers
SOURCE: pool heater will not ignite
Try the owners manual for these pool heaters. It will have suggestions for getting your problem corrected.
http://www.backyardcitypools.com/images/Hayward/H100-Manual.pdf
Posted on Dec 07, 2010
  • 368 Answers
SOURCE: I have a Hayward HD100ID
Since this heater was only purchased last year, if it is faulty they should cover it under warrantee. If you call Hayward technical support they should be able to help you figure out what the next step is. I hope this helps.
Posted on Aug 08, 2011
Luke warm water
is the water temperature dial turned up? or even functioning?
Jul 28, 2013 | Bosch AquaStar Indoor Natural Gas Tankless...
1998 peugeot 406 heater gets warm but not hot
This may be a thermostant or a plugged heater core, locate the hoses going to the heater core in the engine compartment, feel both of them and see if one is a lot hotter than the other, if so then you may need to flush the core with a water hose, the other thing would be if the hoses are luke warm then the engine thermostat mat be stuck open.
Nov 17, 2012 | Cars & Trucks
Heater gets warm the goes Luke warm when blower is turned on
when you put the heater on hot and the blower on full and the car is running at idle, the coolant in the heater matrix is cooled quickly,as when the radiator fan comes on to cool the engine, have you tried raising the revs and checking the heater to see if it gets hotter. If this does not happen you could have air lock in the cooling system and may need bleeding properly.
Mar 23, 2012 | Ford Focus Cars & Trucks
I have a Hayward HD100ID natural gas heater that I purchased last year. It's been working great up until yesterday. Today, when I plug it in and turn thermostat to max, nothing happens. I don't...
Jul 23, 2011 | Hayward 100,000 BTU Pool Heater H100ID1 -...
My oil fired hot water heater provides only sporadic hot water. For example, when I am home alone it takes 2 minutes to get luke warm water in the shower, then it is only warm for a few minutes, then...
It sounds like your thermostat on the water heater isn't working properly. try turning it up higher and if this doesn't work I would have a service techy look at it.
Mar 24, 2011 | Water Heaters
My jAYCO rv only get luke warm water for as few seconds and
Also check that by-pass valve(s) is/are, in proper position at back of tank.
Apr 19, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Apr 05, 2010 | Hayward H Series Pool & Spa Heater 400k...
Power light blinks after blower turns on. Water is barely coming out luke warm after 30m of running. No other status lights lit.
The water is mixed with cool water as it leaves the heater and will only be eight to ten degres hotter than when it goes into the heater so as to avoide scalding. You need to ck the total heat rise of the water after about an hour in a spa and after about three or four hours in a pool.
Nov 21, 2009 | Jandy Laars Lt 400,000 Btu Heater
Pool heater will not ignite
check pressure switch,if it is faulty or out of adjustment it wont allow it to go tomain burner
Jun 17, 2009 | Hayward 100,000 BTU Pool Heater H100ID1 -...
Mondeo diesel 18.00 only luke warm water blows out
The water pipe that suplys water the the water heater would have been blocked or twisted
Mar 07, 2009 | 1996 Ford Taurus
Open Questions:
See all Hayward 100,000 BTU Pool Heater H100ID1 - Above Questions
Hayward 100,000 BTU Pool Heater H100ID1  - Above Ground Logo
117 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
