Question about Kodak Office Equipment & Supplies
Dvd copier program
I think i accidentally uninstalled my software for my wifi printer and it wont connect to my computor and i cant print anything out
    Master:
  • 435 Answers
Go online and find the manufacturers page for your model of printer. Download the software and install it. Try your printer again.
Posted on Nov 28, 2013
Mix-it-up
  • 832 Answers
SOURCE: MFC 845CW Not Printing Via Wifi
have a look around here:
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_list.html?reg=us&c=us&lang=en&prod=mfc845cw_us&Cat=8
Posted on Dec 28, 2007
mickspaceNET
  • 115 Answers
SOURCE: trouble networking copier to computer
you might have to set up the nic card in the machine. set it to a static IP address (not DHCP), then ping it from a PC..
If you can ping it, then instalation should find it!
I dont understand " time warner connection to rout both computors thru " ?
you should have.
One broadband Modem...
One Router which all pcs and machine's are connected to...
do ipconfig/all to figure out the pcs IP address, arp -a shows the arp table. determine what IP address to give the machine.
the machine should have a nic card with a light on it, if that light is green when you connect the cable, then the nic card is working.
then proceed to install the drivers to the PCs.
Posted on Oct 23, 2008
  • 3 Answers
SOURCE: Re: DVD labels won't print on my Epson R265
Hello guys.
About the problems printing CD/DVD with your Epson R265 ....................
There is nothing to do. The prg coming with the printer (PrintCD) is wrong at all and we cannot understand why the Epson Corp. has simply deleted the prg by its download site.
After tryng for a lot of solutions ........ INCREDIBLE but TRUE ..... the program Print CD coming with the previous Epson R200 is ok at 100% !
So, in conclusion, all prgs inserted onto the Epson R265 CD are OK eccept the Print CD. Don't install it from the R265 disk ! It will crash !
If already installed, delete it and install the prg Epson R200 print CD.
It will work fine and without troubles.
Repeat ... it's incredible, but true.
The prg can be downloaded searching for Epson R200 software.
If you will have troubles, let me know.
Posted on Dec 05, 2008
  • 11 Answers
SOURCE: Re install Dell 926 printer
Go to this site and on the left hand side of the screen select "Download and install the 926 printer drivers". Just follow the instructions as given and select the correct OS.
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&dl=false&l=en&s=gen&docid=295FA22157850234E040A68F5B281614&doclang=en&cs=
Posted on May 13, 2009
  • 117 Answers
SOURCE: my hp psc 1350 printer scanner copier wont scan
When an ink tank becomes empty.
("No ink error" displayed on the
monitor or on the machine LCD, or
short flashing of an ink tank LED)
Posted on Oct 09, 2009
I have a new laptop but i cant print it any document and my printer no hp laserjet 1018. so pls help me.
You need to uninstall the HP solution center and other HP printer software from add/remove programs or program and features, in your control pannel.
Disconnect the printer from the USB, use the disc which came with the printer or download the printer software/ driver from HP.com or click the link below.
Driver download link (after clicking the link select the operating system and click on next as shown in image below)
Install the driver/ software and follow on screen instruction, connect the printer when the software will ask.
Give a test page print.
Note: Uninstall the HP printer softwares before installing it again.
Regards,
Shrey
May 31, 2011 | HP LaserJet 1022n Printer
Printer said to disconect from computor which I did but still blinks and wont print
Disconnect the printer or at least be sure it is turned
off. I'd do both and reinstall the CD software program
that came with the printer.
When the software program asks you to
connect the printer to the USB port, do so and it
should again work properly.
Hope this is of some help. Bud
Aug 09, 2010 | Lexmark Office Equipment & Supplies
Wont print, no error msg
You have no choice...Be patient...Try to uninstall and install your printer driver.I hope this could help.
May 12, 2009 | Office Equipment & Supplies
Removed epsom rx600 printer installed lexmark f480 get ocr prob
If you are using MS Vista Operating System then your scanner feature will not work as there is no provision for it in Vista. If you are using MS XP or older, unistall the software from your pc. Detach the device and restart the pc. Re-install the drivers from the cd. DO NOT CONNECT the printer at this stage. Connect it ONLY when prompted or at the completion of installation. Good luck
May 04, 2009 | Epson Stylus Photo RX600 All-In-One InkJet...
Can not reinstall printer
Try disconnecting the printer from the USB port and reinstalling the CD program. Don't connect the printer to the USB port till the program says to do so.
Hope this help. Bud
Jan 21, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
My all in one printer 922
what operating system are you using? if you have windows vista then go to the dell site, download the patch under the windows vista drivers. run the patch, it will remove all traces of the software then download the latest vista driver form the dell site and install it. if that doesnt work then try this.
1. Download the latest Vista driver.
2. Disconnect the PC from the network/Internet
3. Delete the printer
4. Disconnect the printer from the PC
5. Uninstall the software from Device Manager (you have to choose
view, show hidden devices). Right click on the printer and choose
uninstall.
6. Uninstall the software from the program group or the control panel.
7. Reboot
8. Delete everything in C:\windows\system32\spool\drivers\w32x86\
9. Install the Vista Driver reconnecting the printer when the driver
install calls for it.
Good luck
Nov 17, 2008 | Dell 922 All-In-One InkJet Printer
Will copy wont print
uninstall printer from control panel on computer and reload software driver for this printer also make sure this is the default printer on your computer this printer should have a black checkmark above this printers Icon
Jan 07, 2008 | Dell 924 All-in-One InkJet Printer
SOFTWARE MALFUNCTION NO DIRECTOR OR SOLUTION CENTER
What Operating system are you using? One thing I would recommend trying is uninstalling all software related to the printer/scanner, then turn off the computer and unplug the printer from the computer. Turn the computer back on then restart the computer and try reinstalling. Your problem could be that the computer is not uninstalling the printer/scanner all the way meaning the computer is still detecting the printer/scanner. Those steps would fix it if that is the case.
Oct 22, 2007 | HP PSC 1410v All-in-One Printer
HP 1315
You should have gotten an installation CD with the printer. First, find the installation CD. Once you have that, follow the steps given by the tech.
Apr 25, 2007 | HP PSC 1315 All-in-One Printer
21 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
