Question about Lexmark X3480 All-In-One Printer
Printer says the cover is open none of the funcutions work.
Find the door actuator and stick it in place with Blu tac
job done
Posted on Jul 25, 2009
    President:
  • Lexmark Master
  • 990 Answers
Hello sir;I'm not sure this model is there have rear side door if do have close it if don't have, then check the door actuator isn't broken, either on the side of cover or on cover hinge.
Posted on May 09, 2009
Cover open
reseat all the covers and check that none have broken tabs which tell the copier the covers are closed,
Aug 10, 2014 | Sharp AM-400 Digital Multifunction Printer
Samsung er-5115 sam4s cash register is locked up and read PP00. Unplugging does not do anything. None of the keys respond.
Your printer is stuck.1 open the printer cover 2Pull out he ribbon 3 plug your machine, that should work
Sep 18, 2013 | Sam4s Samsung Er-5115ii Cash Re
Z1380 green power light flashing constantly. Cartridges not returning to right hand side of printer. No printing possible.
The flashing light on your printer could indicate either a paper jam or a cartridge problem. Remove the sheets of paper from the feeder. Open the printer cover and remove the cartridges. While cover is open, check for any obstructions in the cartridge carrier's path. Close the cover. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, insert one cartridge first. Close the cover and check for any errors. If none, re-insert your other cartridge. Replace whichever cartridge is causing the error to appear. You can also try to insert a different known working cartridge to determine if the other is faulty. If cartridges are fine, load some paper (avoid overloading). Also, use the specified paper types and sizes for your model. Try to print again.
Jun 23, 2011 | Lexmark Z816 InkJet Printer
Error #1203 x7350
The 1203 error on your printer indicates either a communication failure between one of the cartridges and the printer or a short in one of your cartridges. Please follow the steps below to fix the problem:
  1. Open the printer cover and remove both cartridges.
  2. Close the cover.
  3. Unplug and re-plug the printer into the power source to reset it.
  4. When the printer turns on, re-insert one cartridge first. Close the cover and check for any errors.
  5. If none, re-insert the other cartridge. Close the cover and check for any errors.
  6. Replace whichever cartridge is causing the error to appear. You may also try to insert a different known working cartridge to determine if the other is faulty.
Try to print again.
Jun 22, 2011 | Lexmark X7350 All-In-One InkJet Printer
My lexmark printer x 3470 will not operate....it says the cover is open but it does not appear to be and none of the controls will function.... help please??????
It could be due to the cartridges in the carrier or the sensor for the cover has become stuck. Open the printer cover and remove the cartridges from the printer. Close the printer cover. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, re-insert the cartridges and close the cover. Check for any errors.
Jun 15, 2011 | Lexmark C533DN InkJet Printer
Printer wont print showing C 5 E on display
EC5 error code indicates a short has been detected in one of your cartridges. Try to remove both your cartridges from the printer. Close the cover. Unplug and replug the printer into the power source to reset it. When the printer turns on, reinsert one cartridge first. Close the cover and check for any error. If none, open the cover and reinsert the other cartridge. Close the cover and check for any error. Replace whichever cartridge is causing the error to appear. You may also try to insert a different known working cartridge to determine if the other is faulty.
May 04, 2011 | Lexmark X2670 All-In-One Printer
Brother 5250
I had the same problem on 4 Brother HL-5250's, I checked the whole printer, and couldn't find a paper jam, yet the red printer light wouldn't shut off. I finally followed the instructions on Brother's website for removing a paper jam, and the solution for all 4 printers was paper stuck in the fuser cover. See below on how to open the fuser cover.
Pull the tabs at the left and right hand sides toward you to open the fuser cover (1).
  2. Hint
  3. There are 2 kinds of covers at the rear of the printer. Please make sure to open both the back cover (step 7) and the fuser cover (step8).
  • May 27, 2008 | Brother HL 5250DN Laser Printer
    Drum light flash Brother HL 2070N
    You need to have the front of the printer open, when you press and hold the 'Go' button. All four lights will come on, in sequence. Release the button, and close the front cover. Done...
    Feb 27, 2008 | Brother HL-2040 Laser Printer
    Lexmark 3400
    printer screen shows cover open but it is,none buttons will work
    Jan 09, 2008 | Lexmark X1270 All-In-One InkJet Printer
    AIO 922 Cover Open
    Some how, the sensor that reads when the cover is closed is not reacting like it should.
    I assume that you have pulled the cover back up and then back down several times? The status then still indicates that th "cover open" and does not change?
    We need to figure out why your sensor is not reading correct. It is located on the right rear when looking with the cover open.
    Jan 05, 2008 | Dell 922 All-In-One InkJet Printer
    Lexmark X3480 All-In-One Printer Logo
    215 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
