Question about Tools & Hardware - Others
Milling machine problems and solutions
What problems are experienced on milling and how are they solved
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
Volumns can and have been written to answer your question. If you are seriously considering getting into machining, go to your local technical college or look on line for more info than you can possibly absorb. You tube videos are posted that can and will show you and give you so much information it boggles the mind. Good luck.
Posted on Nov 26, 2014
  • 3,961 Answers
I'm going to assume you mean metal, since on wood it is called routing.
The number one problem would be insecurely fixed work pieces. Work out which way the cutting force goes, and try to have that directed to a solid part of the setup, not to a moving jaw or clamp.
Make sure your cutter is sharp. Blunt cutters generate enormous forces which can become dangerous. I have seen cutters shatter in this situation.
Know your cutter type and what it is capable of. Some types cannot do a heavy feed rate. Know your material and what it requires. Stainless steel for instance is treacherous because it hardens in the cut.
Use some kind of cutting fluid even if it makes a mess. Milling is a process which needs it, and you will get a better finish.
Never never put your fingers near the rotating cutter. I saw an apprentice mill his forefinger off once. He was feeling the surface finish behind the cutter.
Posted on Jun 18, 2014
  • Geoffrey White
    Geoffrey White Jun 18, 2014
    Ha. It should read "I once saw an apprentice...."
Motherboard smoke when switch on CPU damage power connector on board
I would replace the whole power supply. You don't want to give it a chance to short out the board. If this is a just a run of the mill business machine the power supply should only be around 50.00 or less depending on where you find it.
Apr 14, 2016 | Lenovo ThinkCentre Computers & Internet
Are there automatic grain mills? I've only been seeing hand mills on Amazon.
Most of the mills that you will see on sites like amazon are hand mills but I found the Nutrimill to be a really amazing machine mill, its quiet and quick and has many different settings. EQUIP Nutrimill Grain Mill Amazon com Kitchen Dining
Jan 23, 2014 | Kitchen Appliances - Others
Whats the difference between a vertical and horizontal mills?
Horizontal and vertical just refers to the orientation of the spindle, each has their advantages and disadvantage, the vertical mill is more for standing mechanists and doing more detailed work while the horizontal are designed for cutting heavy pieces.
Jan 23, 2014 | Tools & Hardware - Others
What is gang milling? Do I need a special milling machine?
Gang milling is the term used for using multiple milling cutters mounted all on the same arbor. If you have a horizontal miller then you shouldn't need to get an other one.
"GROUND TOO FINE ADJUST MILL! Insert water spout
  1. Insert steam spout and push OK.
  2. Fill your tank and add descale solution.
  3. Go to program settings - Descale.
  4. Follow the prompts on the readout.
  5. After descale and rise are complete refill your water tank.
  6. Your system should now work as normal.
Note: If you do not have a descale solution, run the above with just water. Remember to descale when you obtain a descale solution.
Sep 27, 2013 | DeLonghi Perfecta ESAM 5600 Espresso...
Whats the difference between a milling machine and a drill press?
a drill press holds the work piece stationary to be cut, a milling machine moves the work piece to the milling cutter.
Jan 23, 2013 | Tools & Hardware - Others
Wont spin
Hello Trish Mills - Does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if water pumps out. If it does not, the unit could possibly be experiencing an issue with the pump, door lock assembly or timer. Contact a professional to move forward accurately.
Nov 17, 2012 | Frigidaire ATF6000ES Front Load Washer
Ave an SAECO INCANTO RONDA with milling problems.
You can turn the grinder (mill) so the plates open for a more gross coffee this will help the grinder motor to rotate more free you can use a vacume cleaner to **** all the remainig coffee inside the grinder. If still not any reaction you have to desasemble complete clean the grinding plates. If you still not have any reaction then the grinder motor burn out and need to bee replaced.
Remeber to vote for this answer.
Feb 25, 2010 | Saeco Incanto Rondo Fully Automatic Coffee...
My xbox360 turns on but does not show on the television
The problem you are experiencing is closely related to the dreaded RROD (Red Ring of Death). It has the same causes and solutions. I suggest getting an experienced person to repair your console for you. Take care that no one is doing the "Towel Trick" instead of an actual repair.
I run an electronics repair business and would be happy to fix your machine for you, email me at Jordan@jordanselectronics.com for more info
Dec 27, 2009 | Microsoft Xbox 360 Console
Where is the Knock Sensor 1 located
Solution:
1. If you have to pay for a solution here on fixya, why not take it to a mechanic.
2. For the price of a live chat here on fixya for a one time solution you can purchase a complete repair manual and solve the problem yourself. Daah???? No more $20.00 piece mill each time you have a problem with your car.
I hope this eye opener will be a help to others.
I really don't expect to see this one in a post.
Jun 10, 2009 | 2002 Kia Spectra
Tools & Hardware - Others Logo
122 people viewed this question
Top Tools & Hardware - Others Experts
ray gallant
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
