Question about Vornado TouchStone Vortex Heat 500 Heater
My vornado heater wont turn on - Vornado TouchStone Vortex Heat 500 Heater
Static electricity
From what you have said, I am guessing that you shorted out the little controller chip(s) on the circuit board. Some of the Vornado heaters are serviceable by the company but you would have to check your model number. They have a live chat that can tell you if you go to Vornado.com and click on support you will see it.
Mar 17, 2014 | Vornado Heating & Cooling
My vornado heater stopped working.
vornado tv 500 work 2 minutes and stop forever
Feb 01, 2011 | Vornado EH1-0014-01 Compact Heater
I am writing about a vornado TouchStone Vortex 500 Heater. I plugged in another heat in another room and the lights went out. I reset the circuit breaker but the Vornado will not turn on. Cathy Giuli...
Call 1-800-234-0604 - This is Vornado's consumer service line. This manufacturer is well known for great customer service, and they should be able to tell you if something is wrong with the unit. If so, and if the heater is under warranty, they will fix it or replace it for free. You won't even have to pay shipping to send the unit in.
Oct 22, 2010 | Vornado TouchStone Vortex Heat 500 Heater
I need a new on/off switch
I have the same problem with a VH Vornado heater
No need to change switch.
The switch has to sets of contacts, but uses only one. This one is burnt out
Just reconnect the black cable (hot) to the opposite free switch connector.
Then interchange the white (resistance) with the brown cable (ground for switch light)
You may have to turn around the switch because the heater will turn on on the "OFF" position
Check your cables with tester, to avoid any short circuit.
Dec 15, 2009 | Vornado REH1-0001-01 VortexHeat Compact...
Vornado dvth lights are on but no fan
I would call Vornado at 1-800-234-0604. They have great customer service- and usually have really good warranties with their products. I bet they can get you figured out. Any time I have had any questions, they have been very helpful. Vornado is also on Twitter, by the way - so if you "tweet" then some people ask questions via twitter too. I have always had good luck with their fans...
Mar 01, 2009 | Vornado DVTH Compact Heater
The fan has quit on my Vornado VH2 portable heater.
take apart the heater clean the bearings, and oil the shaft around the berings lightly with all purpass oil
Jan 19, 2009 | Vornado VH2 Compact Heater
I have a Vornado VH2 portable heater. The fan has quit working.
generaly a problem like this ocures because of gummed up bearings
1.take apart heater
2.remove fan
3.wipe of bearings
4.lightly oil bearings and shaft around bearings ## TO MUCH OIL COULD POSE A FIRE HAZARD :0
5.asemble
6.test
Vornado VH2 stopped working. on/off not functioning
if it is a rocker type switch replace the swich
IMPORTAINT make shure switch it is replaced with is rated at 15Amps
Jan 08, 2009 | Vornado VH2 Compact Heater
My Vornado TouchStone Vortex heat 500 Heater - temperature
After calling Vornado Corporation, they suggested that the room temperature monitor might be failing as it read 65 degrees no matter where you started the heater. I took the unit back to the store I purchased it from, and we unpacked another unit and found the same problem existed. Therefore, the product is not capable of heating a room properly and I will continue my search for a space heater to control the temperature in my upstairs office which does not have air ducts for heat.
If anyone has recommendations I would be interested in their comments.
Thank you.
Nov 19, 2008 | Vornado TouchStone Vortex Heat 500 Heater
Vornado TouchStone Vortex Heat 500 Heater Logo
133 people viewed this question
Top Vornado Heating & Cooling Experts
Bill Long
Lyle Siemens
Lyle Siemens
ray gallant
Are you a Vornado Heating and Cooling Expert? Answer questions, earn points and help others
