Question about Infotainment MEGA 8400 mAh Portable USB Powerbank Charger - Black Carbon -
How do I turn off flashlight - Infotainment MEGA 8400 mAh Portable USB Powerbank Charger - Black Carbon -
My streamlight stylist flashlight won't turn on. i had to shake it or mess with rhe end by turning it yo get it to come bsck on. I was holding it in my mouth do you think it got wet
LED flashlights (depending on the manufacture) are not cracked up to what they say they are. The problem with these LED flashlights is that they don't draw enough/much current through the flashlight itself to close the circuit when turned on. So, what happens a lot of times, they become intermittent. Sometimes you have to play with the on/off button to get it to turn on or unloosen the battery end cap or the LED end cap and retighten. Sometimes you have to remove the batteries themselves from the holder and reinstall. Or sometime just spinning the batteries in the holder will fix it till next time. LED flashlight with spring contacts inside work a little better because it's applying pressure to the contact inside the flashlight providing batter connections.
May 27, 2016 | Streamlight Camping, Backpacking & Hiking
Tip
LANTERN OPERATION 1. PUSH THE LANTFRN/FLASHSLIGHT/OFF (11) TO ?LANTERN 1+2? OR...
LANTERN OPERATION
1. PUSH THE LANTFRN/FLASHSLIGHT/OFF (11) TO “LANTERN 1+2” OR “LANTERN I”. THE LANTERN WILL BE TURNED ON.
2. PUSH THE LANTERN/FLASHLIGHT/OFF (11) TO “FLASHLIGHT’ TO TURN ON I’HE FRONT LIGHT.
3. PUSH THE LANTERN/FLASHLIGHT/OFF (11) TO “OFF’ THEN BOTII LANTERN AND FLASHLIGHT WILL BE TURNED OFF.
4. PUSH THE BLINKER/SIREN/OFF (12) TO “BLINKER” AND THE FLASH LIGHT (10) WILL BLINK.
5. PUSH THE BLINKER/SIREN/OFF (12) TO “SIREN” AND THE SIREN WILL BE TURNED ON.
6. PUSH THE BLINKER/SIREN/OFF (12) TO “OFF” AND BOTH THE FLASH LIGHT (10) AND THE SIREN WILL BE TURNED OFF.
7. PULL OUT THE LANTERN (16) AND ADJUST THE LANTERN ANGLE.
on Mar 05, 2009 | Jeep KNG36-JXLWBC AM/FM/Weather Radio
How do I turn on flashlight on Maven ZTE
The best way to turn on your flashlight is to download a flashlight app on the Google Play Store. most of these apps have a simple switch to turn on and off the flash on your phone.
Mar 08, 2016 | AT&T GoPhone ZTE Maven 4G with 2GB Memory...
Replace batteries for stanley 95-112 flashlight
95-112B - Stanley Tripod Flashlight battery replacement is in the center chamber. Open the three legs, then put your fingers around the bottom part of the center chamber and turn counter-clock wise. Wella put in 3 new AA Batteries.
Apr 14, 2014 | Stanley 3in1 Tripod LED Flashlight 95155
How to turn lite off
With IOS 7 it is very easy to turn the flashlight ON and OFF.
When you are in the home screen you have to swipe your screen from the bottom towards the top. A menu will appear. 64380167-2721-4575-b0bb-bf6ea793596e.jpeg
By pressing the flashlight icon you can turn the flashlight ON and OFF. You'll also find shortcuts to the timer, calculator, camera, controls for music and buttons to turn several wireless connections ON and OFF.
I hope this wil solve your problem.
Feb 01, 2014 | Apple iPhone 5c
How come flashlights are called flashlights if they don't flash?
In the early days of flashlights, the battery life was very short. So if you needed to use a flashlight, you would turn in on only for a second and then shut it off. Hence, the term flash-light.
Jul 09, 2012 | Camping, Backpacking & Hiking
I can't turn off my Nokia 6111 flashlight.
you turn it off by pressing Clear once more. You can also find the flashlight from the main menu by selecting 'Extras,' 'Flashlight,' and then 'On/Off.' The Flashlight icon appears on the display when the flashlight is on.if this didnt not turn off the flash,then try the hard reset remove the batteries and leave for about 5mins, then back
Jan 03, 2010 | Nokia 6111 Cellular Phone
Flashlight problems
streamlights have lifetime warranties. Contact them to find a dealer that can fix it. They might even let you send it in to get fixed.
Aug 15, 2009 | Streamlight Stinger XT DC, Black
Wild Card Phone flashlight .
There is a setting in tools that asks if you want to turn the light on or off. If that doesn't work, then your back button is messed up. Hope this helps.
Jun 11, 2009 | Kyocera wild card Cellular Phone
Infotainment MEGA 8400 mAh Portable USB Powerbank Charger - Black Carbon - Logo
Top Infotainment Electronics - Others Experts
Are you an Infotainment Electronics - Other Expert? Answer questions, earn points and help others
