Cars & Trucks Logo
R
Richard Watson Posted on Nov 28, 2013
No heat low r no heat and coolant dissappears
cchong10
Level 1:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Nov 28, 2013
cchong10
Contributor
Level 1:
Problem Solver:
Answers
8
Questions
0
Helped
1558
Points
20
Leak in radiator and/or hose. Hot water from radiator flows through heater core and fan blows heat inside car. Too low coolant level and there's no heat!
2004 Kia low heat at idle hiway speeds ok
1) Coolant tank may show full but radiator is low in coolant...Cold engine...remove cap...inspect coolant level in radiator...fill if necessary,,,
2) If #1 is OK, the coolant system has an air blockage...With cold engine remove cap...Start engine...Heat control on high... when thermostat opens coolant AND air will escape from radiator...there will be coolant loss...Wait until all air escapes then carefully replace cap...When engine cools remove cap and top off coolant if required.....saailer
Iā€™m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Low coolant suburban
Where is your coolant going is the biggest problem you have to fix first. You may want to look at the water pump too.
Drivers side no heat. only cold air.
Fill the radiator and coolant reserve tank to MAX level.
Low coolant will cause low to no heat.
If coolant is over 2 years old then you should do a coolant flush
2004 kia spectra has blowing air but know heat.
Heat and air conditioning are in separate systems. If you aren't getting heat, the first step is to check your coolant level. Low coolant can result in improper flow through the heater core. If you do have low coolant, be on the lookout for a coolant leak! If your coolant isn't low, then there is going to be an issue with circulation through the heater core. The heater core could be clogged in some way or another.1
3helpful
I have a 2001 saturn and my coolant becomes low to none at all in a few days but it doesnt show on the ground and now the rpms drop very low when im at a complete stop. what does that mean?
I would take your vehical to a local service station its possible your coolant is leaking internally inside your engine and possibly mixing with your engine coolant, I feel this is because you are not seeing any coolant on the ground underneath your car, the coolant is dissappearing rather fast, if i were you i wouldnt drive the car at all in the risk that if the coolant is mixing with your engine oil this could severly damage critical parts of your engine, they usually will perform a series of tests in a case like this such as pressurizing the cooling system and a possible leak down test on the engine to see where the coolant leakage is occuring and what the proper repair course would be to take....
2helpful
3answers
Heater blows cold air 1995 plymouth voyager
could be a cracked block engine.what i would do is put a tarp or old sheet down park vehicle on it and wait then when you check you can look on old sheet to see where its leaking and it will give you an idea where to look for the leek if it was head gasket youd have sludgey looking whitesh foam in the oil
2answers
Heat doesn't work all the time
Check the coolant level. If it is low, the heat won't work at idle, only when accelerating. If it gets even lower, it will overheat.
Heat only works when temp gets about 220, just change the thermostat, will low coolent be the issue
You should see heat well prior to this heat, is your coolant level exceeding low? I have seen situations where the coolant level is so low it will not get to the heater until it warms up (by warming up the coolant has expanded thus filling up the heating system more.
I hope this may have helped,
Tom
1991 Toyota 4x4, 4 cyl. engine. Surges when coolant level is low, even though it has not yet heated up.
your carb has a coolant heated choke system if i am correct as car warms up the coolant warms the choke spring. keep full of coolant to keep from other damage
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
