Question about Denon AVR 2808Ci Receiver
When I turn on my receiver, it automatically turns off and the power button flashes red. Prior to shut down, the receiver display notes "Tuner Ext. In" What's the problem? It has worked p
Regarding Denon AVR-2808CI When I turn on my receiver, it automatically turns off and the power button flashes red. The display on the receiver prior to turning off says "Tuner Ext. In" Any thoughts on how I can fix this?
  • 163 Answers
Protection circuit turns off the unit because of critical conditions- wrong power supply voltages or one of the power amplifier channels is bad. First, visual inspect the power amp board near the heat sink for burned resistors, test outputs for a short. If there are no problem you may try to turn the unit on and you have several second before it shuts down to check power supply voltages and power amp output voltages and bias, then ... Long story you'd better take it to a repair shop or repair at ebcelectronics.com
Posted on May 09, 2009
How do i factory reset my Harman Kardon avr 55 receiver
Troubleshooting Guide
Processor Reset
In the rare case where the unit's operation or
the displays seem abnormal, the cause may
involve the erratic operation of the system's
memory or microprocessor.
To correct this problem, first unplug the unit
from the AC wall outlet and wait at least three
minutes. After the pause, reconnect the AC
power cord and check the unit's operation. If
the system still malfunctions, a system reset
may clear the problem.
To clear the AVR 520's entire system memory
including tuner presets, output level settings delay times and speaker configuration data,
first put the unit in Standby by pressing the
System Power Control button 2. Next,
press and hold the Tone Mode 8 and the
FM Mode Selector ^ buttons for three
seconds.
The unit will turn on automatically and display
the RESET message in the Main
Information Display Y. Note that once you
have cleared the memory in this manner, it is
necessary to reestablish all system configuration
settings and tuner presets.
ELECTREPAIRUSA@ELECTREPAIRUSA.COM
Jan 05, 2017 | Harman Kardon Audio Players & Recorders
No display but have sound
HI
Try resetting the system . if this doesn't work.
"Service" is needed .
To clear the AVR's entire system memory including
tuner presets, output level settings, delay
times and speaker configuration data.
1: first put the unit in Standby by pressing the System
2. Next press and hold the Tone Mode button 8 for three seconds.
The unit will turn on automatically.
this will clear all the proccessor.
Note that
once you have cleared the memory in this manner,
it is necessary to re-establish all system configuration
Good luck
Kind Regards
Apr 19, 2015 | Harman Kardon AVR 235 Receiver
IN104 automatic shutdown
Hello, my infocus in104 will power up for a while (1- 5 minutes) when connected to the power supply and turned on, after that it automatically shuts down. Power button does not light red when it automatically shuts down and need to be unplugged for a minute or more before red power button will light up again.
Mar 21, 2013 | InFocus IN104 Projector
Power Surge
charlie the proble has something to do with the tv guide here is a response from an older post Un plug the power to the Plasma Screen and also to the Media Receiver for ten minutes. Disconnect the off the air antennas both A and B. After ten minutes plug in the plasma screen then the media receiver and turn on wi the remote control. You should now be back in operation. I was. Also It may not be a bad digital tuner. The TV Guide feature is active even when the zip code is set to all 0s so if you have an over the air antenna attached the TV will look for the TV Guide info and if it can not find it because of a weak signal or the chanel it is tuned to does not carry that information the TV thinks that tuner does not work which triggers the 12 flashes. Also on power up the gray box with the waring message "Plasma Display Starting Up, Please Wait" appears and the screen is blank.
Aug 05, 2012 | Pioneer PDP-6010FD 60 in. Plasma HDTV
Power light is flashing and power won't turn on
these a couple things you can try to reset,if resetting dont work you will have a amp problem.Try pushing and holding down these 3 buttons s.speaker b and att and exit buttons for at least 3 sec or more.should reset.If not also try pushing and holding down mult speaker and exit and att buttons together for at least 3 or more seconds.if still shuts down you will have shorted transistors inside of unit.
Apr 17, 2010 | Marantz SR4002
WMC PC and TV no longer communcating by remote
For the remote : try replacing bateries
Device driver : try reinstalling the tv tuner from the device manager.
Please name you model number of ur pc.
Jun 20, 2009 | Dell Dimension 3100 PC Desktop
Red ring
speakers terminal maybe short circuit------connect it properly.
---ventilation holes are blocked----turn it off let it cool down and turn it on.
-------the unit is operating in continuous high power condition---turn it off-----and let it to cool down.-------turn it on.
Aug 04, 2008 | Denon AVR-2307 Receiver
Denon AVR 2808Ci Receiver Logo
743 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
