Question about American Standard R430 3-Way In-Wall Diverter Valve R430. Shower Fixtures. Three-Way In-Wall Shower Diverter. 1/2" NPT inlets/outlets. Solid Brass Construction. Removable Plaster Guard. Polished Brass. Cannot be used as a shut-off valve. Also available in 2 way in-wal
Repair shower converter kit #124104
Diagram to replace washers & RINGS
HOW TO CLEAN UNLOADER VALVE
Good luck. It is best to get the repair kit for your unloader. Many unloaders are not marked very well and it is difficult to find the kit needed. They have all of the parts that need replacing. ( usually a new ball or two, seats, o-rings and seals) The kits usually have a diagram of what goes where. You might want to make your own drawing and match each part you take out with the part in the kit and where it goes. It is amazing how they all look the same when they are out of the unloader. Did this go here or there????
Sep 23, 2014 | Karcher Garden
Peerless faucet sometimes won't turn on
It sounds to me like the rubber o-rings are getting old. Try posting your concerns on the Peerless Customer Support webpage. They can help you identify the model of your faucet and what repair kit to purchase. (Repair is fairly easy, the faucet is repaired in-place).
Customer Support Peerless Faucet
Apr 16, 2014 | Peerless Industries Peerless& Single...
When water is turned on, water leaks from faucet and hot/cold water handles but when diverter is engaged the shower works fine with no leaking from the handles or faucet. I have a three handle system. Any...
Write down the type and model of faucet you have. Most hardware stores have rebuild kits for faucets.( washers, rubber o-rings and or gaskets) You will have to turn your water off and do some minor repairs.
The kits come with step by step directions.
Dec 13, 2012 | Home
How to take apart delta classic shower
You can downlood and view a parts diagram here:
http://www.deltafaucets.com/customersupport/documentation/T13222-SHC.html?document=&
Here you can find a video on repairing a Delta sink faucet but shoul, be simialr to your shower facucet:
Trust these links are helpful.
Dec 19, 2010 | Delta T13222-SHC Chrome Classic Single...
Just purchased Delta Tub/Shower Kit w/Stainless Steel Ball Single Lever. The problem is the repair kit came with 1 spring and 2 small rubber washers that were not on the original lever. Looking for a...
the parts are for the shut off diaphram. if they were not there in what u have removed, u don't need them. some kits cover several types.
Aug 12, 2010 | Delta Home
The hot water valve vibrates and opens further on its own when in use. have a clawfoot tub with converted shower fixture. Is the faucet worn out?
tighten the stem if its at its tightest and stem still loose then get a rebuild or repair kit/parts most plumbing and hardware stores carry them
Apr 25, 2010 | Dmm Strom Plumbing Clawfoot Tub Shower...
I have a drip, drip, drip from my shower head on my triton t90x can you please advise. thank you
A shower head will drip for a period of time but I will assume that it is dripping continually. Servicing the Mixing Valve is what is needed to fix the continual drip. there are several 'O' rings washers that eventually wear down causing problems. These parts are serviceable and kits with instructions can be purchased at plumbing shops, DIY Stores, Hardware Stores. I hope this has helped thanks for using FIXYA. Good luck and have a great day. Jeff
Apr 07, 2010 | Home
Its has a drip i think it needs o rings but i
most home repair stores have the kits you need to repair this problem
you need new spring and seats replaced ...good luck
Nov 01, 2009 | American Standard T215.730.002 Chrome...
American Standard R430 3-Way In-Wall Diverter Valve R430. Shower Fixtures. Three-Way In-Wall Shower Diverter. 1/2" NPT inlets/outlets. Solid Brass Construction. Removable Plaster Guard. Polished Brass. Cannot be used as a shut-off valve. Also available in 2 way in-wal Logo
26 people viewed this question
Top American Standard Home Experts
Donni Steen
Mike
john h
Are you an American Standard Home Expert? Answer questions, earn points and help others
