Question about Sharp UX 108 Roll paper Thermal Fax
Fax machine fax is not coming through
    Problem Solver:
  • 17 Answers
Re: fax machine
Really? A thermal roll fax? Not working? I don't mean for this to sound brash, but in all sincerity, a nice plain paper basic fax can be had at almost any retail outlet (Wal-Mart, Staples, etc...) for about $60/$70 these days. Why even try to fix an antiquated piece of equipment like that?
Posted on Oct 12, 2007
0 characters
3 Points
Its giving me a pls open cover offline screen and it wont send any faxes i might be stupid this maybe is normal or simple but when the machine is warming it gives out a wicked screeching noise
Hi Fax machines are one of the oldest ways to send document information over a telephone line. Before e-mail became the most popular, and more efficient way to send documents, the fax machine was king. With time, fax machines have become sophisticated machines capable of many functions. No longer found only as a stand-alone machine, fax machines are included in copiers and printers. Faxing can even be done through computer software to a receiving fax machine or printer. So with such a complex machine there are several things that could go wrong. This article teaches you some basic troubleshooting steps.
    Fax Quality
  1. If the faxes you are receiving are too dark or light, or ruined by streaks and splotches, play around with the darkness and density settings on your machine. Send a few test faxes until the quality looks good on your end. If the faxes continue to come out poorly, the problem probably lies on the sender's end. If you are the sender, and your documents are coming out badly on the other end, try cleaning the sensors of your machine with a damp cloth.
Aug 09, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
Brother Intellifax 2820
most new machines have a fax block mode to eliminat unwanted faxes coming through, just reset your fax machine to factory setings and then re load your personal data , this should rectify this problem
Apr 12, 2010 | Brother IntelliFax-2820 Laser Fax
My fax goes off periodicall when a call comes in.
It means that your fax machine is "answering" the incoming call before you pick up the handset. Usually, the factory setting on the fax machine picks up after two incoming rings. There are three ways you can address this issue: 1.) You can either change the number of rings to, say, five incoming rings to give you enough time to answer the phone before the fax machine picks up, or 2,) you can find out if your fax machine has a feature that allows for the voice hook "click over" that will allow you to override the fax when you pick up your handset, or 3.) turn your fax machine off until you need to send a fax.
If you want to investigate number 2.), then you'll need your operator's manual.
Good luck.
Aug 28, 2009 | Fax Machines
Fax Machine vs. Answering Machine
If you are there unplug the phone line from the answering machine. -Carl
Jul 24, 2009 | Brother FAX-575 Plain Paper Thermal
Fax comes out blank at the receiving fax machine.
This type of fax is "toy" buy a laser fax an get rid of all your problems
May 26, 2009 | Canon FAX-JX200
My fax machine will send faxes but not receive them. I have made sure it is plugged in and connected but no faxes will come through. Please Help!
If you have an answering machine, have it answer at three rings. Have the fax answer at five rings. Let the answer machine go thru it's cycle, and see if the fax picks up.
Apr 27, 2009 | HP 1220 Plain Paper Inkjet Fax
Hello sir; I suggest you to replace a phone wire should be take care the problem.
Feb 03, 2009 | Canon FAX-JX200
Can't get this fax machine to work with my answering machine
I have the same problem. I can send a fax, but if I try to receive a fax, the distinctive ring goes off, and it says RECEIVE on the display, but it doesn't receive anything, and there is nothing in the memory. Any ideas? PLEASE HELP!!!!!
May 24, 2008 | HP 640 Inkjet Fax Machine
Sharp UX 108 Roll paper Thermal Fax Logo
53 people viewed this question
Top Sharp Fax Machines Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Sharp Fax Machine Expert? Answer questions, earn points and help others
