Question about Sony STR-DE475 Receiver
No subwoofer i can't seem to get any sound out of my subwoofer, and yes i turned the sw on I Have five speakers hooked up plus the woofer
  • 151 Answers
Make sure you have sub pluged into the sub pre out and not the six channel input.
CABLE GUY.
Posted on May 09, 2009
How to hook up psw350 polkaudio powered subwoofer
A powered subwoofer is fed the sw line output provided by the receiver. If lacking, then the woofer might have connections to it from the speaker outputs of your receiver.
Connect them in phase, make sure your sw is in phase with other speakers and balance the sw output.
Sep 20, 2015 | Audio Players & Recorders
How do you power up the sattelite speakers without the subwoofer?
Depends on the type of sound system. Some require you to hook up to the subwoofer then the subwoofer to the sound system, others are just a direct line in to the sound system (in which case simply un hook the sub woofer. If it requires hook ups to the woofer, see if you can turn the volume down on the woofer directly.
May 29, 2015 | Audio Players & Recorders
How to hook up emerson subwoofer sw 03
For powered sub :If your receiver has a sub woofer output on female RCA plug, that is the way to go. If no output you will have to get a speaker line to line output converter to then connect to your subwoofer amp input.
Unpowered sub - just hook up across the speaker terminals for each channel making sure that you hook it up in phase.
Mar 14, 2014 | Audio Players & Recorders
I just bought a subwoofer and I cannot get it to work. I changed the receiver setting to SW = YES. Where is the correct place to plug it in the receiver, there are two subwoofer outlets.
Here's your manual. Check Pg. 9 for correct Sub Woofer connection. Leave the SW=YES setting as is if you any small speakers in the system. It can be set to SW=PLUS if you want all bass signals sent to the Sub Woofer. It should only be set to SW=NO if no Sub Woofer is connected. Experiment between the YES and PLUS settings and leave it where it sounds best to you.
If this was helpful, please rate it "4 thumbs up" - thanks & good luck!
Aug 04, 2011 | Pioneer VSX-D514 Receiver
Cerwin vega passive subwoofer model sw-12b
Passive woofers are hooked up to the output of a sub amp.
Active woofers are hooked up to the sub out of a receiver. They have the amp built in.
Mar 09, 2010 | Cerwin Vega Audio Players & Recorders
SA-AX720 no subwoofer signal?
THIS UNIT HAS NO SUB WOOFER AMP IN IT. THE ONLY WAY TO OVER COME THIS IS TO HOOK THE LEFT AND RIGHT FRONT SPEAKERS STRAIGHT TO THE SUB WOOFER AND THEN GO FROM THE SUB WOOFER BACK TO THE INPUTS ON THE BACK OF THE UNIT FOR THE FRONT SPEAKERS. THE SUB WOOFER THIS WAY WILL EXTRACT THE BASS AND THE FRONT WILL RECEIVE THEIR PART. THIS SOUNDS CRAZY AS HELL I KNOW BUT THAT'S HOW I GOT MINE TO WORK. THE OUTPUT FOR THE SUBWOOFER IS USELESS AND PUT THERE FOR YOU TO HOOK UP AN AMP FOR A SUB WOOFER. EVERYTHING HAS SHORT COMINGS, AND THAT'S THE ONE FOR THE AX-720.
Sep 22, 2008 | Technics SA-AX720 Receiver
RCA Sub-Woofer
Did you try making sure the subwoofer is turned on under the set up menu on the Sony Receiver?
Press Set Up, Press the left or right button above the scroll wheel until you get to SW. It should say SW: ON or SW: OFF. If it says SW: OFF, use the Scroll wheel to scroll right until it says SW: ON. Also, make sure you aren't in 2CH mode, try A.F.D or surround sound.
Jul 26, 2008 | Sony STR-DE445 Receiver
Sw 300 powered sub woofer
It sounds like your subwoofer acts as a receiver in its own right. Many low-budget home theater systems act this way, and it may in fact have a Dolby Pro Logic II encoder in it. Your best bet is to hook up either the speakers it came with, or purchase speakers from your local audio visual store. Check its power rating per speaker (in watts) in your manual, and purchase speakers that are rated for it.
The "red and white" input you mention are RCA connectors, and should allow you to connect a source to your system. If you have any more specific questions, please post them here.
Dec 31, 2007 | Kenwood SW-303 Speaker
JVC RX-809V
Go to the following website www.servicemanuals.net where you can get the service manual for $17.00, unbelieveable, don't you think? The service manual should help you sort out your hookup problems. Good luck.
Jun 10, 2006 | JVC RX-818V Receiver
Sony STR-DE475 Receiver Logo
132 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
