Question about Sony BRAVIA KDL-52X2000 50 in. HD-Ready LCD TV
Many horizontal lines running through left half of sony 50 in lcd 1080
melnavz
  • 1226 Answers
SOURCE: Dark horizontal lines on Sony KLV-26HG2 LCD TV screen
If you can fix it by yourself, there is a problem in horizontal circuit panel, you need to check that in series because the part appear visbly good but when tested by the exact tester you register busted. that should be replaced immediately. Check also the vertical panel parts of the circuit. but if hard you do the job you may consult the service center of your TV or the vendor of the TV.
ps. please don't rate me if you are not convince of my suggestion.
best regards, melnavz
Posted on Apr 08, 2008
SOURCE: 12 little horizontal lines in Sony Bravia KDL-52W4100
we have the same exact tv and it is not even a year old. we are told that it is the display panel and it is a well known problem with this tv. we were also told that there is a shortage of these parts. they had 283 on order, but only received 35. you need to call sony and tell them that you have this problem. they should warranty this for you even if your tv is 3 months past the warranty period. since this is a well known problem with this tv, keep on them.
Posted on Nov 24, 2009
Testimonial: "It in fact was a part of the lcd panel...the t-con board. I was able to research it and bought a box of parts off of a tv like mine and fixed it. Ron"
welcomejee
  • 10594 Answers
SOURCE: The top half of my Sony Bravia 32" screen plays as
I'm sorry, it sounds problem with lcd panel (screen) that is defective and causing lower half distorted image. If tv is under warranty then call number written on warranty documents for warranty cover or lcd panel (screen) replacement would cost you approx 80% of new tv price.
Hope these info will help you.
Thanks.
Posted on Nov 09, 2010
welcomejee
  • 10594 Answers
SOURCE: The left side of our
Symptoms that described indicates problem with lcd panel (screen) however, t-con board that provides digital video signal to lcd panel could also be defective and causing such problem.
T-Con board replacement by tech might solve tv picture problem in less amount but mostly it is lcd panel (screen) problem and its replacement would cost approx new tv price.
Hope these info will help you in decision.
Let me know if you have additional question.
Thanks.
Posted on Dec 24, 2010
AJIN G
  • 6694 Answers
SOURCE: horizontal,wavy lines on sony xbr4 52" sony lcd tv
hi,
check the ground connection of your house wiring. fist of all remove all the external input like set top box, cable connection, dvd etc from the tv. Then power on the tv and watch is the wave is there or not. if it there then ,if the tv power cord comes with three pin connector then remove the earth connection on the wall outlet socket to which you connect its power. the connect the power and switch one the tv.
if the wave will not appear then connect external devices (set top box, dvd etc) one by one and watch which device produce this wave in the tv. also check the ground connection of that device which produce this wave.
If all these will not help full then the SMPS power supply of your tv have some problem. Normally this type of complaint arises due to the faulty Main filter capacitor. you can see it in the power supply.. It will be the big capacitor according to others. Normally There will two or more. replace the same. will solve this problem. if you need any more assistance feel free to contact me through fixya
ok
Posted on Mar 05, 2011
Why half screen is ok, other half I.e. bottom part horizontal lines are seen.
Your LCD or Control Board is damaged. You can replace the LCD or the Board or have someone do it for you.
Aug 03, 2015 | Sony KLV-32BX300 SERIES BRAVIA LCD...
Horizontal shadow line
It sounds to be a back-light fault. Check the backlight inverter board, and back light. To get more details, http://electronicshelponline.blogspot.com/ Pull up older posts.
Nov 30, 2013 | Sony BRAVIA KDL-46W3000 Television
Sony HX750 has green line running vertically all the way down left hand side and black line running horizontally across top of screen
The fault is with its main power regulator section circuit itself. Check all the electrolytic capacitors there. Replace them. Replace the main filter capacitor too.
Jan 18, 2013 | Sony 46 " Bravia Hx750 Series 3d Led Black...
My hitachi plasma 1080 tv has black horizontal lines on the top half of the screen
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1000 posts to different brand TVs now. Pull up older posts there. Faults to Plasma TVs are described in detail there. Check it. Just see, almost all Plasmas are built on same type chassis and board configuration, so the fault to these sets too will be almost the same in nature.
Oct 24, 2012 | Hitachi P50H401 50 in. Plasma HDTV
What causes horizontal lines across tv screen
The horizontal lines on the screen is a symptom of failing LCD panel, it will get more lines as time goes by.
Dec 12, 2010 | Sony BRAVIA KDL-52X2000 50 in. HD-Ready...
Thanks.
Nov 09, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Blue horizontal line on my lcd tv
change the channel up 7 times and go back to the station
Nov 14, 2009 | Televison & Video
W580i most of screen taken up by vertical and horizontal lines help. already reinstalled the sw from the sony media mgr
More than likely you will need to replace the display screen. Those lines are a symptom of the LCD screen going bad. If you are still under warranty, see if you can get it replaced
If not, a new LCD screen runs about 15 dollars shipped from eBay and is pretty easy to replace.
Check out the following link for instructions on replacing the LCD display and links to buy the screen.
Sony Ericsson W580i LCD Display Replacement
I hope that helps you out
May 31, 2009 | AT&T Sony Ericsson W580i Cell Phone -...
Grey line horizontally across screen
yOU ARE HAVING A PROBLEM IN HORIZONTAL CIRCUIT OR IN YOUR POWER SUPPLY kindlyu take your T.V tO A QUALIFIED TECH to repair it.ypur problem could be a faulty capacitor ,flyback or horizontal output transistor.
Feb 16, 2007 | Sony WEGA KLV-26HG2 26 in. HD-Ready LCD...
Sony BRAVIA KDL-52X2000 50 in. HD-Ready LCD TV Logo
16 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
