-   my thing was working just fine but now its like it doesnt have any power connected to it i think its a problem with the adaptor or smtin please help
-   backstroker
Apr 20, 2008
-   i cant get my wireless light on help?-   dork94
if your wireless zero is turn off then you do this. Go to start then to control panel. There you should see administrative tools. Once you click onto that double click onto services. This will open a page for you to scroll down to wireless zero configuration. Make sure that is set to automatic and it's started. Often a restart of the wireless zero fixes it Also make sure windows is configuring your wireless network. To do this go to the control panel and then to your network connections. Right click on your wireless network card and then left click onto properties. Make sure the check mark is in use windows to configure my network settings. This should work for you then. Let me know if that works for you
I have a problem with my Colubris installation: As long as the accesspoints are on the same subnet,...
(More)
I have a problem with my Colubris installation: As long as the accesspoints are on the same subnet, everything works fine. When I put an accesspoint on a different subnet, the wireless users (connection via an employers SSID eg. only authentication) get an IP-address and all, but cannot access anything on their LAN. Any ideas? :)
I have an edimax ar7265wna wireless adsl/modem router that came bundled with an edimax wireless pci...
(More)
I have an edimax ar7265wna wireless adsl/modem router that came bundled with an edimax wireless pci card. The problem I have is that my 2 pcs will only connect if I dont have wpa activated. I have turned off the firewall but that didnt help. my os is win7
2 Power adapters have died in a period of 2 days ... The radios have functioned since 2005 ..is it...
(More)
2 Power adapters have died in a period of 2 days ... The radios have functioned since 2005 ..is it possible that the radio equipment has a problem or just the Power adapter. Also I tried a Power injector that output 24 Volts as a temporary solution as I wait for my supplier to deliver the Motorola branded Power adapters , but this fabricated adapter has refused to work ... are the motorola canopy 5.7 ghz set to work only with motorola branded Power adapters ? I have a network tht is down now for 4 days .. plse advice
