Question about U-Line Refrigerator Ice Maker
Water leaks inside unit wher selenoid calls for water
  • 286 Answers
The fill tube that goes into the water cup of the icemaker make sure its in with a clip on the cup to hold it downwards. Sometimes the clip is off and the tube sprays out of the icemaker. Also check to see if flakes are in the ice. That would mean that the teflon is peeling off and forcing the water out of the icemaker.
Posted on May 14, 2009
My 95 Honda odyssey isn't holding the coolant or
did you check the water pump for leaks if you do not see coolant on the floor a good posibility you have a head o head gasket problem, first check for the obvious like coolant reservoir, cap, water hoses for any leaks: Remove oil filler cap and inspect if it has a white milky goo on it inside filler cap then you have a head gasket leak
Sep 20, 2014 | Cars & Trucks
Why is my keurig 560 leaking water from the base
Most likely the water lines inside your unit are leaking. If you can take the bottom of B60 off and look inside the unit. Usually, the line that comes off the water pump is leaking at the T connector. If not leaking there look for other signs of leaking while the bottom is off. You can call Keurig 800 number to see if your unit is still under warrenty. Hope this helps.
May 28, 2014 | Keurig B60 Coffee Maker
Wher is it leaking
slide a piece of paper under the unit when the floor is dry, fill some water and peer underneath the unit, when you notice water drops this location will indicate your leek location, lay unit on its side and track down the leek
Jan 10, 2012 | Maytag Washing Machines
Water keeps dripping from dispenser
HI,CHECK THE SELENOID WATER VALVE LOCATER IN THE UNIT COMPARTMENT ,PROBABLY THE DUOL SELENOID VALVE IS BAD..
Jul 05, 2011 | GE Profile 23.3 Cu. Ft. Counter-Depth...
Leaking from inside unit
What is leaking? If it is water, you need to find the drain pipe leading from the inside unit to the outside of the house, and open up the obstruction in it. You could push a wire up through it, or send some compressed air up it. The drain pipe is probably near the ground next to the foundation or in the ceiling of an outside porch.
If this is a window unit leaking water you need to clean the obstruction out of the drain pipe or hole on the outside of the window, probably at the bottom outside rear of the unit.
I wasn't sure from your question if it is leaking water, or leaking refrigerant gas. If it's the gas you probably need to call an A/C repair service.
good luck,
genetuck
Jan 15, 2011 | Carrier Heating & Cooling
Water leaks when washer is filling up
The hoses are locted in the back do not open the top you may need to just replace the hoses,check intake selenoid
Jul 05, 2010 | Maytag MAV7580E Top Load Washer
WM1814CW Front Load Washer: my machine is leaking, i been told that that part ...
Yes that could very well be your problem . is there water leaking under the machine?
May 03, 2010 | Washing Machines
Aprilare 400 - will not run
it could be the solenoid or the motor,also if it runs but does'nt get water check the float switch
Feb 06, 2010 | Aprilaire 400 Humidifier
My kenmore refrigerator 106.56166500 quit dispensing water. Icemaker works fine. I disconnected the water line at the bottom of the front door via the quick disconnect and I get water from the supply side...
The line inside the freezer door is frozen . Turn the temp in the freezer , to warmer for a few days , and it should thaw . A dispensor heater is available , pt # WR49X10173 . Instructions come with the part .
Nov 11, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Front load washer fills up with water
Jamesbestor,
The water fill selenoid had junk in it holding the valve open or the seat in the valve is damaged.
Turn off the power and water, remove two screws on the back of the machine and remove the lid.
On the back left top corner are the water fill selenoids. Remove these and disassemble by undoing the 6 or 8 screws ( depending upon model ) holding the unit together. Clean and reassemble, it should take care of the problem. If not, replace the selenoid.
Feb 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
U-Line Refrigerator Ice Maker Logo
82 people viewed this question
Top U-Line Refrigerators Experts
mike cooper
Dale Copeland
Dale Copeland
billconfused
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
