Question about Oster 4134 / 4126 Classic Beehive Work Top Blender
Osterizer blender problem
Recently I have had a problem with this blender, basically the blade doesnt spin though the motor seems to be fine as the drive pin does spin. I am guessing it has something to do with the contact between the black plastic part which screws into the glass portion and the drive pin. Any thoughts greatly appreciated. Thank you.
I experienced the blades freezing after making smoothies and letting the unit sit for some time. I believe the problem was sugar seeping into bearing interface and solidifying. I soaked the blade assembly in water and they freed up.
I plan to add water to container when cleaning and will operate it until clear water seeps out the bottom of the bearing.
Any other ideas?
Posted on Sep 04, 2012
    Problem Solver:
  • 5 Answers
Is the black plastic part, seal, and glass portion snugly fitted together? If so, it's likely that the black plastic part isn't making contact with the pin. On mine I have to turn it about a quarter turn to lock it to the motor/ drive pin.
If I have a hard object such as ice cubes too firmed placed in the blender against the blade and the glass, I shake the container to loosen the materials and reseat it onto the drive pin as mentioned above.
Posted on Jun 14, 2009
I have a waring pro blender Model WF2111211 It's glass he blade part doesnt come off. motor runs fine but blade really tight won't spin so the motor smells burn out trying to get it to free.
Heat up a cup of water in microwave until boiling in a two cup Pyrex measuring cup. Add one more cup of tap water. Our it in the blender and let it soak. If it doesn't work, repeat but with less tap water.
Sep 15, 2015 | Waring Blenders
Blades on ninja blender won't spin, but motor seems to be working.
I don't have one, but inspect the shaft, it looks like there is a key on the shaft, then inspect the inside of the blade where it goes on top of the shaft, see if it looks like the shaft has spun out the blade and this is why it's not spinning.
Remove the blade and the container, then turn on and see if the shaft is spinning, it should be most are a direct drive.
So now if the shaft is spinning, that most likely means that the blade hole is broke where it sets on top of the shaft.
Look closely at the inside of the blade, you should see some type of damage like the groves are worn, I hate to see you buy one and it was the shaft that wore, but usually the blade will go first.
Mar 31, 2013 | Blenders
Ninja blender blade wont turn with food in container.
make sure blade is pressed tightly onto shaft... should click into indent. if not then you need a new blade piece.- stripped
Aug 18, 2012 | Blenders
My wolfgang puck 1.6 hp professional blender will not spin the blades if there is anything in the blender container.
This is not really the solution it is just a better description of the problem that I am also having. This is a great blender however the part where the cup blades conect to the motor is made of plastic.
So what has happened here is that the motor is fine, the cup is fine only the plastic part that makes the motor turn the blades has worn down therefore rendering the blender useless. I would like to know where I could get this small part to change on my blender!!!
Jul 30, 2012 | Wolfgang Puck 1.6 Hp Professional Blender...
Unit seems to work fine, but when the pitcher is attached, the blade hardly spins. It seems like it is loose or something. I can manually spin the bottom piece of the blade assembly, but the blade itself...
Depending on the age of your blender, a new blade assembly may be available. I would recommend calling Kitchenaid Customer Service for pricing. Their toll-free telephone number is:
1.800.541.6390
Jul 27, 2009 | KitchenAid KSB3 Classic Work Top Blender
Connection between the motor and the blender unit (where the spinning takes place) - get extremely hot and blender does not seem to blend well. Motor works fine without the top - and the top seems to spin...
Replace the blade assembly immediately. They are available from Cuisinart's website. Sugars and other stuff can gum up the blade assembly over time, so it will periodically need to be replaced. A quick and easy way to keep the blade assembly clean and working longer is to put water and a drop of dishwashing soap in the blender after use and run the blender at low speed for 15-20 seconds - an old Osterizer trick.
Jul 15, 2009 | Cuisinart CBT-500 SmartPower Premier Work...
Replacing the part that connects the motor to the blades on an Oster blender
I don't know if this will help or if this is what you are looking for. But today I was searching the web for the bottom piece that fits on the jar and saw this website has a lot of replacement parts for Oster blenders. Hope this is what you're looking for.
Good Luck
http://www.goodmans.net/get_item_os-070_square-drive-pin-for-oster-osterizer-blenders-shor.htm
Sep 12, 2008 | Oster 6803 14 Speed Blender
Osterizer
Thanks to some good leads, I determined the cause of the problem and ordered a part. Hopefully, that will resolve the problem.
Apr 23, 2008 | Oster 4134 / 4126 Classic Beehive Work Top...
Osterizer Blender
You can replace the Osterizer "Standard Blade Assembly" (which includes a new rubber gasket) without buying a new and expensive glass jar. See http://www.householdappliance.com/blenderparts.html or one of the other appliance repair parts websites. After 20 years of use, it's time for a new blade and bearing.
Feb 27, 2008 | Blenders
Oster 4134 / 4126 Classic Beehive Work Top Blender Logo
909 people viewed this question
Top Oster Blenders Experts
Dan Webster
Dan Webster
Dave
Dave
Angel Joseph Jr.
Angel Joseph Jr.
Are you an Oster Blender Expert? Answer questions, earn points and help others
