Question about Shotz Peak PKC0TR 30 LED Rechargeable Worklight
Where do i get a replacement charger - Shotz Peak PKC0TR 30 LED Rechargeable Worklight
Gateway 522 series not turning on after hours of charging not using included charger
If you see lights when you connect the charger, then its not the charger. If you dont see any lights on the device when you connect the charger, then replace the charger. Otherwise replace the battery.
Nov 08, 2014 | Computers & Internet
Why doesn't my battery charge? Why doesn't the charger's light come on?
Hi Suzanne! Follow these steps to check that your charger and battery are working properly.
1. Unplug the charger for at least 30 seconds.
2. Plug the charger back in. The blue light on the charger should flash once.
If the blue light flashes once this is an indication that the charger is still functioning properly. If the blue light does not flash, the charger will need to be replaced. Follow this link to order a replacement charger. LiNX Battery Charger
3. Place the battery in the vacuum and turn it on for 30 seconds. (even if it does not turn on or powers off)
4. Turn the vacuum off.
5. Remove the battery and place it in the charger.
If the light on the charger is solid blue this is an indication that the battery has been reset. Allow 3-4 hours for the battery to fully charge. The blue light will start to blink slowly to indicate the battery is fully charged.
If the light on the charger is flashing blue or there is no light at all this can mean that your battery needs to be replaced. Follow the link to order a replacement battery. LiNX Lithium Ion Battery
Hope this helps!
Jul 28, 2014 | Hoover Platinum LiNX Cordless Stick Vacuum
Will a ryobi 18 volt charger replace a coleman powermate battery charger?What's your problem?
They look different in their shape where the battery goes so I would say no. To be safe always use the charger from the same manufacturer. There are a few different types of batteries too so it is always best to use the model number of your original charger to search for the replacement.
Aug 08, 2012 | Coleman Cable Coleman 18 Volt Combo Drill...
I am needed to find a replacement charger for a wahl rechargeable clipper Model # 8552 It says that it need to be a PCC charger only. Need to know where and how much it would be.
i need a wahl replacement charger PCC as well!!! if anyone knows how to get on let me know because Wahl No Longer sells the clippers so they don't sell the charger now! that sucks wahl !! they should be able to sell you the charger when the charger goes bad like mine did ! it had a short in it and i accidently threw it away!!! now i don't know how to find a replacement charger?thanks
Jan 14, 2011 | Wahl Health & Beauty
Why doesn't my htc phone charge while plug in?
First, you need to check to see if the problem is with the phone - the battery - or the charger.
If you have a car charger, try to charge the phone with it. If it works, you'll need to replace your home charger.
If the car charger doesn't charge the phone - you'll either need to replace the phones battery or your home charger. (Sometimes the battery will go bad if you use a car charger not made specifically for the phone.)
If you replace your battery and it still doesn't charge you'll need to replace your home charger.
If after you've replaced the battery and the home charger and it still doesn't charge - your problem is with the phone and it will either need to be replaced or repaired.
Apr 07, 2010 | HTC FUZE Smartphone
Need charger
The replacement DM-XM2 replacement battery charger is @ http://www.ebuybatteries.com/product/battery_chargers/Canon/Canon-BP-941-AC-charger.htm , note it is an extern battery charger, not a power adapter.
Sep 12, 2009 | Canon DM-XM2 Mini DV Digital Camcorder
What is the replacement fuse for a Ryobi 18v charger?
The fuse in mine said 4 amp. I have also used. You can use a 4 amp or lower to replace the original one that blew.
Good Luck
Mar 07, 2009 | Ryobi Multi-Volt Battery Charger
Shotz Peak PKC0TR 30 LED Rechargeable Worklight Logo
Top Shotz Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Shotz Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
