That code indicates that there is a problem with the waste toner bottle either being too full, which means that it must be either emptied or replaced, or that the sensor that senses the amount of toner is defective. You should have got an E-31 code in conjunction the C-7 980. the only thing that you can do is change the waste toner bottle, after that you're going to have to get technical help in person. Sorry. Let me know if this helps.
Don't know how to make the second sort option work. The option is to rotate every other set of...
(More)
Don't know how to make the second sort option work. The option is to rotate every other set of copies 90 degrees. It will only sort, not rotate, loading second drawer with paper rotated did not work.
Hi, I am receiving an E-1 error message on my FT5832 copier.Then when i press gain to (,)to know...
(More)
Hi, I am receiving an E-1 error message on my FT5832 copier.Then when i press gain to (,)to know more about this eror i receive 41.. please give me a solution thnk u
getting printer under preparation and can not print to it. This is a sharp ar-810 and I have a...
(More)
getting printer under preparation and can not print to it. This is a sharp ar-810 and I have a Parallel cable hook to it
It pulls the paper back as another pap[er comes out also making a very funning noise when it moves...
(More)
It pulls the paper back as another pap[er comes out also making a very funning noise when it moves to print. Also would love to buy another hp 190 copier
