Question about APC Back Ups CS 350 (252545) UPS System
How can you bypass the timer circuit of apc es500?
The APC es500 shut off every 30 minutes
SOURCE: APC ES350 strange noise
My solution was to unplug everything, hit the reset button, and then power the unit back up. The problem I found to be that I had my laser printer connected to the "surge + battery" side, and for some reason no laser printer can be connected to it.
Posted on May 28, 2009
  • 25 Answers
SOURCE: APC BR800 Overload light with beeps
Your main control board is defective, you need a new unit.
Posted on Jul 11, 2009
jvpacoin
  • 91 Answers
SOURCE: apc smart ups su1000, su750i and sua700inet circuit diagram
you mean you need a circuit diagram for the following APC unit? i dont think so if you can get unless theres one MF from APC manufacturing or service center that can give it or sell it to you. beacuse as far as i am concerned it is punishable by law to sell or to give copy of all circuit diagram of APC products. Good luck
Posted on Aug 14, 2009
jvpacoin
  • 91 Answers
SOURCE: APC back-ups es500 alarm continuously sounds why
It means it has an internal fault. if still under warranty period, just call APC and ask for replacement. if it out of warranty bring it to service center or better if you have to buy a new one because as far as i am concerned repair cost of this unit is much expensive than a new unit
jvpacoin
  • 91 Answers
SOURCE: Overload light in APC RS 800 UPS
it seems that the inverter circuit of your UPS is dying. the solution here is you have to open up the UPS and check the inverter circuit. to make easier, check the power mosfet if its leaking.
Hi, i have an APC UPS with model BE 500R PH how to bypass the auto shutdown of it?
On mine, until an electrical storm, was controlled through my computer via USB. Now, it shuts down in 5 seconds. I'm sure it's the thermistors, but I don't have time. Also, check for timing circuits.
Apr 26, 2015 | APC Computers & Internet
Apc symmetra px stuck on self test
Place UPS into internal Bypass (Static Bypass) via the display. Then place unit back to Normal from Internal Bypass(Static Bypass). See if that helps. Or shut the unit down completely by placing UPS into Static Bypass first and then place UPS into external bypass mode, switch is located on the bottom front of the UPS. Please follow the UPS Manual to help you understand the procedures. Also recommend doing this after hours, not during business hours.
Jan 15, 2014 | APC Symmetra PX (SYCF80KF) UPS System
What is the problem of my UPS APC es500 when buzzing continously? please help me to solve my problem. thanks!
short circuit may be happen to your UPS. try to open your UPS and look for the short circuit or try to call a electronics service technician... :))
Feb 23, 2011 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
We have apc es500 we used almost 2 yrs and now its not working, possible to repair? but if not do you have any idea where we can sell it for disposal. thanks
Contact APC.com
Here is the page for your model , it looks like it qualifies for the tradeups program. Or you can purchase a battery for it and fix it yourself.
http://www.apc.com/tools/upgrade_selector/index.cfm
Jul 13, 2010 | APC Back-UPS CS 500VA UPS System
APC ES500 switches off and the red light blinks. The problem started after I changed the the old battery. It had worked flawlessly with the previous battery.
The battery for this unit is an APC# $^ (RBC46)
Also known as a UB-1280 (12 volts 8.0 AH- amp-hour)
Did you add a greater load ... like a small "heater"?
Remove most of the plugs for what is plugged into it and try again.
If you have a "printer" plugged into it, unplug it, from the "protected" side. It belongs on the "surge" side of the APC Battery backup.
Hope this helps!
Sep 15, 2009 | APC (BE500U-WEB) (BE500UWEB) UPS System
Apc smart ups su1000, su750i and sua700inet circuit diagram
Aug 04, 2009 | APC (BE500U-WEB) (BE500UWEB) UPS System
My APC back-ups es500 is keep on flashing in orange and green having the beep sound, whe it is on. It has been used for nearly 3 years. What would be the problem...?
Probably the battery is drained. You should charge it first. And if the problem still persist, it could be that the UPS battery needs replacement.
Aug 01, 2009 | Computers & Internet
APC UPS 1500 w/full load forces immediate reboot at pwr failure
With a 980watt load the run time is only 7 minutes on a brand new battery. If you have the system on full load your run time will be much less and it has likely damaged the battery. here is the APC web site page for your model. If you are running that much equipment I think you need either a bigger UPS or another 1500 and spread the load out.
Buddy
Corporate Computer
Jul 24, 2009 | APC Smart-UPS 1000VA UPS System
APC back-ups es500 alarm continuously sounds why we power it off and alarm stops everything works fine then we power it back on and alarms sounds again
Jun 22, 2009 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
APC Back Ups CS 350 (252545) UPS System Logo
Top APC Computers & Internet Experts
Shawn DuRee
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
