Question about Paintball Tippmann U.S Army Alpha Tactical Mod Kit
Need manual for Predator Board
Trying to fine a manual for my paintball gun... i have a angel 04 with fly internal the mother board in it is call a predaor board....if you guy can have me that would be great....
Try this
http://www.alternativepb.com/manuals/tagdm4board.pdf
Posted on Jul 08, 2009
My paintball wont stop shooting but it has nothing to do with the co2 tank help?
The sear is not catching the bolt and resetting it properly. Or, there is not enough air pressure to push the bolt back to its original position. I would take it to a gunsmith. Parts fly out of a Tippmann if you open it up.
Jun 16, 2014 | Tippmann 98 Custom Act Paintball Gun
Tippman A-5 with low pressure kit, e-grip. When pull the trigger gun shoots fully auto until I manually stop it by re cocking the gun.
Sounds like the gun needs lube. Oil it and try again. 2-3 drops of oil in the hole
where the tank screws on then put the tank back on. Fire it and see how it does.
I havent heard of a low pressure kit for the A-5 but I think it is a waste. There is a rule
with pressure and paintball guns. Low pressure=high volume of air used.
Standard pressure=regular volume. I have 2 a-5's with e-grips and flatlines.
I polished the internals by sanding the bore of the tube (use fine sandpapaer) and
this makes the velocity very consistent.
One thing that comes to mind is that the hammer may not be getting caught on the
trigger latch. Makes sure your gun is assembled correctly. here is your manual.
http://www.tippmann.com/pdfs/products/A5/a5manual.pdf
Feb 15, 2011 | Tippmann A 5 Standard Paintball Gun
When I try to **** my gun, the valve makes a cracking noise, and doesn't move.
Sounds like it is put together wrong. Take it apart and follow the diagram to put it back together
or head to your local shop and have them help you. Make sure to oil the internals.
Here is your manual.
Jan 06, 2011 | Tippmann 98 Custom Act Paintball Gun
Do I have to take the gun apart to get the battery in the gun??? and also before i was done with the gun my brother put the paintballs in the hopper but for some reason they were falling out of the...
No, you didn't do anything wrong...
Paintballs come in a variety of sizes. That difference is very hard to see with the naked eye, but your barrel knows what fits and what doesn't. Players have a choice in barrels and ID-internal dimensions, so the balls are various sizes as well. You will have to sample a few brands and see what works best for you.
Play hard, play safe, play with honor!
8^)
Nov 03, 2010 | Tippmann 98 Custom Act Paintball Gun
My gun wont shoot. Ill **** it once and it will fire a dead shot then not recock
Time to lube (oil) the gun. A few drops of oil in the inlet hole (where you screw on your tank) should do and then dry fire the gun. If no luck you may need to tear down the gun and clean and lube the internals.
http://www.paintballadvisor.com/manuals/Tippmann%2098c%20manual.pdf
Oct 06, 2010 | Tippmann 98 Custom Act Paintball Gun
98 Custom Act Paintball Gun: i want it to go fasteer...
I can take that a couple of ways. Do you mean you want to fire more balls per second or you want the paintballs themselves to fly faster?
If you want to fire faster, make sure it's clean and properly lubed with a quality oil that made for paintball. Practice makes perfect and fire that ****** as often as you can, even without paint (that's cheaper!) so you can get your trigger finger in shape.
There are custom mods to the trigger, or you can buy a trigger that's smoother or a shorter pull. There are electronic trigger assemblies that make firing faster even easier.
If you're talking about making the balls fly out of the gun faster, that would be the "velocity adjustment". Your user guide shows you how to make that adjustment and which direction is up, and which is down.
A good suggestion is to check out a local field or paintball store, or an airsmith and they can give you some definite ideas you will want to pursue.
8^)
May 17, 2010 | Tippmann 98 Custom Act Paintball Gun
Paintball gun is rapid firing when trigger is pressed. CO2bottle is full and i have tried other bottles but stillth same.
Tippmanns are known for their reliability and are very simple markers making them very easy to repair. you need oil from a local paintball shop or regular sewing machine oil will do.
On one side of the marker there is a little "handle" for cocking the gun, pull that handle as far back as you can and you will see 1 o-ring. put 2 drops of oil on it and fire it a couple times without paintballs to test it. This solves the problem 9/10 for tippmanns, if not..
Sometimes paintballs can break inside your gun. Look and feel inside your breech (where the paintballs go into the gun) and check for paint. If its dirty this can be causing your problem, strip it down and clean it (refer to your manual if you have difficulty)
on one side of the marker there is a little "handle" for cocking the gun, pull that handle as far back as you can and you will see 1 o-ring. put 2 drops of oil on it and fire it a couple times without paintballs to test it. This solves the problem 9/10 for tippmanns
Jan 08, 2010 | Tippmann 98 Custom Act Paintball Gun
Paintball Tippmann U.S Army Alpha Tactical Mod Kit Logo
334 people viewed this question
Top Paintball Sport & Outdoor - Others Experts
Are you a Paintball Sport and Outdoor - Other Expert? Answer questions, earn points and help others
