I need to internally reset A sharp XV-Z2000......service center is too far away. Client needs there projector ASAP. Please help
  • 1 more comment
  • inexsystems May 09, 2009
    Iversh, they didnt reset after they changed the bulb. So now it won't come on. I aqm supposed to take to a service center so they can internally reset it, But it can't be that hard so I want to do it myself.
    I need to internally reset a sharp XV-Z2000 projector. Not manually reset. I changed the bulb, but they did not have the manual and contiued to use. Now projector wont turn on it needs to reset internally.
    Its not that. The projector worked after I installed the new lamp. But I didd not hnave the manual to reset it, so the projector counter kept going until it hit the critical mark. And now it won't turn on I talked to sharp they said needs to go to a service center, but I know I should be able to open it up and reset it myself.
  • 130 Answers
Here's a link to the Operation manual:
http://www.sharpusa.com/files/hom_man_XVZ2000.pdf
Start on page 58 for replacing the lamp AND resetting the lamp timer. Note that the power won't turn on if the lamp AND lamp cover are not installed correctly.
Posted on May 09, 2009
  • Steeler Ed May 09, 2009
    Oh, it's totally out. It actually needs to be "reprogrammed" by Sharp service center. It's nothing that you will be able to do yourself.
    President:
  • 1,197 Answers
I unplug my cord, waited for 5 minutes, then reconnect cord holding the power button at same time, released, then proceded with input, left arrow, enter, right arrow and depress power button again holding for 15 seconds, then released. projector warmed up showing the  "0000H" on the bottom left of screen...that's how mine worked
or if that doesnt work........
make sure that u have a blue screen, then select as follows:
ON --- INPUT --- UNDO --- < --- ENTER --- > --- ON
Make sure you "depress" the left arrow < -- then ENTER -- then right arrow >. Good Luck
here is the URL the the service manual if you have lost yours.
http://www.solar.sharpusa.com/files/hom_man_XVZ2000.pdf
thank you have a nice day
Sharpvision XV-Z2000 No red color in picture.
Hi This is most commonly caused by a loose or broken video cord. Check to make sure it is not loose or broken.
Oct 19, 2012 | Sharp XV-Z2000 Multimedia Projector
I am replacing the bulb on my sharp xv-z2000 projector. i replaced it fine but the power light and the bulb light both stay red and i cant even turn the projector on. how do you reset the projector?
Two red lights indicate a problem with the lamp circuitry, i.e. the ballast. This requires a service center to change out a circuit board. Given the cost, it might be time to look for a new projector.
Dec 04, 2010 | Sharp XV-Z2000 Multimedia Projector
How do I reset...followed instructions but still will not turn on
Do any lights come on when you plug in the power cord? If the power and lamp lights both glow red, the problem may be in the "ballast" circuit. The projector will have to go to a service center.
Sep 26, 2010 | Sharp XV-Z2000 Multimedia Projector
I need a parts breakdown for a sharp xv-z2000 projector. I think I have a broken internal mirror, but I'd like to know the correct disassembly procedure.
It's been a while, but in case you or someone else needs this information: The only quick source I could find for a service manual on this unit was the web site nodevice dot com. They charge something like $8 for 24 hours of download access, so work up a list of all the service manuals you might need and get them all while you're at it.
Mar 13, 2010 | Sharp XV-Z2000 Multimedia Projector
Just changed the lamp in our Sharp DLP Projector, lamp indicator
You don't mention whether the power light is on as well. IF you are seeing red lights for both power and lamp, there is a problem with the circuitry, beyond just the lamp. unfortunately this is very common. The unit will likely need a new ballast circuit.
Mar 12, 2010 | Sharp XV-Z2000 Multimedia Projector
Color wheel for a Sharp XV-Z2000
you can get the part from a sharp service center and replace it yourself or send the projector to one for repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Dec 17, 2009 | Sharp XV-Z2000 Multimedia Projector
Projector won't switch off either with the remote
Im sorry but it needs a new switch. i can help with ording online.
Oct 26, 2009 | Sharp XV-Z2000 Multimedia Projector
Blue instead of red colour afer replacing lamp in sharp xv-z2000
You didn't put your 3-D glasses on backwards, did you? :)
Seriously, if you are using the component inputs, be sure the three cables didn't get mixed up when you put the projector back. Otherwise, you might have an issue with the color wheel inside the projector, but I doubt it.
Dec 31, 2008 | Sharp XV-Z2000 Multimedia Projector
Lamp timer on Sharp XV-Z2000 will not reset
I unplug my cord, waited for 5 minutes, then reconnect cord holding the power button at same time, released, then proceded with input, left arrow, enter, right arrow and depress power button again holding for 15 seconds, then released. projector warmed up showing the  "0000H" on the bottom left of screen...that's how mine worked today.
Feb 15, 2008 | Sharp XV-Z2000 Multimedia Projector
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
Electro Med Services...
