Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Manual for sears kerosene heater #40911
Ignition pin gap
Sears Heater Manuals
Here is a direct link to the owners manual.
http://www.allpartsinc.com/ProductDesc.aspx?code=PK115T&type=0&eq=&desc=PK115T---PORTABLE-FORCED-AIR-HEATER-&key=it
Nov 07, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
Sometimes the heater throws out raw fuel out of the burner and sometimes if I cut it off and wait a little bit it will ignite and come on and then it will work normal with the thermostat. Is there...
turn the adjustment srcew clockwise a little to raize the pressure.. check your gap on the spark plug /igniter .060. also check the air pressure should be 6.5#
Jan 23, 2011 | Reddy Heater-170,000 BTU Kerosene Deluxe
Heater blows smoke out front, wont ignite...please help!
Two things cause it ,No fire at Spark plug or low air pressure
Jan 22, 2011 | Reddy Kerosene Heater with Thermostat:...
I hava an All Pro 65,000 BTU heater. It was working fine a week ago. The igniter glows, fuel mists but doesn't light off then shuts down. Ideas?
I am sure you have confirmed that the fuel is fresh and good, no water in it, etc.--
It is kerosene, not #2 Diesel fuel, right?
And the shutting down is good, if the flame does NOT ignite--- :-)
So we have to figure out why the fuel is not getting hot enough to ignite?
Question-- is the oil spray passing close enough to the ignitor?
And this unit does NOT use SPARK to ignite?, correct? --
for most of these heaters have spark ignition.. I am learning all the time, too!
How about checking the fuel pressure. and the air -- is it correct?
Check with your manual how to check and adjust.
After testing these tings, let us know what you learned
Mack B
Jan 15, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
Vogelzang kerosene heater will not ignite (no spark)
There is an igniter module and then the igniter electrodes (check the air gap) that produces the spark to start the fuel burning, both could be defective.
May 18, 2017 | Reddy Heater-30-55,000 BTU Variable
Missing owners manual
try going to manualsonline.com it's free...
Jan 10, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
71 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
