Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer error codes f02 and e01
Both codes coming up
  • 185 Answers
SOURCE: error code f02
the f 02 means you have a long drain issue press pause/cancel twice to clear the display check drain hose make sure it isnt plugged or kinked check electrical connections at the pump make sure the pump is running check drain filter for foreign objects if the above does not correct the problem replace the pump
Posted on Mar 25, 2008
SearsTechToo
  • 261 Answers
SOURCE: Whirlpool washer error code problem
LD is long drain associated with two problems the drain hose install and the pump. Debris in the pump and a drain hose inserted too far will cause most of these issues.
Posted on Sep 23, 2008
SOURCE: error code F02 on whirlpool
Pop off the front cover (3 Torx screws on the bottom lip) After removing the cover you will see a white plastic unit with a screw on cover on the front. Unscrew the cover (no tools needed). Pull the cover off then remove the strainer. It will have gray gook on it plus God knows what else. Clean the strainer in the sink replace screw the cover back on and your in business.
Posted on Apr 18, 2009
jsrock516
  • 5911 Answers
SOURCE: Whirlpool duet washer F21 error code. Just bought
"F21" is a Long Drain error. The following link explains how to torubleshoot:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
What this usually means is that you have something clogged in the drain pump and it needs to be cleaned out. In the majority of the cases, this corrects the problem. However, if you JUST purchased this washer, and it is brand new (not used), I would recommend you use your manufacturer warranty (good for the 1st year in most cases) to avoid the risk of voiding it. The conditions of some warranties, prohibit the consumer from opening the appliance and attempting any repairs. Read the find print just to be sure.
If you have any questions, please let me know. I hope this helps you.
Posted on Jul 09, 2009
localwonder
  • 6784 Answers
SOURCE: Whirlpool Duet Mdl GHW9150PWO Washer stops
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Posted on Oct 16, 2009
What do error codes e06 and e01 mean?
E01 and e06 codes - Fixya
www.fixya.com/support/t14040885-e01_e06_codes
Aug 19, 2012 - e01 and e06 codes washer will not do anything other than lock the door. - Whirlpool Duet: WFW94HEXW Laundry : question. ... Error message E06 onWhirlpool. Unplug the machine and wait 10 minutes before restarting it.
Aug 24, 2015 | Maytag Washing Machines
What is code message F02?
Repairing the F02 error code can usually be done without ordering parts. Tools needed to repair your whirlpool Duet F02 error code are towels and a quarter inch socket.
Tip the washer back at a 45 degree angle. On the bottom panel there are three or four screws, with the screws removed the panel will slide down and off. With the lower access panel now removed you will have access to the washers drain pump clean out.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out.
With the filter out clean and install it back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back, it may require you to clean the drain pump filter again.
If you require a new drain pump motor, you can purchase the part from the link below.
- See more at: http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-error-code-f02-duet-sport-error-f02-fix/#sthash.PuGd0iuQ.dpuf
Sep 09, 2014 | Whirlpool Duet Sport HT WFW8400TW 3.7 Cu....
Why does my whirlpool frontloader stop in the middle of a cycle and read f 02
Sep 06, 2014 | Whirlpool Washing Machines
My whirlpool duet washer had a F02 code now it won't pump water
Aug 24, 2014 | Whirlpool Washing Machines
What does F02 code on duet washer mean?
Jul 28, 2014 | Whirlpool duet Washing Machines
Whirlpool front loader duet hd washer gets stuck in the wash cycle with the error code of F02. What is F02 mean?
Whirlpool Duet front-load washer F02 usually means it is taking over 8 minutes for the washer to sense that the rinse or wash water has drained, which either means that the drain/filter is clogged or the pressure switch/tube is clogged (causing both the washer to over-fill with water and not sensing that water has drained).
To clear out the drain/filter, tilt the washer backwards a little for easier to the kick-plate and support the front bottom with a wood block or similar, remove the front kick-plate's (3) retaining screws and swing the kick-plate up out of the way. The filter drain is behind the white knob in the center, be prepared with something to catch any remaining water and lots of towels to soak up any spills, and turn the knob counter-clockwise to remove the filter.
Jan 11, 2013 | Whirlpool Duet GHW9150P Front Load Washer
F- code 02
How to fix a Whirlpool Duet & Duet sport error code F02. Repairing your F02 error code can usually be done without ordering parts. Tools needed to repair your Duet F02 error code are towels and a quarter inch socket.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out. With the filter out, clean and install back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back it may require you to clean the drain pump filter again.
Dec 03, 2012 | Whirlpool Duet GHW9150P Front Load Washer
F02
The f02 error code is caused when the unit control thinks there is still water in the tub after it has tried to drain. If the washer is full of soap suds it will also display an f02 error code. You will need to use only name brand HE detergent. If your washer is not draining the water out you will need to clean the pump filter. I have provided the instructions below. Run the washer in a drain and spin to ensure the pump is running. If the washer has no water and no suds the problem will be either the pressure switch or a plugged pressure hose. To check the pressure hose you will need to remove the top and remove the hose from the pressure switch.
Jan 30, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer GHW9150PW will not drain.
Needs new drain pump. About $140. Will fix F02 / SUD error. Basically the drain pumpm isn't pumping water out. about 5 minutes to replace.
Oct 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
674 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
