Question about APC BE500R Back-UPS ES 500 (BPAPWBE500R) UPS System
How can you bypass the timer of apc es500? - APC BE500R Back-UPS ES 500 (BPAPWBE500R) UPS System
5 Suggested Answers
jvpacoin
  • 91 Answers
SOURCE: APC back-ups es500 alarm continuously sounds why
It means it has an internal fault. if still under warranty period, just call APC and ask for replacement. if it out of warranty bring it to service center or better if you have to buy a new one because as far as i am concerned repair cost of this unit is much expensive than a new unit
Posted on Aug 14, 2009
Gort007
  • 1187 Answers
SOURCE: APC ES500 switches off and the red light blinks.
The battery for this unit is an APC# $^ (RBC46)
Also known as a UB-1280 (12 volts 8.0 AH- amp-hour)
Did you add a greater load ... like a small "heater"?
Remove most of the plugs for what is plugged into it and try again.
If you have a "printer" plugged into it, unplug it, from the "protected" side. It belongs on the "surge" side of the APC Battery backup.
Hope this helps!
Posted on Sep 15, 2009
  • 150 Answers
SOURCE: we have apc es500 we used almost 2 yrs and now its
Contact APC.com
Here is the page for your model , it looks like it qualifies for the tradeups program. Or you can purchase a battery for it and fix it yourself.
http://www.apc.com/tools/upgrade_selector/index.cfm
Posted on Jul 13, 2010
  • 52 Answers
SOURCE: what is the problem of
short circuit may be happen to your UPS. try to open your UPS and look for the short circuit or try to call a electronics service technician... :))
Posted on Feb 23, 2011
Hi, i have an APC UPS with model BE 500R PH how to bypass the auto shutdown of it?
On mine, until an electrical storm, was controlled through my computer via USB. Now, it shuts down in 5 seconds. I'm sure it's the thermistors, but I don't have time. Also, check for timing circuits.
Apr 26, 2015 | APC Computers & Internet
Mge galaxy 4000 bp ss supply failed
Make sure that Bypass Phase Rotation is A-B-C. Check that Bypass voltage is within a tolerance of 208 +/-5%. Frequency tolerance is 60hz +/- 1hz.
Any condition not met, and Bypass will not be available
Apr 01, 2014 | APC MGE GALAXY 4000 75KVA-3-PH OL UPS 208V...
Apc symmetra px stuck on self test
Place UPS into internal Bypass (Static Bypass) via the display. Then place unit back to Normal from Internal Bypass(Static Bypass). See if that helps. Or shut the unit down completely by placing UPS into Static Bypass first and then place UPS into external bypass mode, switch is located on the bottom front of the UPS. Please follow the UPS Manual to help you understand the procedures. Also recommend doing this after hours, not during business hours.
Jan 15, 2014 | APC Symmetra PX (SYCF80KF) UPS System
APC Back-UPS ES500. Battery is new replacement UB1280, and battery has charge and runs fine if unit not plugged in. However, if unit is plugged in to power back-up side outlets in unit don't work.
there are 2 parts of a UPS .
the charge side
and (battery is obvious)
the inverter side.
if the charger fails, all is lost. (are the batteries in backwards?)
if the charger works (volt meter tells you that)
then the inverter is bad. (this unit is not full time UPS , but part time, this means it switches over to inverter at power fail.
(on full time sys. inverter runs full time, like the name states)
the unit, you mean the load right.?
the UPS side plugged into a load. and the load is now dead.
the Backup plugs should work if the mains are hot.
if you kill mains, the inverter will fire off, (hear the squeal?)
and give you 500 watts for some minutes, sucking the batteries dry. (see load run time curves)
I used to do service on HUGE UPS systems, some with 100s of batteries. 3 to 5kw too.
on ours there is a port on the rear , we connect and can
check everything "BEST brand" even charge voltage.
did you look on APC site for special software and connections?
the manual does cover trouble shooting, ever read that?
RTM? start there, its online, for sure.
Oct 03, 2013 | APC Back-UPSĀ® CS 500 UPS System
What is the problem of my UPS APC es500 when buzzing continously? please help me to solve my problem. thanks!
Feb 23, 2011 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
We have apc es500 we used almost 2 yrs and now its not working, possible to repair? but if not do you have any idea where we can sell it for disposal. thanks
Contact APC.com
Jul 13, 2010 | APC Back-UPS CS 500VA UPS System
Both my APC UPS units switched to bypass at about the same time. There was no one in the room at the time, as per camera and access control logs. The technician said the units were switched off manually...
there are several reasons that will make an ups to go to bypass, which include    1. overload, check the load percentages of your loads to make sure they dont exceed 100% . check logging events
               2. ups failure, if the ups is set to go to bypass whenever it detects internal failure it will do so. but it is highly unlikey becouse they went to bypass at the same time.
              3. manual bypass, somebody is involved in bypassing.
for some ups system it is possible to see the cause of automatic bypassing, try and check in the user manual to see whether it is possible with your system.
Oct 17, 2009 | APC Computers & Internet
APC ES500 switches off and the red light blinks. The problem started after I changed the the old battery. It had worked flawlessly with the previous battery.
Hope this helps!
Sep 15, 2009 | APC (BE500U-WEB) (BE500UWEB) UPS System
My APC back-ups es500 is keep on flashing in orange and green having the beep sound, whe it is on. It has been used for nearly 3 years. What would be the problem...?
Probably the battery is drained. You should charge it first. And if the problem still persist, it could be that the UPS battery needs replacement.
Aug 01, 2009 | Computers & Internet
APC back-ups es500 alarm continuously sounds why we power it off and alarm stops everything works fine then we power it back on and alarms sounds again
Jun 22, 2009 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
APC BE500R Back-UPS ES 500 (BPAPWBE500R) UPS System Logo
71 people viewed this question
Top APC Computers & Internet Experts
Shawn DuRee
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
