Question about Compaq Presario R3000 Notebook
Laptop keeps losing power at start up and shuts down repeatedly
I push the power on button and it starts to load Windows. After a couple of seconds the laptop looses power and it shuts down. Push the power button again and it starts to power up but loses power again, this time quicker.
If I wait awhile and then try to power up it lasts a little longer loading Windows and then loses power and shuts off. I try to power up again and it starts to power up and then shuts down after a couple of seconds again.
  • h1u1f1f11 May 11, 2009
    It responds the same way with or without power chord. I believe that the battery is being charged because the light will change from orange to green as if it is charged.
    After waiting overnight I was able to power up the laptop and retreive some files before it shutdown after about 2 minutes from reaching the desktop screen. The battery indicator was full and the wrench icon showing that the battery was being charged. The laptop powered off after a couple minutes.
    I tried to power up again and it would shut off before loading windows. Repeated attempts to restart and it would just keep powering off and on.
    My laptop is a Accer Aspire 7520-5311
    Scholar:
  • 85 Answers
Does it run with the power cord plugged in? if so your batterys dead, otherwise harddrive/bios/motherboard fault? is your power supply charging the battery?
Posted on May 09, 2009
I press start on laptop, windows 7 will not load up, i have to press F8 a few times to load ,windows 7
Try a cold start, unplug, remove battery, hold down on/off button for 10 seconds, replace battery, plugin, push on/off button, try to start normally. If that fails do a system resotre/ recovery.
Nov 04, 2012 | HP Computers & Internet
Starting Windows
In that case, I would reinstall Windows. Something must corrupted in windows. Do you have your OEM Windows disk with you?
Sep 06, 2012 | Dell XPS M1530 Laptop
My Aspire one will not allow windows to start and my start button is frozen so I have no access to anything. This happend right after I downloaded updates.
Have you attempted to reboot the machine? By holding the start button for 20 seconds you can shut of the power.
If that fails, remove the power cord and remove the battery. Reassemble and attempt to reboot. Failing that, load your windows CD and attempt a repair.
Aug 13, 2011 | Acer Aspire One PC Notebook
I press the power off button and it doesn't power off
You should never power down by pressing the power button unless your system is deadlocked and won't respond to any other actions. Powering off in this fashion can cause you to lose data, corrupt files, and improperly shut down Windows.
Nonetheless, if you are in need of shutting down the laptop in this fashion you must hold the power button instead of only pressing it. You'll find this in the power settings of the device. Honestly, the power button may even be set to do nothing, which is possible.
To properly shut down your new Pavilion laptop, which should be running Windows 7, follow this process: Click Start > Shut Down
Start is now simply a circular Windows icon in the bottom left corner of the screen and shut down has an arrow pointing down next to it. Click the words shut down instead of the arrow which will bring up other power save options.
Oct 17, 2010 | HP Pavilion dv7-1245dx Notebook
When i push the power button on my amilo xi1554 all the lights come on and you can hear it starting up but after a few seconds it shuts itself down and then turns itself back on and it keeps repeating this
i had the same problem and found it was a virus.
i had to reinstall the operating system and unfortunatly this meant losing all data on the laptop, but i was lucky that all was backed up on external hd.
Feb 07, 2010 | Fujitsu Siemens AMILO Xi 1546 Notebook
Screen stuck in hibernating mode compaq laptop with windows vista
Disconnect the Laptop from Power, remove the battery, Hold the power button for 6-10 seconds.
Restart the machine by connecting the power and battery, Hit the Esc key while windows is loading
Sep 29, 2009 | Compaq Presario CQ60-220US PC Laptop
How to reset a laptop CY25?
Windows XP, right? Click on start, shutdown and then restart!
Is the laptop frozen? Hold down the power button for about 5-10 seconds until power shuts off. Just press the power on again to get it to start back up. Make sure you can NOT reset soft before cycling power on your laptop because you can lose/corrupt data during a cold boot.
Hope this helps,
Bill
Sep 04, 2009 | Fosa CY25 Laptop
Laptop wont switch on fully
Did you press F8 as you boot up to get boot up options and did try the Last Known good Configuration and Safe Mode?
If these didn't work I suggest you re-install Windows.
Apr 10, 2009 | Acer Computers & Internet
Laptop starts then shuts down
As soon as you power up keep pressing F8 to get into safe mode. You will see a black screen with various options, go to Safe mode with networking, and see if your laptop stays on. If it does you should be able to go to the manufacturer web site and download latest graphic drivers, as this may be the problem. Download, then uninstal current graphics driver from add/remove programmes. Re-boot your pc and when it finds your graphics again ensure that you point windows to install the down loaded driver and not a generic driver. If you were not able to get this far, then a possible processor or motherboard failure is the answer; taking to a qualified repairer is recommended.
Dec 10, 2006 | Fujitsu LifeBook A1010 Notebook
Compaq Presario R3000 Notebook Logo
609 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
