Question about Apple iPhone Smartphone
My iphone doesnt charge
Ive just recently purchased my iphone, and when i have it low battery it doesnt charge at all, i put on the charger and m iphone doesnt even show that the battery is charging what can i dooooooooooo
    Problem Solver:
  • 10 Answers
Hi there!
There have been some reports of iPhone chargers going bad prematurely.  The test:
  1. Connect your iPhone to your computer via the USB cable.  Does it make a little beeping noise when you connect it, and then charge up?  If so, the issue is not with your iPhone or USB cable.
  2. Next, using that same USB cable, connect it to your iPhone charger.  Do you get the same connection noise and then does it charge up?  If not, the issue is probably with the charger.
Assuming you have a faulty charger, you are still well within your 1 year warranty from Apple.  Visit an Apple store (www.apple.com/retail) Genius Bar (make your reservation online before you go, to avoid waiting around), explain the issue and how you tested it out, and they will almost certainly replace the charger for you at no cost.
Posted on Oct 15, 2007
SOURCE:
I purchased a low-profile USB Car Charger for ipod, iphone and ipad and it doesn't it work!!!!!! FRUSTRATING!!!!!!
hi
you state that you have "purchased" the charger. if this is recent and particularly if the charger is new then you should take it back to the vendor for him to replace with a working unit, because clearly the one you have is "not of merchantable quality".
hope this is helpful, if so would you please register that with fixya
cheers
Jan 21, 2015 | Isimple IS45 - Low Profile USB charging...
Message on my iPhone shows icon for iTunes to plug in a charger. What do I do?
Charge the phone at least overnite. Sometimes a replacement phone may arrive with a totally dead battery and the charger may not be able to put out enough current to operate the phone and charge it at the same time. If you want it to charge faster use a plug in charger with an output rating of 2 amps. They usually have 2 USB outputs and can charge two devices at the same time. If you only charge one device it's a piece of cake for the charger. .
Sep 10, 2014 | Apple iPhone 4S
Iphone 5c
Not sure. But dod you check if the charger and the cable are correct? When you insert the charger cable the phone should give a beep, turn on for a few moments and than goes in sleeping mode. If nothing happens, please try another cable and / or an different charger.
Jul 27, 2014 | Apple iPhone Cell Phones
Iphone 3g proper charging
Once you purchase the iphone,dont use it yet.Instead of using it right away,kindly charge your IPhone with the wall charger for 3 hrs.Please dont use the Iphone while charging.Kindly check always if the battery is full.Once its fully charged then that's the time that you can use the iPhone. Once fully charged, let the iPhone's battery fully drain.Please keep the iPhone off for 2 hours.Fully charge your iPhone and allow the battery to rest in the fully charged state for two hours. (You may use your iPhone during this time as long as the iPhone is plugged in).Repeat the third and fourth step a maximum of three times if you feel your battery indicator is inaccurate.
Here are some tips for your everyday charging for your IPhone:
#1 - Charge your iPhone throughout the day when available. Charge EVERY night, regardless of charge level. This will keep your battery active, which is healthy for the iPhone's battery.
#2 - Use a wall charger or car charger w/ rated output 5V 1A. Computer chargers might not charge when the computer is in standby mode.
#3 - You cannot overcharge your iPhone. You don't need to disconnect the iPhone from the charger after it's done charging. Once fully charged, the iPhone will run strictly off of AC power and will not damage the battery.
#4 - Every two months, make sure you fully charge and fully drain the battery, in one cycle. This calibrates your battery indicator. If you fail to do this, your indicator will become inaccurate. Calibrating your battery does not improve battery life.
#5 - If you ever need to store your iPhone for any reason, make sure your battery is stored @ roughly 50% and in a cool environment.
#6 - Always charge your iPhone out of its case (assuming you can easily remove the case). Charging your iPhone inside your case will make the iPhone hotter, which is bad for the battery.
#7 - Charge your iPhone in a cool location. Charging your iPhone in a cool environment has a tremendous impact on your battery's lifespan. The colder the location you use to charge, the more charging cycles you can complete without your battery deteriorating. Avoid charging in direct sunlight.
#8 - Use properly rated chargers. Using chargers that are not properly rated will have a huge impact on your battery's lifespan. Make sure your car charger has the same rating as the official Apple charger.
The official Apple wall charger is rated as follows:
Input: 100 240V ~ 50/60 Hz 1.0A
Output: 5V 1A
Thanks!
Apr 15, 2011 | Cell Phones
I bought a portable charger for my iphone 3gs, my battery was getting low so i put this charger in and now my phone wont switch on?
The charger may not be compatible with your iPhone and the battery on your phone may be completely discharged.
Use an OEM (Apple iPhone) charger and see if it charges your phone. Do not unplug it until it is completely charged (several hours).
Dec 15, 2010 | Apple iPhone 3G
IPhone charging problem
If you are using a genuine apple usb lead, replace the charge port in the phone.
Sep 26, 2017 | Apple iPhone (16 GB) Smartphone
I have iphone 3gs. Battery got drained yesterday(1st time it got drained) and i put it on charge., it was charging till morning. It chareged only half when i saw in the morning. Then i removed i connected...
sounds like your charger is bad..you need to replace it and if that doesnt help i would contact apple or your service provider for replacement options...apple is 1800myiphone
Jan 15, 2010 | Apple iPhone Smartphone
My camcorder doesnt charge up properly, ive purchased a new batteery and charges a bit but doesnt charge to full, light keeps flashing to say somethings wrong. I put it on the pc and it seems to charge.
Is the charging of the battery part of the camera or is it a separate charger? Meaning you remove the battery from the camera and install it into the charger to charge. Of course, if the charge is not full when both batteries have been on the charger, then the charger is at fault. Also, considering that you have also put a new battery on the same charger and the problem is still the same, then the charger is (again) at fault. You can try and send the charger to the retailer for inspection or, better still, take the whole camera and get it checked. Bad batteries or charger can cause more trouble to both the batteries or the camera.
Sep 18, 2009 | Samsung SC-DX103 DVD Camcorder
My iphone 2g wont charge & wont turn on
Try using another cable or charger. A damaged charger or cable could cause it not to charge.
Otherwise, contact apple or apple store for repair.
May 06, 2009 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
323 people viewed this question
Top Apple Cell Phones Experts
Ekse
jacobcheatha
Level 1 Expert
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
