Question about HP PhotoSmart 1315 InkJet Printer
Photosmart 1315 Installed new cartridge. Test page shows no blue. No blue is coming out in prints.
  • rjbeg123 May 11, 2010
    Did you remember to remove the plastic tearaway from the printhead?
    Scholar:
  • 70 Answers
Could potentially be a defective ink cartridge out of the box (Yes, it does happen, even if they;re brand new). Try replacing that one again with a new one, and if that fails, then either the print head is dirty, in which case you can usually clean it with just a q-tip and some rubbing alcohol (make sure that your printer is off and NOT plugged into AC power when you do this), or it may have worn out entirely, in which case the printer would have to be serviced or replaced. Check either with HP directly, or with your place of purchase to see if warranty is available for this unit. If not, then it would probably be more economical to simply replace the printer entirely, rather than paying for parts and labour, and being without a printer for a while.
Posted on May 09, 2009
Installed new hp black cartridge 56 ink but won't print
it shows if your using refill cartridge. & if you r using refill cartridge clear cartridge sensor with soft hands your problem would be resolved.
Jan 20, 2010 | HP PSC 1315 All-In-One InkJet Printer
Everytime I turn my PSC 1510 on it prints a test page, I have new cartridges in how can I stop it...it using all my ink unnecessarly:-(
yes, when you get test page face down the page on sccaner and press scan button after some time you get green light still, further u don't get test page again.
Jul 08, 2009 | HP PSC 1315 All-In-One InkJet Printer
HP 1315 printing real slow
If there are a compatiable black cartridge
replace this cartridge with your old empty cartridge and print a test page (don't mind about printing of black )
If speed is correct,
then replace the black cartridge with another new cartridge.
(some time compatiable black cartridge not work properly to flow ink)
Jun 04, 2009 | HP PSC 1315 All-In-One InkJet Printer
HP C5180 will not print in blues
try to run maintenance pages..go to your printer panel ..and choose maintenance..and print maintenance page..
May 17, 2009 | HP Photosmart C5180 All-In-One InkJet...
Will not print in color
So it never worked?, return it, run the utility first that is on either the disk or the website
Dec 20, 2008 | HP PhotoSmart 1315 InkJet Printer
HP Photosmart 3200 All-In-One not printing yellow
Step1
If you're setting up the printer or changing the toner or ink cartridge for the first time, double-check the instructions to make sure that you installed the cartridge correctly and, for new printers, that you have removed all the pieces of cardboard or plastic packing material.
Step
Check to see whether paper is feeding from the paper tray. If it's not leaving the tray at all, try feeding a page manually (if that's an option) or using a different paper tray. Sometimes a problem with the tray can be traced to a broken spring or a piece of plastic.
Step
If paper is feeding from the tray but jamming in the printer, examine where the jam is occurring and then inspect the printer carefully to see if you can find what is causing the problem. A piece of paper, for instance, might be blocking the paper path.
Step
If paper is feeding through the printer but coming out blank, check to see whether the printer is out of toner or ink. A defective toner or ink cartridge could be the problem.
Aug 20, 2008 | HP PhotoSmart InkJet Printer
Not responding to PC instructions to print data
You need to load the PRINTED ALIGNMENT PAGE on the scanner glass, then press on "OK" button. It should start scanning the alignment page. That way, you are completing the PROCESS of ALIGNMENT.
Thank you so much.
adonscott
Jul 01, 2008 | HP PSC 1315 All-In-One InkJet Printer
PRINTING BLANK SHEETS
You need to put the test page that was printed into the scanner part of the printer and then press the scan/blue button. This is so the printer can calibrate the new ink. When you have done that the next time you turn on the printer a blank page will not be printed. When you next change ink you will have to repeat the above procedure.
Sep 01, 2007 | HP PSC 1315 All-In-One InkJet Printer
Cartridge jam
Dear Satz This problem shows when dust has come in your printer. If you have a dust cleaner pump, you should try to pump air in your printer. And About align cartridge, "Installed cartridge again (color and black) after removing. Printer print a test print, that is called alingnment page, Take this alignment page and put it into the scanner, printing area should be on mirror side. and press scan button, which is present in keypad of printer (last one) you will hear the voice of scanning after 45 sec. light will stop blinking and still. It means cartridge have been aligned.
Apr 24, 2007 | HP PSC 1315 All-In-One InkJet Printer
HP PhotoSmart 1315 InkJet Printer Logo
105 people viewed this question
Seeker5211
Seeker5211
