Question about JVC GR-D370 Mini DV Digital Camcorder
Where could I get a charger, memory card, and remote for this, and what does it usually go for?
    Problem Solver:
  • 19 Answers
The memory card - get an SD card from about 14.00 per gb.
Charger - Ebay has them
Remote - try eba
Posted on Dec 21, 2007
0 characters
3 Points
How do I record onto a SD memory card on my JVC grd72u?
Make sure the camcorder's power is off.
Open the LCD monitor (cover (MEMORY CARD).
To load a memory card, firmly insert it with its
clipped edge first.
To unload a memory card, push it once. After the
memory card comes out of the camcorder, pull it out.
Do not touch the terminal on the reverse side of the label.
Close the card cover.
To protect valuable files (available only for SD
Memory Card)
use the snap button to capture a scene.
Feb 06, 2016 | JVC Video Cameras
What does it mean when I get a message that says "please insert memory card" on my JVC Everio GZ-MG21U?
Make sure you're using an SD card, not a higher-capacity SDHC card. The GZ-MG21U works with SD cards, not with SDHC cards.
Sep 24, 2012 | JVC Everio GZ-MG21 Camcorder
GR-D370 Mini DV Digital Camcorder: i have a jvc dr-d370u and i can't format my memory...
This model can accept SD card for up to 2GB only. You may be have more than 2GB card, otherwise there is an internal problem with your camera that needs repair. Hope this helps
May 17, 2010 | JVC GR-D370 Mini DV Digital Camcorder
Memory card
I think the largest card you can use is a 4G SD card.
Jun 10, 2009 | JVC Video Cameras
GR-DX97U Need Help
ccd image sensor problem........Lucky you though!!
JVC has received reports that in certain circumstances, the following models may, while in the camera mode, show no picture, a distorted picture and/or display “LENS CAP” even though the lens cap is removed. We have identified the probable cause as a failure of the CCD image sensor. Repairs of units exhibiting these problems as a result of a defect in the CCD image sensor will be made free of charge at a JVC Authorised Service Centre even if the unit is outside warranty.
Please call our Consumer Support Department on 0870-330-5000 to obtain your free repair. We apologise for any inconvenience and we appreciate your understanding and support.
Please note that this offer expires on 31st December 2008 and is applicable only to failure of the CCD image sensor.
This information applies to the following models:
GR-D18, GR-D20, GR-D21, GR-D22, GR-D225, GR-D23, GR-D24, GR-D30, GR-D31, GR-D32, GR-D33, GR-D34, GR-D40, GR-D43, GR-D50, GR-D53, GR-D54, GR-D60, GR-D63, GR-D70, GR-D73, GR-DX25, GR-DX27, GR-DX28, GR-DX35, GR-DX36, GR-DX37, GR-DX45, GR-DX47, GR-DX48, GR-DX55, GR-DX57, GR-DX67, GR-DX75, GR-DX77, GR-DX78, GR-DX95, GR-DX97, GR-FX15, GR-FX16, GR-FXM39, GR-FXM393, GR-FXM40, GR-FXM404, GR-PD1, GR-SX19, GR-SX25, GR-SX26, GR-SXM29, GR-SXM30, GR-SXM49, GR-SXM50, JY-HD10.
Sep 04, 2008 | JVC Video Cameras
Charger is a good source for that answer. Usually they can tell you that by the batter number you are using.
Jul 03, 2008 | JVC GR-D50 Mini DV Digital Camcorder
Connection to the PC
In order to connect your GR-D70US to your USB port, you must insert an MMC or SD memory card into the camera, however neither of these cards is included with the GR-D70US, and the card must be purchased separately. You may contact the JVC parts department at 1-800-882-2345 or visit the JVC online accessory store to purchase a MMC or SD memory card. Some local retailers may also carry these memory cards.
Sep 14, 2005 | JVC GR-D70EK Mini DV Digital Camcorder
JVC GR-D370 Mini DV Digital Camcorder Logo
89 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Larry Stiles
Larry Stiles
Shekar Avadhani
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
