Question about Sharp CD-DH950 5-Disc Compact Stereo System- Open Box
Cd drawer came out
How can I get cd drawer back in unit
  • Fred Eisenlohr
    Fred Eisenlohr Apr 09, 2016
    Mine did the same thing ! Did you ever resolve it ?
Wow , mine did the exact same thing . I don't know how to fix it . How weird is this to even happen. CD drawer just comes out, go figure ?!?!? Did you ever resolve ?
Posted on Apr 09, 2016
The display flashes "closed" and I can't open the cd drawer when pressing the open/close button. Is there a reset please ?
Try removing power from the unit, let it set two minutes without power and power it up again. See if the problem continues.
Make sure the cd drawer is complete closed and flush with the front panel. If not, something could be stuck inside.
Turn off power and remove cord from wall for next step:
There is a small hole generally on the flat face of the cd drawer through which a bent straight paper clip can be pushed gently until you hit a mechanical stop. Pushing slightly harder at this point should cause the cd drawer to move open mechanically. Gently pull the cd drawer open until you can remove any CD still inside.
Gently push the drawer closed again and restore power to the unit and see if the problem returns.
Would be nice to have manufacturer and model number of the CD player.
Apr 08, 2015 | Audio Players & Recorders
How to open cd drawer
Oh my God, the answers I\'ve found on the net on how to get the CD drawer on a Crosley CR247 open are all nuts. Mine wouldn\'t open yesterday and I dismantled the whole damn thing to get the tray open, but that isn\'t necessary.
First of all my unit was making noise when I hit the eject button but the drawer wouldn\'t open. I knew there was no CD in the tray. Powering down and all the other foolish answers I found didn\'t work. There is no small round hole in the front to do a manual eject. Trying to pry the door open won\'t work and you\'ll just damage the unit. Here\'s what you need to do. And do it all GENTLY. There is no need to force anything!
Take a small, pointed steak knife out of your kitchen silverware drawer. This is all you\'ll need to get the drawer open. First let\'s identify where we\'re going to put that knife blade. The CD drawer says "CD RECORDER" and there are 3 lines on each side of that label. Where you\'re going to put that knife is below the 3 lines on the left, to the left area of those lines (see picture). This is the location of the drawer lock.
If you still hear noise when you push the eject simply push in the knife gently as you push the eject button. The drawer will open if you got the right spot.
If you hear no noise, or your unit is dead and you want the CD out, or if you\'re just afraid to stick the knife in the unit, unplug the unit. Gently push in on that spot until the drawer pops out a little bit. Now you can gently open the drawer by hand.
You can see the drive belt and pulleys (see pic). Mine was still intact but needs replaced. Here is also the info I got off of the back of the CD (see pic). Might not be able to find a replacement belt but at least you can get the thing open. Good luck.
jim Maarrttiin@msn.com
Mar 04, 2014 | Crosley CR247 Shelf System
Cd has fallen behind disk tray and drawer won't close
Remove the metal case/top from the whole unit. See screws at back and any at sides. You should then be able to see and remove the CD upwards, without removing the drawer.
Dec 14, 2013 | Yamaha Audio Players & Recorders
My cd drawer will not open. It was suggested that a belt was slipping and I take it apart. How do I do this?
To be honest with you...this unit is quite complicated to be user serviceable.When to press the open button for the cd drawer..do you hear the motor running.this unit uses gears to open the drawer.If you can hear the motor..and even if not...the drawer is not opening...please get it serviced by a qualified technician.If you try to repair this yourself..you can easily cause more damage to the unit.....by all means...DO NOT DISASSEMBLE THIS UNIT YOURSELF.I hope this was helpful....
Oct 29, 2010 | JVC MX-K30 CD Shelf System
When I press the button to open the cd drawer, the drawer doesn't open - any suggestions??
Just solved mine, turn the unit over and give it a shake and knock the underside a few times. I know you shouldn't be treating a delicate piece of hi-fi like this, but the tray comes out of the guide so you're just shakin it back in.
Apr 26, 2010 | Teac PD-H300 CD Player
My CD drawer will not open or close
I had a mini system with the same problem, out of guarantee so was either fix it myself or bin it.
I opened the unit and removed the whole cd drawer assembly from it's housing. I then, not really recommended, plugged it back in and by pressing the open/close a few times the drawer finally opened. Put it all back together and it now works fine. I think what had happened is that I use the cd player once every couple of months and combined with the lack of use is the fact that there are several smokers in the living room and basically it got jammed by a build up of nictotine or whatever.
Apr 01, 2009 | RCA 5-cd 300w Stereo System Shelf System
A CD is stuck, it won't play, and it won't eject.
i would go to the website of the make of the 5 disk changer and click on the support page. there you should find answers to your problem
Mar 24, 2009 | RCA Audio Players & Recorders
Player doesn't recognize most CDs - 'no disc' message appears.
Your player lens needs to be cleaned by a lens cleaner...
Feb 24, 2009 | Teac CD-P1260 CD Player
Cdr20 drawer is jammed ERROR message
Try taking the unit apart it mostlikly jamed or jumped track try re ajusting it that would prob work, another thing is to try messing with the gears that could aslo work
Oct 18, 2008 | Harman Kardon CDR20 CD Player
Hi, The CD drawer mechanism needs a new belt. They have a motor that drives the tray mechanism, and there's a small belt that drives the main gear so that pushing the drawer in gently to close it doesn't damage anything. However, once that belt breaks/wears out, the drawer will stay in whatever position it was last in.
Jul 24, 2008 | Audio Players & Recorders
Sharp CD-DH950 5-Disc Compact Stereo System- Open Box Logo
77 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
