Question about Goulds Pumps Goulds 1/3Hp Submersible Sump Pump Sp035V
Float turns motor on / motor hums but doesn't pump on Goulds SP035V
My water pump is only humming not working
the humming means the power is getting to it, but for some reason it is not spinning, if it ran dry too long the impeller may have melted.
Dec 26, 2014 | Goulds Pumps Pump Centrifugal 1/2hp
Wire diagram 4 gould gt20
Wiring diagrams for pump motors are usually on the inside of the cover of the wire access cover or on the motor tag. If this is a 1/2 HP motor it could possibly be wired 125V or 250V. Be sure to wire for correct voltage.
Nov 06, 2014 | Goulds Pumps GOULDS GT20...
Dissemble pump motor from impeller
The impellers screw on. Hold motor shaft and unscrew.
Oct 08, 2014 | Goulds Pumps Goulds Centrifugal SS Pump &...
Why does my goulds pump j5s draw water to the pump but it won't pump out, what could be wrong and can it be repaired?
you will have to prime the pump after working on the lines. You can get just the pump section but I doubt that there is much wrong other than priming the pump
Aug 05, 2014 | Goulds Pumps Goulds 1 Shallow Well Jet...
Why goulds septic pump buzzing
check for foreign objects jamming the impeller. have the motor tested for failure.
Jun 07, 2014 | Goulds Pumps Goulds 1/3 Hp 115V 1 Phase...
Pump doesn't reach pressure
Either it has an open outlet so there is nothing to pump against, a blocked inlet so there is nothing to pump or a bad impeller.
Aug 23, 2012 | Goulds Pumps Goulds Centrifugal Pump,...
How do I change the motor side casing on a j5s pump
The motor must be dismantled as well . a bit scary , but I have done one Carefull not to damage the motor axle ie comutator etc.
May 01, 2012 | Goulds Pumps Goulds 1 Shallow Well Jet...
Won't pump water but can hear it humming?
could be something plugging the impeller,theres I think 3 screws to remove the bottom check if some small stones are plugging it up.that pump should be installed off the bottom of the pit like on a patio block or the like.unplug the cord before messing with it.
Feb 22, 2011 | Goulds Pumps Goulds 1/3 Hp 115V 1 Phase...
Well pump running every 5 minutes
It can be water loged you need to drain some water out of your tank and put 35 psi air in it,
Aug 27, 2009 | Goulds Pumps WW0511A Goulds Sewage Pump...
Goulds Pumps Goulds 1/3Hp Submersible Sump Pump Sp035V Logo
85 people viewed this question
Top Goulds Pumps Fish Experts
Richard Lindsey ...
ThothMer
ThothMer
Level 1 Expert
Tom Chichester
Are you a Goulds Pumps Fish Expert? Answer questions, earn points and help others
