Question about HP Computers & Internet
My screen on my hp laptop cracked, ibaught a separate computer screen so icould hook it up to the laptop and still be able 2 use it. i have connected them earlier. but i just got done installing an internet virus software which recommended me 2 restart my laptop. when i tried 2 turn it back on,the laptop came on but it didnt want 2 send the signal out 2 the external monitor. i tried pressing the function key and the f4 key at the same time but that didnt work anymore either. the screen on the laptop isreally bad, and there is no way that i could use it in order 2 change any of the settings. i dont know what else 2 do. do u have any suggestions?
  • roxanabranna May 14, 2009
    I tried all the other Function keys that you recommended i try and that still didnt work. I do have a question tho, is there any way that i could of somehow locked the Fn + F4 key on the keyboard to where it wouldnt work anymore. I remember right before this problem occured, this weird box popped up on the bottom right hand side of my external screen, it displayed like two monitors and some kind of transfer arrows inbetween them. I hit the one on the right thinking that this would always display the screen onto my external monitor only. Im wondering if this process did something to where it disabled the Fn + F4 key to where i would have to manually change the settings only off of the actual laptop's screen? Is there any way that i could over ride this operation and restore the original settings back to where they were at in the beginning?
    Thank you,
    RoX
  • 6,784 Answers
The only way to change the display options to direct the viewing to the external monitor is to do it on the bad LCD screen. this is impossible, due to the fact that, the original LCD screen is ruined. you will have to send the laptop to a repair depot or the manufacture for the LCD repair.
Posted on May 15, 2009
    President:
  • HP Master
  • 2,923 Answers
It seems that the laptop stopped sending the signal to your external monitor. Even pressing the Fn + F4 didn't work.
Here's what you're going to do:
1. Connect first your external monitor into different computer to make sure that the monitor is still functioning correctly.
2. Disconnect the external monitor from the laptop and then restart again the laptop without the external monitor.
3. If you notice that the laptop is fully booted up, connect the external monitor and wait for couple of seconds.
4. Press Fn (Function) + F4 and see if that would work.
If the external monitor will not work after Fn + F4, try pressing Fn + F5; Fn + F8. These are the key combinations for transferring the signal for the external monitor.
If none of those steps work, you need to bring your laptop to the computer repair shop. Defective LCD should not affect transferring of signal to the external monitor.
Here, I provided you the link where you can bring your laptop if in case you need to repair it:
http://www.screentekinc.com/
Have great day!
Posted on May 09, 2009
Cracked laptop screen connect external monitor
If your laptop screen is cracked or broken.... its either you buy a new screen and replace it because its not repairable..... or you use an external monitor that is if you have one, and connect the VGA cable to your laptop.............
Feb 08, 2014 | HP 417035-001 - HP Pavilion dv2000 Series...
HP pavilion entertainment laptop monitor will not come on. Laptop making sounds like it is downloading something but no disc in tray, not connected to internet.
Your computer is becoming way too hot and the soder between your graphic card and monitor is melting. You need to get your computer opened and reheat your graphic card ( I usually use a heat gun.) Make sure you do not heat it too much as you could screw up your graphic card. Once it is done, just hook the battery, ram, powering unit and hook-up your screen to see if your screen works. If it works then you need to place 2 copper shims between the heat sink contact points with your processor and graphic card to keep everything at a normal temperature. Then reassemble your computer.
Sep 28, 2013 | Microsoft HP Pavilion DV6276US Notebook PC
Laptop broken screen... plugged in Dell monitor,still doesnt work
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Sep 03, 2012 | Computers & Internet
My toshiba satellite m305 s4819 had a colored lines on the screen so I thought it was simple to fix so I open the screen and tried to open the inverter jack but it was small and hard to I used flat screw...
1) The FIRST thing you do when working on a computer, Desktop or Laptop, is to Remove Power.
2) The SECOND thing is to observe Anti-Static Precautions.
You need to disconnect the Video Cable, and the Inverter, FROM the motherboard.
This will ensure that the LCD screen, Backlight, and Inverter are taken out of the system.
You may have shorted across enough with the screwdriver, to just damage the electronic components on the Inverter.
With it connected in the system the computer will not turn on.
But I also want to take the Display Assembly, out of the 'equation' temporarily.
Of course the damage may be more extensive. Diagnose one step at a time.
Laptop off, monitor off; connect a VGA monitor to the VGA connector on the laptop.
Turn the monitor on, allow it to 'warm' up.
Turn the laptop on. If graphics do not automatically show up on the external monitor, press the Fn key, and hold it down, then tap the F5 key.
The F5 key is the toggle-over display key.
You can have;
1) Just the internal monitor of the laptop,
OR,
2) The internal monitor AND the external monitor,
OR,
3) Just the external monitor.
This is why you may have to tap three separate times.
Post your findings back in a Comment.
Regards,
joecoolvette
Sep 24, 2011 | Toshiba Computers & Internet
How do I take out the screen on my HP G71 -329WM laptop
I have a HP Pavilion zv6000 laptop and have replaced both the screen and the hinges, plus a few friends laptop screens all the same way. First remove the battery and unplug the laptop. To replace the screen you will need to to remove the hard drive and remove all the screws form the underside of the laptop to allow access to the underside of the keyboard as the connectors for the screen are under the bezel above the keyboard. Opening the lid all the way will make it easier to get under the keyboard t and bezel then disconnect the power, video signal, and wifi connectors. Might be 1 or 2 or 3 separate connectors. Carefully removed the rubber plugs from the front of the screen and stored them so you didn't loose them. Using a small screwdriver, remove the screws under the plugs. Using a flat screwdriver or small thin blade, carefully separate the bezel around the outside of the screen, it may be glued together so take care not to crack the plastic. At this point would can see the screen screwed in to the hinges and the back of the lid and what screws need to be removed. The wifi antenna is usually attached to both the screen and the lid via tape so take care when removing the screen. Place the new screen back and attach the hinges and connectors, making sure to place the wifi antenna back where it was located properly. At this point I plug in the laptop and verify the HP logo or POST screen appears whe I turn it on, showing that the connections are ok before unplugging and continuing to replace the remaining screws, hard drive and finally battery. Depending on how the bezel around the screen is attached, you might want to use double stick tape as the glue no longer holds the front and back together around the screen. Depending on how mechanical you are, figure between 30 and 60 minutes to replace the screen the first time.
Dec 03, 2010 | Computers & Internet
If the screen is cracked how do you get another monitor that is hooked up on the side of the laptop to show up?
That's a tricky one, but when i connected a secondary monitor to my laptop, the desktop automatically changed to the new monitor.
Dec 22, 2009 | HP 530 CD T2400 1.83GHZ/1GB/VBUS (KD096AA)...
Black Screen
The first thing I would do after turning the computer on is check to see if the video output is being directed to the LCD screen. The output can be directed using the Fn key along with the key with the picture of the 2 monitors on the Function keys at the top of the keyboard. Hold down the Fn key and tap the other key once or twice,
Next, hook the computer up to an external monitor. Do the same thing with the Fn key to see if it's the LCD screen.
If the external monitor works, then you haven't correctly hooked up the LCD screen or it's bad.
Feb 05, 2009 | Averatec 3200 Notebook
THE LCD SCREEN ON OUR ACER ASPIRE 5520 IS CRACKED, HOW DO WE HOOK IT UP TO AN EXTERNAL MONITOR SO WE CAN STILL USE IT UNITL WE FIX THE SCREEN
Connect a monitor to connector 2 or 3
Hold down the Fn key and press F5. This toggles between laptop screen and the external monitor.
Dec 27, 2008 | Acer Aspire 5610-4648 Notebook
Display
sounds like the video chip is history.
Feb 20, 2008 | HP Pavilion dv1000 Notebook
Computers & Internet Logo
128 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
