Question about GPS
Hard reset magellan smartgps - GPS
I was trying to update my software and I accidently connected the unit to the computer before I was supposed to. Now the unit is frozen on the Magellan screen. If I connect it to the computer it just...
Look in your manual on how to do a hard reset. Usually is holding the power button/slide on while resetting. That can get it out of loops. This is a more brute force reset that just using the reset button
If that doesn;t work you should talk to magellan tech support. They are quite helpfull and may have some differant way to reset things. And at worse will be able to tell you if it is time to send it in.
Mar 30, 2010 | Magellan Maestro 5310 Car GPS Receiver
Reseting the Magellan Roadmate 360 to the factory settings
Hello there:
here is a couple of linkds that i was able to retrieve hopefully they will help you ok
best regards michael
  1. [PDF] Magellan User Manual 3519k - Adobe PDF - View as html The Magellan RoadMate 800 is a vehicle ... segments totalling 360 degrees. Starting at the Prime Meridian (which is ... 11.2 Resetting the Magellan RoadMate ...www.magellangps.com/assets/manuals/MRM_800NA_en.pdf
  2. Magellan RoadMate 360 Manuals, Support and Troubleshooting - GPS Free download of Magellan RoadMate 360 User Manual. Troubleshooting ... Resetting the Trip Computer " • Viewing a Saved Trip Report " • Deleting a Trip Report " ...www.retrevo.com/support/Magellan-360-GPS-manual/id/421ag200/t/2 - 109k - Cached
  3. Magellan_RoadMate_360_North_America_Manual Documents_and_Forms ... Magellan RoadMate 360 North America User & Instruction ManualGet access the the ... Resetting the Trip Computer. Viewing a Saved Trip Report. Deleting a Trip ...store.payloadz.com/str-asp-i.388383-n.Magellan_RoadMate_360_North_America_Manual_Othe... - 189k - Cached
Sep 18, 2009 | Magellan RoadMate 360 GPS Receiver
It is shutting down while we are using it. it is plugged into the lighter outlet and has power, does not show a low battery
try a hard reset first using a paper clip, innsert it in the little pin hole on the side to reset the unit. if that fails, get the 3.12 update off the magellan site..you must register the unit with magellan before you can download the update.
Jul 29, 2009 | Magellan RoadMate 1430 GPS Receiver
Magellan roadmate 1430 calibration is wrong
try a hard reset again using a paper clip, insert it in the little pin hole on the side to reset the unit. if that fails, get the 3.12 update (if you havent already) off the magellan site..you must register the unit with magellan before you can download the update.
Jul 02, 2009 | Magellan RoadMate 1430 GPS Receiver
HOW CAN I GET THE GPS TO SPEAK AGAIN.
make sure its not muted or volume turned down. if ok then use the hard reset on the side (tiny hole)use paper clip to reset it. if none of those work check your firmware version and see if its the latest..i have the latest updates for magellan 2200t 3100 3140 4000 4040 and 4050
Jun 11, 2009 | Magellan Maestro 4040 GPS Receiver
I have a Magellan Maestro 4250 and touch screen not responding
Yes. The hard reset is the little pinhole on the left. Just use a pin and poke it. It should bring everything back to factory default and all saved info, addresses, routes etc. will be deleted.
Jun 07, 2009 | Magellan Maestro 4040 GPS Receiver
My magellan GPS Roadmate 1400 hard reset
there is a little pin hole on the side on the unit. you need a paper clip to reset it
May 27, 2009 | Magellan RoadMate 1400 Car GPS Receiver
Needs password
if you got computer software with this unit you might want to reinstall it and reset the password. otherwise you might want to do a hard reset which clears the password and storage memory.
that should help
Jun 12, 2008 | Magellan RoadMate 800 GPS Receiver
Stuck on magellan load screen where it says magellan
there should be a small hole eather in the back or side of the unit to insert a tooth pick or something not share to reset the unit to factory defaults.
that should do it
May 13, 2008 | Magellan RoadMate 800 GPS Receiver
How to hard reset magellan 700
Hussam.. I believe the newest software upgrade you can get for the 700 is version 4.32 which is the same version used on the 760's. The maps are stored on the hard drive, so I do not think a reset will help but here is how it's done. 1. At the user select menu (first screen to appear after initial turn on) hold down the zoom out key (-) and the repeat button (on top of your unit). 2. Once at the "secret" menu, select reset user data. This will reset all of your personal information from the unit. All of your POI's will be deleted as well as your user name (which you can re-create of course) 3. Your unit will re-boot automatically and that's how you reset your unit. Like I said though, I do not think this will revive your maps. If you have the maps on a DVD-CD then you can reload them that way, otherwise send it to the Fort Worth, Tx repair center and they have the proper program to load data directly to the hard drive. Good luck! -Daniel
Jun 28, 2007 | Magellan RoadMate 700 GPS Receiver
GPS Logo
125 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
