Question about Toshiba SD-3990 DVD Player
Toshiba sd 3990 won't play disc - Toshiba SD-3990 DVD Player
SOURCE: toshiba sd-3990 Disc-drawer won't open
I was given one of these the other day. I was told the drawer wouldn't open yet the machine seemed to function fine. I removed the six screws holding the top on the box and then removed the four screws holding the drawer assembly in place. As you lift the drawer assembly out of the box, make sure you release the two pieces of black retaining tape holding the data cable to the box floor. Turn the drawer over and you will see that there is a little sideways bar mounted on the front underside of the drawer assembly. This is sticking. As you press the OPEN button, jiggle this bar and the drawer will open. You may have to manually move the drawer cogwheel a little to help free it up. Hope this helps.
Posted on Oct 07, 2008
SOURCE: Toshiba DVD SD-3980SU2 or SC2 player loads every disc as "bad disc"
Toshiba says:
Information for Owners of Toshiba SD-3980 and SD-K750 DVD Players spacer.gif To ensure the satisfaction of our customers and to maintain the integrity and quality of our products, Toshiba America Consumer Products, L.L.C. is issuing an important product update. This is not a safety issue.
Toshiba is committed to customer service and to continuously improving the quality of its products. It has come to our attention that certain DVD players bearing the model numbers SD-3980 and SD-K750 may at some point in their life stop playing discs due to a component part failure. In such case, the error message "bad" will be shown on the unit's display. Affected units will have "SU2" at the end of the model name (e.g., SD-3980-SU2), which can be found on the back of the unit.
If you own either of these models and experience the issue described above, please contact Toshiba Customer Solutions at 1-800-631-3811 for information on how to obtain a replacement unit.
Posted on Jan 18, 2009
SOURCE: TOSHIBA SD-1600 WILL NOT PLAY DVD+R RECORDIBLE DISC.
wer i can find the model of the toshiba dynabook video driver?
Posted on Feb 03, 2009
  • 11 Answers
SOURCE: Get Disc Error on display when loading a disk
you have problem with EPEROM IC you have to bring your set to toshiba repair center and they give a new program to your set . the program of your set is defected must be repaied
Posted on May 29, 2009
SOURCE: CD is hung up in the player and does not come out with the tray
There are a few solutions:
1. hit it ok just kidding
make sure when you are trying to open it does not say "disc Lock" or some sort. You can solve this problem by hitting the device menu and typing in 2005
2. Open up the device by unscrewing the six case bolts and then the 4 dvd section screws. After this I had the problem where my dvd was stuck in the play mode so the tools would just not let go. I had to gently wiggle them apart however be very careful. I have also heard that it might be a tired arm on the side that just needs some coaxing. HOpe this helps
Posted on Jul 25, 2009
Dvd won't turn on
the roller have problem, fix it with oil
Oct 29, 2012 | Toshiba SD-3990 DVD Player
Toshiba SD3950SU quit reading discs after playing an old disc. It will still play the old disc
The optical pickup unit might need replacement. Visit this site for more details. Type in the site name "Electro-help" either Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as Service help to electronic home entertainement equipments.
Pull up older posts. You can get all details.
Site is listed in Google, and you can locate it either at the bottom part of first search page, or at the top of second page.
Click on associated ads too. Sometimes, it might help you.
May 30, 2012 | Toshiba SD-3990 DVD Player
Player will not read discs. keeps saying "no disc" when discs are inserted. Worked fine until today.
Easy option first , clean laser with a laser cleaning disc ,if that doesn't work then (I assume you have tried more than 1 disc). a laser won't read a dirty disc, you may have a laser mechanism fault ie laser sticking in its tracks. you could try oiling the cradle that the laser sits on. other than that it is a costly repair.
pete
Mar 06, 2011 | Toshiba SD-3990 DVD Player
Screen on TV shows Toshiba label and says there is no disc but a disc loaded in it
The laser unit has gone bad. Usually it's not worth replacing as it is about 3/4 the cost of a new player.
Jul 25, 2009 | Toshiba SD-3990 DVD Player
Mar 23, 2009 | Toshiba SD-3990 DVD Player
Mar 13, 2009 | Toshiba SD-3990 DVD Player
DVD player won't play DVD, says "load"
The unit can recognize that a disc has been loaded but can not read the contents. This can be as simple as a dirty lens or more drastic like failing optics. Try cleaning the lens using a cotton swab and alcohol. If that fails to correct the problem and a music CD will play OK, then the optics are failing. DVDs require more laser power to read than a music CD.
Dan
Feb 04, 2009 | Toshiba SD-3990 DVD Player
Setup menu selected entered component under VIDEO
I was able to read a couple of words on the menu screen and with the help of them manual I was able to figure out how to navigate to the default button and was able to reset.
Nov 24, 2008 | Toshiba SD-3990 DVD Player
Toshiba SD-3890 several related problems, I think!
http://www.tacp.toshiba.com/tacpassets-images/notices/sd-3980_sd-k750.asp
Check this page, there is a problem with one of the components that causes it to fail. Call the number to get a replacement.
Jan 26, 2008 | Toshiba SD-3990 DVD Player
MP3 files on a DVD+RW disc - not all display or play
Toshiba SD-3990 does not recognize DVD+R/RW discs. You need DVD-R/RW
Jan 09, 2008 | Toshiba SD-3990 DVD Player
Toshiba SD-3990 DVD Player Logo
66 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
