Question about Thermador Dishwashers
Thermador dishwasher error code s2 - Thermador Dishwashers
2 Suggested Answers
  • 21 Answers
SOURCE: Thermador dishwasher DWU244, error code "F" does not run?
f code is a fill fault problem to much or to little water to determine the problem is to hit cancel drain buttons on the front of the machine and wait for cl on the display turn off machine and wait 30 seconds turn back on and the first thing you will hear is the drain motor turn on for 15 sec then you should hear the water filling into the machine if you dont hear water filing then check to see if the valve under the sink is open to allow water to fill machine
Posted on Jan 05, 2011
What does the thermador dishwasher dwhd640jfp error code e:21 mean?
E21 Circulating pump blocked.
A blockage between the motor or the pump resulting in insufficient water flow.
Feb 22, 2015 | Thermador Dishwashers
Why do I have error code F25 on my Thermador oven error codes
clean the touchpad control panel. Make sure the oven door closes properly to prevent excessive heating of the touchpad. If these don't resolve it, it calls for a replacement of BOTH the touchpad AND the relay board. EXPENSIVE!
Aug 23, 2014 | Thermador SC272T Electric Double Oven
How to use star speed cycle on thermador dishwasher
A typical insruction in Thermador dishwasher manual explaining use of the star speed program...
Apr 19, 2014 | Thermador Dishwashers
What is error code F34 on the thermadore built in double oven
If your Thermador was manufactured between 2004 and 2007, this may be due to a recall issue. I kept getting this error on my Thermador wall oven when I would run the self-cleaning feature, and when heating it over 375 degrees. After doing some research, I discovered that my oven was recalled. Apparently there are gaps in the insulation which could cause a fire. You can find out more on the Thermador website: http://www.thermador.com/safety-notices/7_oven-safety-recall-notice-expanded
Oct 15, 2010 | Ovens
Do you have any insight into disassembly of a thermador DW246US dishwasher?
Hi, Welcome to FixYa. Since this model Thermador is a B/S/H/ built ( bosch...provided the model is indeed DW246US ) machine let me know what you want to service and I can provide pretty much any service guides, info and direction on what or how to proceed. Macmarkus :)
Oct 09, 2010 | Thermador DW44Z Built-in Dishwasher
My thermador oven tells me error code 14
Sometimes you can unplug the unit for at least 30 minutes and reset the unit and it wont do it again.Try that first. An error code on a thermador of 14 means latch switch problems.
May 12, 2009 | Thermador SMW272 Electric Double Oven
Feb 15, 2009 | Thermador DWU244 Dishwasher
Will not drain
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Feb 08, 2009 | Thermador DWHD44E Built-in Dishwasher
Flashing Lights on Thermador Oven/Range
the lights flashing in a sequence indicates the error code. The error codes indicates what the problem is with your stove. Based on the response to your message, it sounds like their error code is 12, one then two. It is not clear what your error code is.
There is an explanation of the error codes on the wiring diagram that comes with the stove. I found the wiring diagram for my stove taped to the inside of the kick plate. The kick plate had to be removed to find it.
my oven is not working either. the error code I get is 34. I am told by a technician that error code indicates that the computer is not recognizing that the cooling fan is operating, which is why my oven will not work.
When I try and order a new cooling fan from Thermador, the website says that it is temporarily out of stock. Obviously, other people are having the same problem I am.
Jan 31, 2009 | Thermador PGR366 Gas Kitchen Range
Dishwashers Logo
20 people viewed this question
Top Thermador Dishwashers Experts
ray gallant
Ken Johnston
Ken Johnston
Level 1 Expert
Are you a Thermador Dishwasher Expert? Answer questions, earn points and help others
