Question about Generac 20 Kw Air-Cooled Standby Generator
LCD panel is blinking but blank
Generator works fine but the lcd panel on the generator is blank and is slowly blinking.
Why my LCD TV blinks picture and goes off when backlight is high
When you set the backlights to high it causes the inverter board to generate more energy, as well as consume more from the power supply, all the while both are generating more heat. If you have your set mounted (restricting the vents) and/or you regularly use the high setting, that could cause capacitors to bulge and leak due to excessive heat damage. I would open her up and have a look at the power supply and inverter boards. Check for bad caps or board surface discolorations.
May 26, 2014 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
My samsung LE40R74BD set works fine for about 10 mins then screen goes blank (black) . It would appear there is no back lighting. I have visually checked the psu for blown capacitors but all seem to be...
This does not seem to be a power supply issue but rather an issue with the backlight inverter board. When the screen goes black, take a flash light and focus it on the screen from a close distance and several angles. See if you notice a very faint image. Try changing the channels to make it more noticeable. Try it and let me know
May 09, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Sony bravia kdl-46v3000 screen is full of lines at start up and slowly starts going away sometimes even blank screen have to shut it off and back on for screen to come back on .any sugestions?
Basically it is problem of lcd panel (screen) but some times T-Con board (it is also part of lcd panel) replacement fix the issue.
T-Con board is located top center of lcd panel at back and need to take off back cover of tv to see it, this board would be covered under metal shield.
Expertise are required to replace this board and novice can damage lcd panel (screen) permanently.
Thanks.
Jan 08, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Hello. I have a Vizio 32 inch LCD flatscreen TV. About 5-6 years old. Once on, it works fine for a minute or two but then the screen goes blank and the orange Vizio blinks on and off. Every time. Does...
this is a main board problem. Replacing this will resolve the problem for you. if you want a tech to come to your home and fix it for you, you can call ITI at 888-248-2708
Jun 18, 2009 | Vizio VX32LHDTV10A 32 in. LCD HDTV
Dynex 19 LCD
I went over the specs of the TV.
The max input for the VGA is 1360x768 at 60Hz. Anything higher will make the TV go bonkers.
I would try to get the resolution at 1360x768, then change the frequency to 60Hz.
May 29, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
It will power on but then turn right back off it worked fine yesterday
One of four things happen when these lcd's get power problems. 1. They either go completely dead[no power with no lights] 2. Little green light will blink and go back to red with dtv briefly showing and then the tv screen go blank 3. Same as # 2, but with screen staying blank. The fourth is extremely rare, which is a shorted panel that makes the tv set behave like it's getting no power. All signal a bad tv, and the fourth is not usually repairable, requiring a whole new panel. I hear that power flows thru the panel, so that would explain how sometimes it will short out.
Apr 28, 2009 | Emerson EWL3706 37 in. LCD Television
Apex Digital 19" LCD wont turn on green light blinks
you can have a electronics repair done on this unit call 719 687 6997
Jan 14, 2009 | Apex Digital AVL2076 20 in. EDTV-Ready LCD...
Monitor is Blank and Power Light Blinks
JH77,
Hi...Ya! It's seems your LCD monitor backlight inverter just run out of lucks... it's burnt out. Need to replaced a new inverter. Have a nice day!
Sep 25, 2008 | Dell E173FP 17" LCD Monitor
Generac 20 Kw Air-Cooled Standby Generator Logo
Top Generac Electrical Supplies Experts
Craig Butler
Craig Butler
Ottoniel
dennys23601
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
